Date/Time: Wed, 08 May 2024 20:24:33 +0000
Trading with IB using TD Ameritrade's data
View Count: 805
[2018-10-22 04:57:56] |
User517452 - Posts: 27 |
I plan to trade with IB while using TD Ameritrade's data on one computer. I'd like to know which way is better? using 2 copies of SC from 2 install directories or 2 instances of SC from same install directory? Which way if faster for data download? Which way is more stable for software performance? Which is way causes less confusion? Is the cost the same?
[2018-10-22 10:45:14] |
You need two separate copies of Sierra Chart and also take note of this: Breaking Change: Remote Chart Data Files Really we recommend you use the Sierra Chart Exchange Data Feed instead: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-22 10:45:20
