Date/Time: Wed, 01 May 2024 19:46:02 +0000
Trade DOM Buy/Sell Column Lines color applies to text
View Count: 1391
[2018-10-18 20:29:08] |
User796776 - Posts: 95 |
Setting the Trade DOM Buy/Sell Column Lines color to match the Trade DOM Buy/Sell Column Background results in the Text not being distinguishable. The Trade DOM Buy/Sell Column graphics setting does not have a Quantities setting similar to Trade DOM Bid/Ask Depth. Is there a setting to set the text color of the Trade DOM Buy/Sell Column? |
[2018-10-19 04:34:59] |
This is not making sense to us. We are not sure what you are asking about. There are color settings for the Chart/Trade DOM Bid/Ask Depth Quantities. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-19 15:43:03] |
Sorry, let me clarify; steps to repro: 1. Open new trading DOM 2. Trade/Customize Trade DOM Columns 3. Add Buy Order Column and Bid Size Column 4. Chart/Graphics Settings, uncheck Global 5. Enable Trade DOM Buy Column Background, Apply. this will set same color the same as the Trade DOM Buy Column Lines 6. Text is not view-able in the column, want to change text to White but no setting for text or "Quantity". 7. Change the Trade DOM Buy Column Lines to white and the text is now visible. This also applies to the Trade DOM Sell Column. |
[2018-10-22 18:01:16] |
Is additional information needed?
[2018-10-22 19:53:01] |
John - SC Support - Posts: 31280 |
We will add options to the Graphics settings for the following: - Chart DOM Buy Order Quantity Text - Chart DOM Sell Order Quantity Text - Trade DOM Buy Order Quantity Text - Trade DOM Sell Order Quantity Text For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-30 17:49:05] |
Tested with 1831, the Graphics Settings are present, however the text is still using the Column Lines setting for its color.
[2018-11-01 18:37:27] |
These settings have not yet been implemented but will be today. A new release though will be out probably tomorrow.
[2018-11-14 16:26:02] |
Tested with 1841; the Quantity Text settings are working however, the Title/Custom Title still appears to be using the line setting not the Text setting.
[2018-11-14 18:14:35] |
The title will use the buy and sell order column line colors.
[2022-10-25 16:45:01] |
User753684 - Posts: 1 |
I am trying to view market depth data on my doms and it will not show the chart Dom ask depth quantities. In both the global graphics and chart graphics it shows this option grey, I cannot enable it at all. I have market depth enabled on two different services and it shows the same thing with both. I have also done all of the market depth recommendations in the forums but only show one level of depth still if I bring up a market depth chart.
[2022-10-25 17:17:03] |
You do NOT have an exchange active with us that includes the Market Depth. This is why you are only getting the 1 level. To change your selected exchange go to the following page: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed#Exchanges Just be aware that the exchange fees are NOT pro-rated, therefore you will pay the full amount for the month regardless of when you activate the exchange within the month. For example, if you activate the "Full CME Group with Market Depth for Non-Professionals" you will pay $33.00 today in order to get the data for the remainder of October and then you will need to pay again on November 1 for the month of November. Therefore, you may want to wait until the first of the month before activating a new exchange. You would then "Deactivate" your active exchanges immediately, as you will continue to get the data through the end of the month, you are just setting them to not automatically renew. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
