Date/Time: Sun, 05 May 2024 08:54:31 +0000
[Programming Help] - How to add percentile/numerical lines
View Count: 729
[2018-10-22 14:38:25] |
User135907 - Posts: 5 |
I wish to add a +20 line and -20 line into the Rahul Mohindar Oscillator. (It already has a 0.00 center line with defaults.) This will give a much quicker over-bought/over-sold indication (specific mark) without attempting to visualize across open spaces on these lower studies... Can I copy/drag default study/indicator into build new study and add line there and apply a new name? Date Time Of Last Edit: 2018-10-22 14:50:10
[2018-10-22 19:35:38] |
Refer to: Chart Studies: Adding a Horizontal Line to an Existing Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-22 20:55:53] |
User750920 - Posts: 274 |
SO if you want to add multiple lines to a study you would have to add multiple instances of the Line study correct? Could yo use the Tools draw horizontal line instead for a fixed point line that did not need changing. |
[2018-10-22 21:02:24] |
I think I found it - the Horizontal Lines Study appears to allow multiple lines.
