Date/Time: Thu, 02 May 2024 11:14:57 +0000
Can't Connect to Rhithmic
View Count: 977
[2018-10-16 18:20:15] |
User661100 - Posts: 8 |
I was using Sierra on a Free Trial and had no trouble connecting to Rithmic. Now that i have a paid subscription...it won't connect. I was able to open and login to Rithmic but Sierra won't connect to the Data Feed. I've checked the config and the Service Rithmic Trading....Server: Paper Trading Server are both correct. And I have my Rithmic user name and PW. thank you |
[2018-10-16 20:12:43] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-16 20:56:50] |
Thank you for your prompt reply. After not being able to connect for a couple of hours, I decided to reboot the computer. It's now connecting. Hopefully it will continue to do so. If I need to contact you again, I'll provide a copy of the Message Log. thanks! |
[2018-10-16 21:05:48] |
Okay then we expect this was going to be some kind of Rithmic software issue. That is something we have no control over and this is one reason why we disfavor Rithmic.
[2018-10-21 21:10:08] |
Same Problem again not being able to connect to Rithmic. Here is the message log. thanks Reading Internal Order ID file. | 2018-10-21 17:05:53 Reading Trade Orders file. | 2018-10-21 17:05:53 Reading Trade Positions and Account Balance file. | 2018-10-21 17:05:53 Listening on UDP port 22903. | 2018-10-21 17:05:53 Software version: 1795 64-bit | 2018-10-21 17:05:53 Usage end date: 2019-01-17 | 2018-10-21 17:05:53 Enabled for: Advanced Features. | 2018-10-21 17:05:53 Enabled for: Sierra Chart Historical Data Service. | 2018-10-21 17:05:53 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-10-21 17:05:53 Current selected Data/Trading service: Rithmic Trading | 2018-10-21 17:05:53 Chart Update Interval: 100 | 2018-10-21 17:05:53 Time Zone: -04:00:00 (EST-05EDT+01,M3.2.0/02:00,M11.1.0/02:00) | 2018-10-21 17:05:53 2018-10-21 14:05:53 Local computer time | 2018-10-21 17:05:53 2018-10-21 21:05:53 Local computer time in UTC | 2018-10-21 17:05:53 2018-10-21 17:05:53 Local computer time in SC Time Zone | 2018-10-21 17:05:53 2018-10-21 21:05:52 Server time in UTC | 2018-10-21 17:05:53 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-10-21 17:05:53 Program path: C:\SierraChartE2T\ | 2018-10-21 17:05:53 Data Files path: C:\SierraChartE2T\Data\ | 2018-10-21 17:05:53 OS Version Number: 6.1 | 2018-10-21 17:05:53 Locale Setting: C | 2018-10-21 17:05:53 Created the DTC Protocol server. | 2018-10-21 17:05:53 DTC Protocol Server listening on port 11099. | 2018-10-21 17:05:53 Created the DTC Protocol historical data server. | 2018-10-21 17:05:53 HD Server Manager | Listening on port 11098 | 2018-10-21 17:05:53 Checking for new symbol settings for service code rithmic.trading | 2018-10-21 17:05:53 HTTPS connection to www.sierrachart.com:443 (4) | Creating socket. Using TLS 1.2. | 2018-10-21 17:05:53 HTTPS connection to www.sierrachart.com:443 (4) | Connecting to IP: 204.15.192.108. | 2018-10-21 17:05:53 Received 5 login tokens. | 2018-10-21 17:05:54 Symbol settings are up-to-date for rithmic.trading | 2018-10-21 17:05:54 HTTPS connection to www.sierrachart.com:443 (5) | Creating socket. Using TLS 1.2. | 2018-10-21 17:05:55 HTTPS connection to www.sierrachart.com:443 (5) | Connecting to IP: 204.15.192.108. | 2018-10-21 17:05:55 Files to Open on Start up | Opening file: NQ 233 Short Skirt.Cht | 2018-10-21 17:05:57 NQZ8-CME 233 Trades #1 | Reloading chart. | 2018-10-21 17:05:57 NQZ8-CME 20 Sec #4 | Reloading chart. | 2018-10-21 17:05:57 NQZ8-CME 233 Trades #7 | Reloading chart. | 2018-10-21 17:05:57 NQZ8-CME 233 Trades #8 | Reloading chart. | 2018-10-21 17:05:58 NQZ8-CME [C] 1 Day #9 | Reloading chart. | 2018-10-21 17:05:58 HTTPS connection to login.sierrachart.com:443 (1) | Socket gracefully closed by remote side. | 2018-10-21 17:05:58 HTTPS connection to login.sierrachart.com:443 (1) | Received socket Close event. | 2018-10-21 17:05:58 NQZ8-CME 15 Min #10 | Reloading chart. | 2018-10-21 17:05:58 F.US.TYAZ18 15 Min #11 | Reloading chart. | 2018-10-21 17:05:58 Custom studies file does not exist: C:\SierraChartE2T\Data\ChandelierStop_64.dll | 2018-10-21 17:05:58 NQZ8-CME [C] 233 Trades #2 | Reloading chart. | 2018-10-21 17:05:58 HTTPS connection to login.sierrachart.com:443 (1) | Initiating close of socket by core. | 2018-10-21 17:05:58 HTTPS connection to login.sierrachart.com:443 (1) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-21 17:05:58 HTTPS connection to login.sierrachart.com:443 (1) | Closed. | 2018-10-21 17:05:58 F.US.TYAZ18 15 Min #11 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChartE2T\Data\F.US.TYAZ18.scid | 2018-10-21 17:05:58 Starting first historical Intraday data download. When complete another download will be done from the primary service. Symbol: NQZ8-CME | 2018-10-21 17:05:58 Intraday data recording state for symbol NQZ8-CME is set to download 'Pending'. | 2018-10-21 17:05:58 HD Request # 2 | Downloading Intraday chart data for NQZ8-CME to the file NQZ8-CME.scid. Service: cme | 2018-10-21 17:05:58 HD Request # 2 | Download start date-time: 2018-10-19 16:59:59.000 | 2018-10-21 17:05:58 HD Request # 2 | Using server: ds7.sierracharts.com port 10149 | 2018-10-21 17:05:58 Socket (6) | Creating socket. | 2018-10-21 17:05:58 Socket (6) | Connecting to IP: 8.18.161.133. | 2018-10-21 17:05:58 Rithmic Trading | Port for executable: 50220 | 2018-10-21 17:05:58 Listening socket (1084). Port 50220 | Closed. | 2018-10-21 17:05:58 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:05:58 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50220. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:05:58 HD Request # 2 | Setting DTC encoding to Binary VLS | 2018-10-21 17:05:59 HD Request # 2 | Sending historical data logon request message. | 2018-10-21 17:05:59 HD Request # 2 | Requesting Intraday data. Start date-time: 2018-10-19 16:59:59. Record interval: 1. Symbol: NQZ18 | 2018-10-21 17:05:59 HD Request # 2 | Decompressing data. | 2018-10-21 17:05:59 HD Request # 2 | Receiving Intraday data for NQZ8-CME starting at 2018-10-19 16:59:59 | 2018-10-21 17:05:59 HD Request # 2 | Timestamp of first Intraday data file record written: 2018-10-19 16:59:59 | 2018-10-21 17:05:59 Socket (6) | Initiating close of socket by core. | 2018-10-21 17:05:59 Socket (6) | Shutdown started. Waiting for graceful close. | 2018-10-21 17:05:59 HD Request # 2 | Historical data for NQZ8-CME is delayed because connection to main data feed is not present. Current data will be received upon connection. | 2018-10-21 17:05:59 Historical data download thread signaled to stop. | 2018-10-21 17:05:59 HD Request # 2 | Received 1 record from 2018-10-19 16:59:59 to 2018-10-19 16:59:59 (0.0 seconds) and wrote 1 record for NQZ8-CME | 2018-10-21 17:05:59 HD Request # 2 | Completion time: 0s | 2018-10-21 17:05:59 HD Request # 2 | Intraday data download complete for NQZ8-CME. Unique request ID: 1 | 2018-10-21 17:05:59 Removed historical data download ID 1 | 2018-10-21 17:05:59 Rithmic Trading | Using primary service for historical data for NQZ8-CME | 2018-10-21 17:05:59 Historical data service client indicated that downloads are not enabled. Symbol: NQZ8-CME. Data Type: Intraday data | 2018-10-21 17:05:59 Historical data download ID 2 not found when removing ID from outstanding request set. | 2018-10-21 17:05:59 HD Request # 2 | Download from primary service not started due to error. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (2) | Socket gracefully closed by remote side. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (2) | Received socket Close event. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (2) | Initiating close of socket by core. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (2) | Closed. | 2018-10-21 17:05:59 Socket (6) | Socket gracefully closed by remote side. | 2018-10-21 17:05:59 Socket (6) | Closed. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (4) | Socket gracefully closed by remote side. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (4) | Received socket Close event. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (4) | Initiating close of socket by core. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-21 17:05:59 HTTPS connection to www.sierrachart.com:443 (4) | Closed. | 2018-10-21 17:05:59 Rithmic Trading | Bridge process is running. | 2018-10-21 17:06:00 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50220 | 2018-10-21 17:06:00 DTC Client socket (7) | Creating socket. | 2018-10-21 17:06:00 DTC Client socket (7) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:00 HTTPS connection to www.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-10-21 17:06:01 HTTPS connection to www.sierrachart.com:443 (5) | Received socket Close event. | 2018-10-21 17:06:01 HTTPS connection to www.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-10-21 17:06:01 HTTPS connection to www.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-10-21 17:06:01 HTTPS connection to www.sierrachart.com:443 (5) | Closed. | 2018-10-21 17:06:01 DTC Client socket (7) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:01 * DTC Client socket (7) | Initiating close of socket by core. | 2018-10-21 17:06:03 DTC Client socket (7) | Closed. | 2018-10-21 17:06:03 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:06 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:06 Rithmic Trading | Disconnected. | 2018-10-21 17:06:07 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:07 Rithmic Trading | Port for executable: 50222 | 2018-10-21 17:06:09 Listening socket (964). Port 50222 | Closed. | 2018-10-21 17:06:09 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:09 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50222. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:09 Custom studies file does not exist: C:\SierraChartE2T\Data\ChandelierStop_64.dll | 2018-10-21 17:06:09 Custom studies file does not exist: C:\SierraChartE2T\Data\ChandelierStop_64.dll | 2018-10-21 17:06:13 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:13 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50222 | 2018-10-21 17:06:13 DTC Client socket (8) | Creating socket. | 2018-10-21 17:06:13 DTC Client socket (8) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:13 DTC Client socket (8) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:14 * DTC Client socket (8) | Initiating close of socket by core. | 2018-10-21 17:06:14 DTC Client socket (8) | Closed. | 2018-10-21 17:06:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:14 Rithmic Trading | Disconnected. | 2018-10-21 17:06:14 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:14 Rithmic Trading | Port for executable: 50224 | 2018-10-21 17:06:16 Listening socket (1052). Port 50224 | Closed. | 2018-10-21 17:06:16 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:16 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50224. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:16 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:18 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50224 | 2018-10-21 17:06:18 DTC Client socket (9) | Creating socket. | 2018-10-21 17:06:18 DTC Client socket (9) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:18 DTC Client socket (9) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:19 * DTC Client socket (9) | Initiating close of socket by core. | 2018-10-21 17:06:19 DTC Client socket (9) | Closed. | 2018-10-21 17:06:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:19 Rithmic Trading | Disconnected. | 2018-10-21 17:06:19 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:19 Rithmic Trading | Port for executable: 50226 | 2018-10-21 17:06:21 Listening socket (268). Port 50226 | Closed. | 2018-10-21 17:06:21 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:21 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50226. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:21 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:23 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50226 | 2018-10-21 17:06:23 DTC Client socket (10) | Creating socket. | 2018-10-21 17:06:23 DTC Client socket (10) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:23 DTC Client socket (10) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:24 * DTC Client socket (10) | Initiating close of socket by core. | 2018-10-21 17:06:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:24 DTC Client socket (10) | Closed. | 2018-10-21 17:06:24 Rithmic Trading | Disconnected. | 2018-10-21 17:06:24 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:24 Rithmic Trading | Port for executable: 50228 | 2018-10-21 17:06:26 Listening socket (428). Port 50228 | Closed. | 2018-10-21 17:06:26 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:26 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50228. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:26 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:28 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50228 | 2018-10-21 17:06:28 DTC Client socket (11) | Creating socket. | 2018-10-21 17:06:28 DTC Client socket (11) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:28 DTC Client socket (11) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:29 * DTC Client socket (11) | Initiating close of socket by core. | 2018-10-21 17:06:29 DTC Client socket (11) | Closed. | 2018-10-21 17:06:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:29 Rithmic Trading | Disconnected. | 2018-10-21 17:06:29 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:29 Rithmic Trading | Port for executable: 50230 | 2018-10-21 17:06:31 Listening socket (268). Port 50230 | Closed. | 2018-10-21 17:06:31 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:31 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50230. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:31 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:33 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50230 | 2018-10-21 17:06:33 DTC Client socket (12) | Creating socket. | 2018-10-21 17:06:33 DTC Client socket (12) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:33 DTC Client socket (12) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:34 * DTC Client socket (12) | Initiating close of socket by core. | 2018-10-21 17:06:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:34 DTC Client socket (12) | Closed. | 2018-10-21 17:06:34 Rithmic Trading | Disconnected. | 2018-10-21 17:06:34 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:34 Rithmic Trading | Port for executable: 50232 | 2018-10-21 17:06:36 Listening socket (428). Port 50232 | Closed. | 2018-10-21 17:06:36 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:36 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50232. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:36 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:38 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50232 | 2018-10-21 17:06:38 DTC Client socket (13) | Creating socket. | 2018-10-21 17:06:38 DTC Client socket (13) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:38 DTC Client socket (13) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:39 * DTC Client socket (13) | Initiating close of socket by core. | 2018-10-21 17:06:39 DTC Client socket (13) | Closed. | 2018-10-21 17:06:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:39 Rithmic Trading | Disconnected. | 2018-10-21 17:06:39 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:39 Rithmic Trading | Port for executable: 50234 | 2018-10-21 17:06:41 Listening socket (268). Port 50234 | Closed. | 2018-10-21 17:06:41 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:41 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50234. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:41 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:43 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50234 | 2018-10-21 17:06:43 DTC Client socket (14) | Creating socket. | 2018-10-21 17:06:43 DTC Client socket (14) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:43 DTC Client socket (14) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:44 * DTC Client socket (14) | Initiating close of socket by core. | 2018-10-21 17:06:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:44 DTC Client socket (14) | Closed. | 2018-10-21 17:06:44 Rithmic Trading | Disconnected. | 2018-10-21 17:06:44 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:44 Rithmic Trading | Port for executable: 50236 | 2018-10-21 17:06:46 Listening socket (428). Port 50236 | Closed. | 2018-10-21 17:06:46 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:46 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50236. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:46 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:48 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50236 | 2018-10-21 17:06:48 DTC Client socket (15) | Creating socket. | 2018-10-21 17:06:48 DTC Client socket (15) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:48 DTC Client socket (15) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:49 * DTC Client socket (15) | Initiating close of socket by core. | 2018-10-21 17:06:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:49 DTC Client socket (15) | Closed. | 2018-10-21 17:06:49 Rithmic Trading | Disconnected. | 2018-10-21 17:06:49 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:49 Rithmic Trading | Port for executable: 50238 | 2018-10-21 17:06:51 Listening socket (448). Port 50238 | Closed. | 2018-10-21 17:06:51 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:51 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50238. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:51 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:53 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50238 | 2018-10-21 17:06:53 DTC Client socket (17) | Creating socket. | 2018-10-21 17:06:53 DTC Client socket (17) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:53 DTC Client socket (17) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:54 * DTC Client socket (17) | Initiating close of socket by core. | 2018-10-21 17:06:54 DTC Client socket (17) | Closed. | 2018-10-21 17:06:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:54 Rithmic Trading | Disconnected. | 2018-10-21 17:06:54 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:54 Rithmic Trading | Port for executable: 50241 | 2018-10-21 17:06:56 Listening socket (428). Port 50241 | Closed. | 2018-10-21 17:06:56 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:06:56 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50241. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:06:56 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:06:58 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50241 | 2018-10-21 17:06:58 DTC Client socket (18) | Creating socket. | 2018-10-21 17:06:58 DTC Client socket (18) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:06:58 DTC Client socket (18) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:06:59 * DTC Client socket (18) | Initiating close of socket by core. | 2018-10-21 17:06:59 DTC Client socket (18) | Closed. | 2018-10-21 17:06:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:06:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:59 Rithmic Trading | Disconnected. | 2018-10-21 17:06:59 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:06:59 Rithmic Trading | Port for executable: 50243 | 2018-10-21 17:07:02 Listening socket (456). Port 50243 | Closed. | 2018-10-21 17:07:02 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:02 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50243. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:02 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50243 | 2018-10-21 17:07:04 DTC Client socket (19) | Creating socket. | 2018-10-21 17:07:04 DTC Client socket (19) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:04 DTC Client socket (19) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:05 * DTC Client socket (19) | Initiating close of socket by core. | 2018-10-21 17:07:05 DTC Client socket (19) | Closed. | 2018-10-21 17:07:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:05 Rithmic Trading | Disconnected. | 2018-10-21 17:07:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:05 Rithmic Trading | Port for executable: 50252 | 2018-10-21 17:07:07 Listening socket (716). Port 50252 | Closed. | 2018-10-21 17:07:07 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:07 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50252. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:07 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50252 | 2018-10-21 17:07:09 DTC Client socket (20) | Creating socket. | 2018-10-21 17:07:09 DTC Client socket (20) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:09 DTC Client socket (20) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:10 * DTC Client socket (20) | Initiating close of socket by core. | 2018-10-21 17:07:10 DTC Client socket (20) | Closed. | 2018-10-21 17:07:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:10 Rithmic Trading | Disconnected. | 2018-10-21 17:07:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:10 Rithmic Trading | Port for executable: 50287 | 2018-10-21 17:07:12 Listening socket (456). Port 50287 | Closed. | 2018-10-21 17:07:12 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:12 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50287. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:12 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:14 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50287 | 2018-10-21 17:07:14 DTC Client socket (21) | Creating socket. | 2018-10-21 17:07:14 DTC Client socket (21) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:14 DTC Client socket (21) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:15 * DTC Client socket (21) | Initiating close of socket by core. | 2018-10-21 17:07:15 DTC Client socket (21) | Closed. | 2018-10-21 17:07:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:15 Rithmic Trading | Disconnected. | 2018-10-21 17:07:15 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:15 Rithmic Trading | Port for executable: 50305 | 2018-10-21 17:07:17 Listening socket (716). Port 50305 | Closed. | 2018-10-21 17:07:17 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:17 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50305. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:17 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:19 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50305 | 2018-10-21 17:07:19 DTC Client socket (22) | Creating socket. | 2018-10-21 17:07:19 DTC Client socket (22) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:19 DTC Client socket (22) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:20 * DTC Client socket (22) | Initiating close of socket by core. | 2018-10-21 17:07:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:20 DTC Client socket (22) | Closed. | 2018-10-21 17:07:20 Rithmic Trading | Disconnected. | 2018-10-21 17:07:20 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:20 Rithmic Trading | Port for executable: 50312 | 2018-10-21 17:07:22 Listening socket (456). Port 50312 | Closed. | 2018-10-21 17:07:22 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:22 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50312. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:22 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:24 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50312 | 2018-10-21 17:07:24 DTC Client socket (23) | Creating socket. | 2018-10-21 17:07:24 DTC Client socket (23) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:24 DTC Client socket (23) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:25 * DTC Client socket (23) | Initiating close of socket by core. | 2018-10-21 17:07:25 DTC Client socket (23) | Closed. | 2018-10-21 17:07:25 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:25 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:25 Rithmic Trading | Disconnected. | 2018-10-21 17:07:25 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:25 Rithmic Trading | Port for executable: 50316 | 2018-10-21 17:07:27 Listening socket (716). Port 50316 | Closed. | 2018-10-21 17:07:27 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:27 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50316. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:27 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:29 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50316 | 2018-10-21 17:07:29 DTC Client socket (24) | Creating socket. | 2018-10-21 17:07:29 DTC Client socket (24) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:29 DTC Client socket (24) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:30 * DTC Client socket (24) | Initiating close of socket by core. | 2018-10-21 17:07:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:30 DTC Client socket (24) | Closed. | 2018-10-21 17:07:30 Rithmic Trading | Disconnected. | 2018-10-21 17:07:30 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:30 Rithmic Trading | Port for executable: 50319 | 2018-10-21 17:07:32 Listening socket (448). Port 50319 | Closed. | 2018-10-21 17:07:32 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:32 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50319. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:32 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:34 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50319 | 2018-10-21 17:07:34 DTC Client socket (25) | Creating socket. | 2018-10-21 17:07:34 DTC Client socket (25) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:34 DTC Client socket (25) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:35 * DTC Client socket (25) | Initiating close of socket by core. | 2018-10-21 17:07:35 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:35 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:35 DTC Client socket (25) | Closed. | 2018-10-21 17:07:35 Rithmic Trading | Disconnected. | 2018-10-21 17:07:35 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:35 Rithmic Trading | Port for executable: 50322 | 2018-10-21 17:07:37 Listening socket (716). Port 50322 | Closed. | 2018-10-21 17:07:37 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:37 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50322. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:37 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:39 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50322 | 2018-10-21 17:07:39 DTC Client socket (26) | Creating socket. | 2018-10-21 17:07:39 DTC Client socket (26) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:39 DTC Client socket (26) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:40 * DTC Client socket (26) | Initiating close of socket by core. | 2018-10-21 17:07:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:40 DTC Client socket (26) | Closed. | 2018-10-21 17:07:40 Rithmic Trading | Disconnected. | 2018-10-21 17:07:40 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:40 Rithmic Trading | Port for executable: 50324 | 2018-10-21 17:07:42 Listening socket (448). Port 50324 | Closed. | 2018-10-21 17:07:42 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:42 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50324. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:42 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:44 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50324 | 2018-10-21 17:07:44 DTC Client socket (27) | Creating socket. | 2018-10-21 17:07:44 DTC Client socket (27) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:44 DTC Client socket (27) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:45 * DTC Client socket (27) | Initiating close of socket by core. | 2018-10-21 17:07:45 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:45 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:45 DTC Client socket (27) | Closed. | 2018-10-21 17:07:45 Rithmic Trading | Disconnected. | 2018-10-21 17:07:45 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:45 Rithmic Trading | Port for executable: 50326 | 2018-10-21 17:07:47 Listening socket (428). Port 50326 | Closed. | 2018-10-21 17:07:47 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:47 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50326. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:47 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:49 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50326 | 2018-10-21 17:07:49 DTC Client socket (28) | Creating socket. | 2018-10-21 17:07:49 DTC Client socket (28) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:49 DTC Client socket (28) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:50 * DTC Client socket (28) | Initiating close of socket by core. | 2018-10-21 17:07:50 DTC Client socket (28) | Closed. | 2018-10-21 17:07:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:50 Rithmic Trading | Disconnected. | 2018-10-21 17:07:50 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:50 Rithmic Trading | Port for executable: 50328 | 2018-10-21 17:07:52 Listening socket (448). Port 50328 | Closed. | 2018-10-21 17:07:52 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:52 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50328. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:52 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:54 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50328 | 2018-10-21 17:07:54 DTC Client socket (30) | Creating socket. | 2018-10-21 17:07:54 DTC Client socket (30) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:54 DTC Client socket (30) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:07:55 * DTC Client socket (30) | Initiating close of socket by core. | 2018-10-21 17:07:55 DTC Client socket (30) | Closed. | 2018-10-21 17:07:55 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:07:55 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:55 Rithmic Trading | Disconnected. | 2018-10-21 17:07:55 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:07:55 Rithmic Trading | Port for executable: 50331 | 2018-10-21 17:07:57 Listening socket (428). Port 50331 | Closed. | 2018-10-21 17:07:57 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:07:57 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50331. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:07:57 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:07:59 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50331 | 2018-10-21 17:07:59 DTC Client socket (31) | Creating socket. | 2018-10-21 17:07:59 DTC Client socket (31) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:07:59 DTC Client socket (31) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:00 * DTC Client socket (31) | Initiating close of socket by core. | 2018-10-21 17:08:00 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:00 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:00 DTC Client socket (31) | Closed. | 2018-10-21 17:08:00 Rithmic Trading | Disconnected. | 2018-10-21 17:08:00 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:00 Rithmic Trading | Port for executable: 50353 | 2018-10-21 17:08:02 Listening socket (732). Port 50353 | Closed. | 2018-10-21 17:08:02 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:02 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50353. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:02 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:04 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50353 | 2018-10-21 17:08:04 DTC Client socket (32) | Creating socket. | 2018-10-21 17:08:04 DTC Client socket (32) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:04 DTC Client socket (32) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:05 * DTC Client socket (32) | Initiating close of socket by core. | 2018-10-21 17:08:05 DTC Client socket (32) | Closed. | 2018-10-21 17:08:05 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:05 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:05 Rithmic Trading | Disconnected. | 2018-10-21 17:08:05 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:05 Rithmic Trading | Port for executable: 50355 | 2018-10-21 17:08:07 Listening socket (456). Port 50355 | Closed. | 2018-10-21 17:08:07 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:07 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50355. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:07 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:09 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50355 | 2018-10-21 17:08:09 DTC Client socket (33) | Creating socket. | 2018-10-21 17:08:09 DTC Client socket (33) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:09 DTC Client socket (33) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:10 * DTC Client socket (33) | Initiating close of socket by core. | 2018-10-21 17:08:10 DTC Client socket (33) | Closed. | 2018-10-21 17:08:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:10 Rithmic Trading | Disconnected. | 2018-10-21 17:08:10 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:10 Rithmic Trading | Port for executable: 50358 | 2018-10-21 17:08:12 Listening socket (732). Port 50358 | Closed. | 2018-10-21 17:08:12 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:12 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50358. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:12 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:14 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50358 | 2018-10-21 17:08:14 DTC Client socket (34) | Creating socket. | 2018-10-21 17:08:14 DTC Client socket (34) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:14 DTC Client socket (34) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:16 * DTC Client socket (34) | Initiating close of socket by core. | 2018-10-21 17:08:16 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:16 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:16 DTC Client socket (34) | Closed. | 2018-10-21 17:08:16 Rithmic Trading | Disconnected. | 2018-10-21 17:08:16 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:16 Rithmic Trading | Port for executable: 50366 | 2018-10-21 17:08:18 Listening socket (456). Port 50366 | Closed. | 2018-10-21 17:08:18 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:18 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50366. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:18 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:20 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50366 | 2018-10-21 17:08:20 DTC Client socket (35) | Creating socket. | 2018-10-21 17:08:20 DTC Client socket (35) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:20 DTC Client socket (35) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:21 * DTC Client socket (35) | Initiating close of socket by core. | 2018-10-21 17:08:21 DTC Client socket (35) | Closed. | 2018-10-21 17:08:21 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:21 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:21 Rithmic Trading | Disconnected. | 2018-10-21 17:08:21 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:21 Rithmic Trading | Port for executable: 50370 | 2018-10-21 17:08:23 Listening socket (732). Port 50370 | Closed. | 2018-10-21 17:08:23 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:23 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50370. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:23 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:25 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50370 | 2018-10-21 17:08:25 DTC Client socket (36) | Creating socket. | 2018-10-21 17:08:25 DTC Client socket (36) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:25 DTC Client socket (36) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:26 * DTC Client socket (36) | Initiating close of socket by core. | 2018-10-21 17:08:26 DTC Client socket (36) | Closed. | 2018-10-21 17:08:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:26 Rithmic Trading | Disconnected. | 2018-10-21 17:08:26 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:26 Rithmic Trading | Port for executable: 50372 | 2018-10-21 17:08:28 Listening socket (428). Port 50372 | Closed. | 2018-10-21 17:08:28 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:28 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50372. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:28 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:30 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50372 | 2018-10-21 17:08:30 DTC Client socket (37) | Creating socket. | 2018-10-21 17:08:30 DTC Client socket (37) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:30 DTC Client socket (37) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:31 * DTC Client socket (37) | Initiating close of socket by core. | 2018-10-21 17:08:31 DTC Client socket (37) | Closed. | 2018-10-21 17:08:31 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:31 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:31 Rithmic Trading | Disconnected. | 2018-10-21 17:08:31 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:31 Rithmic Trading | Port for executable: 50374 | 2018-10-21 17:08:33 Listening socket (448). Port 50374 | Closed. | 2018-10-21 17:08:33 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:33 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50374. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:33 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:35 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50374 | 2018-10-21 17:08:35 DTC Client socket (38) | Creating socket. | 2018-10-21 17:08:35 DTC Client socket (38) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:35 DTC Client socket (38) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:36 * DTC Client socket (38) | Initiating close of socket by core. | 2018-10-21 17:08:36 DTC Client socket (38) | Closed. | 2018-10-21 17:08:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:36 Rithmic Trading | Disconnected. | 2018-10-21 17:08:36 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:36 Rithmic Trading | Port for executable: 50376 | 2018-10-21 17:08:38 Listening socket (428). Port 50376 | Closed. | 2018-10-21 17:08:38 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:38 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50376. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:38 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:40 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50376 | 2018-10-21 17:08:40 DTC Client socket (39) | Creating socket. | 2018-10-21 17:08:40 DTC Client socket (39) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:40 DTC Client socket (39) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:41 * DTC Client socket (39) | Initiating close of socket by core. | 2018-10-21 17:08:41 DTC Client socket (39) | Closed. | 2018-10-21 17:08:41 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:41 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:41 Rithmic Trading | Disconnected. | 2018-10-21 17:08:41 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:41 Rithmic Trading | Port for executable: 50378 | 2018-10-21 17:08:43 Listening socket (448). Port 50378 | Closed. | 2018-10-21 17:08:43 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:43 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50378. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:43 Rithmic Trading | Bridge process is not running! | 2018-10-21 17:08:45 Rithmic Trading | Connecting to the server 127.0.0.1. Port 50378 | 2018-10-21 17:08:45 DTC Client socket (40) | Creating socket. | 2018-10-21 17:08:45 DTC Client socket (40) | Connecting to IP: 127.0.0.1. | 2018-10-21 17:08:45 DTC Client socket (40) | Connect event error. Windows error code 10061: No connection could be made because the target machine actively refused it. | 2018-10-21 17:08:46 * DTC Client socket (40) | Initiating close of socket by core. | 2018-10-21 17:08:46 DTC Client socket (40) | Closed. | 2018-10-21 17:08:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-10-21 17:08:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:46 Rithmic Trading | Disconnected. | 2018-10-21 17:08:46 Will reconnect to the server in 2.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-10-21 17:08:46 Rithmic Trading | Port for executable: 50380 | 2018-10-21 17:08:48 Listening socket (428). Port 50380 | Closed. | 2018-10-21 17:08:48 Rithmic Trading | Starting server: C:\SierraChartE2T\Rim\DTCBridge.exe | 2018-10-21 17:08:48 Created process C:\SierraChartE2T\Rim\DTCBridge.exe. Parameters: /Port:50380. Current folder: C:\SierraChartE2T\Rim | 2018-10-21 17:08:48 |
[2018-10-22 03:11:44] |
Could you select File >> Disconnect. And run this program manually from the folder it is located in: C:\SierraChartE2T\Rim\DTCBridge.exe Tell us what you see. You should see a message box that says the port number needs to be specified. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-22 11:47:24] |
Yes, A message comes up saying "Port number not specified. Will exit.
[2018-10-22 17:18:42] |
Okay good that means the bridge program can be run. So not clear what the problem is. Restart Sierra Chart and try connecting again with File >> Connect to Data Feed. Also for the record, we do not regard the connectivity to Rithmic as a proper solution. Rithmic is not favored by us. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
