Date/Time: Mon, 06 May 2024 02:13:34 +0000
serious crosshair / click and control bar issue in build 1817/1818
View Count: 565
[2018-10-08 06:44:33] |
Cavalry3162 - Posts: 523 |
Hello SC, - cursor and crosshair are misaligned and it reacts to clicks at the wrong spot - controlbar overlays chart / dom window see screenshot |
2018-10-08_02-37-10.png / V - Attached On 2018-10-08 06:44:25 UTC - Size: 247.81 KB - 219 views |
[2018-10-08 07:16:12] |
We are reverting back to 1815. There was work done related to this, that had not undergone review.
[2018-10-08 09:58:21] |
User816220 - Posts: 80 |
This may be related; it started after I updated to 1818. Reverting to 1815 fixed it. When I right-click on the buy or sell column of the trade dom, I get the right-click menu for the price column (i.e. the scale menu) instead of entering an order. Left-clicking enters the order as expected. The chart dom is unaffected. |
[2018-10-08 10:09:59] |
Yes it probably is related. It is resolved in version 1819.
