Date/Time: Sat, 18 May 2024 02:16:35 +0000
Advancing Stocks Ratio Chart Not Available In Sierra Chart Market Internals
View Count: 1061
[2018-10-24 00:46:50] |
Alberto Gauer - Posts: 121 |
Hi guys. I could not find this symbol in market statistics. How can I create it using the available charts?? I am attaching an image with the formula. To create the ASR, we need: Advancing Stocks / Advancers+Decliners = Advancing Stocks Ratio |
2018-10-23-214235_1280x800_scrot.png / V - Attached On 2018-10-24 00:46:00 UTC - Size: 544.29 KB - 385 views |
[2018-10-24 15:19:34] |
We have created a Study Collection of the NASDAQ for you to show you how this is done. Here are the instructions for using the Study Collection: Study Collections: Using a Study Collection Provided by Sierra Chart Support To put this together we opened the Decliners Market Stats and then used the Add Additional Symbol study to open the Advancers Market Stats. From there, we used the Sum (Bar) study to sum together the Advancers and the Decliners, then used the Study Subgraphs Divide/Ratio study to create the final ratio of the Closing price for each bar. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
AdvancingStockRatio.StdyCollct - Attached On 2018-10-24 15:18:56 UTC - Size: 28.02 KB - 340 views |
[2018-10-24 15:58:36] |
Thank you very much John! Now I can do the same thing for the NYSE!! A quick question: I see you have the Sum Bar study, where is the Subtract Bar study? How do we subtract the values of one chart from another? EDIT: Found it, it is the Difference Bar study Date Time Of Last Edit: 2018-10-24 16:08:17
