Date/Time: Sun, 28 Apr 2024 17:29:48 +0000
Text display for study malfunction
View Count: 640
[2018-10-13 20:38:12] |
User93534 - Posts: 30 |
Hello, I've had an issue with the text display for study operation. The "prefix text for display value" input is stuck to a previously entered text from another chart I'd saved as default and whenever I try to change it to new text it reverts to the old text that I don't want. This doesn't effect the actual performance but it is super annoying as I use this study for several different things and they're all labeled with the same prefix and I can't change it nor make it go away. I imagine it is a glitch of some kind as I've attempted changing every input to no avail. |
[2018-10-14 19:40:06] |
If you saved defaults for this study a long while ago like probably more than a year ago, and at that time the prefix text was specified and specified using the older Input it used, we can understand the reason for this scenario. If you reset the study back to default, and remove it and add it again, the problem should go away. In any case we are solving this in the next release. We understand the reason for the underlying problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
