Date/Time: Mon, 06 May 2024 04:13:31 +0000
Study Overlay of Volume Area Lines from 4min to DOM error
View Count: 1036
[2018-10-09 08:14:56] |
User360283 - Posts: 440 |
I have a Study Overlay of Volume Area Lines from 4min chart to the Stand Alone DOM. The Point of Control is correct. But both the Hi and Lo lines are off the grid. They appear incorrectly in the top and bottom DOM header and footer. Help please. Thanks |
sierra 1.PNG / V - Attached On 2018-10-09 08:13:51 UTC - Size: 50.61 KB - 258 views Attachment Deleted. |
[2018-10-09 14:32:05] |
In what way are they not correct? Are they not at the right price level?
[2018-10-09 16:55:40] |
No prices are visible. Only the Line Short Names and they appear in the Header and Footer rows. Please see encl. pic. |
sierra 1.PNG / V - Attached On 2018-10-09 16:55:06 UTC - Size: 50.61 KB - 228 views |
[2018-10-10 04:15:19] |
Looks like you will need to compress the scale to see those values. Refer to: The Chart DOM Scale Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-10 04:44:20] |
Auto scaling the DOM results are unusable. see encl. pic. I have tried many manual Constant Range cale setting. All result in the Vol Hi and Lo unreadable in the DOM header and footer. Scale Independent same problem. Looks like a bug fix is needed to me. Help Thanks |
sierra4.PNG / V - Attached On 2018-10-10 04:43:52 UTC - Size: 44.8 KB - 230 views |
[2018-10-10 05:01:26] |
Looking at my 4 minute chart the Vol Hi and Lo are withing the range of the DOM. They should appear but not in the Header and Footer. Thanks
[2018-10-10 05:20:23] |
Calcification. The Vol Hi and Lo LINES are appearing correctly on the DOM. The HI and Lo Line Labels are appearing in the header and footer. Thanks |
[2018-10-10 23:03:01] |
From our perspective we are just not understanding this at all. We cannot possibly understand this unless we get the Chartbook, and understand precisely what you are doing and what you want to see. If you want us to look at this, we will look at it for 50 USD per hour. We are certain there is no bug here.
