Date/Time: Sat, 18 May 2024 18:05:00 +0000
Lines and performance
View Count: 584
[2018-10-25 15:13:16] |
User459170 - Posts: 262 |
If there are many lines manually drawn on the chart, would it affect slow the chart down? Thanks.
[2018-10-25 16:33:08] |
Yes it can. Also refer to this additional reason: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often: 30.33 - Dotted or Dashed Lines >= 2 Pixels in Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
