Date/Time: Tue, 07 May 2024 16:33:01 +0000
I can login to Sierra charts web site
View Count: 1065
[2018-10-20 07:32:38] |
User988462 - Posts: 1 |
Hi I can login to Sierra charts website I cannot login into Sierra charts desktop to look at the charts for some reason the login or password is incorrect I have triple checked it and I cannot login can you please help. Regards Will |
[2018-10-20 08:53:22] |
We have reset your Sierra Chart charting and trading software password. It has been sent in a separate e-mail to your e-mail address. If you did not receive it, let us know. Your e-mail provider may have filtered the message and placed it in a junk mail folder. For complete Login instructions and help with possible Login problems, refer to: Sierra Chart - Software Login Instructions If you continue to have a problem logging in, then let us know and provide us with the *exact* error message you see after pressing the Login button. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
