Date/Time: Sun, 05 May 2024 09:46:40 +0000
Donchian Channel
View Count: 1051
[2018-10-09 17:51:30] |
AE16 - Posts: 31 |
Hi guys, wondering if you could help with my query on the DC. It seems to be that price is breaking outside the channel even when I have it set to using the high and low. However, on other trading platforms DC cannot be broken, price just pushes the width higher. Thanks |
[2018-10-09 20:41:49] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-12 16:37:05] |
AE16 - Posts: 31 |
http://www.sierrachart.com/image.php?Image=1539362198427.png
[2018-10-12 19:20:55] |
Set the Displacement setting for the Subgraphs of this study to 0: Chart Studies: Subgraphs Tab >> Displacement Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
