Date/Time: Mon, 20 May 2024 20:11:55 +0000
Sierra very slow to connect
View Count: 865
[2018-10-15 18:40:12] |
User657627 - Posts: 3 |
Hi, Upon start-up, Sierra always has taken 30-60 seconds to completely load and connect. After a Windows 10 update last week, it now takes 25 - 30 minutes to load and connect. Once it connects, everything is fine. Fix ??? Sierra on my other Windows 7 system loads and connects just fine. Thanks, Nick |
[2018-10-15 18:47:16] |
Refer to help topic 30: High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
