Date/Time: Mon, 29 Apr 2024 21:51:35 +0000
Highlight min max on numbers bars
View Count: 1877
[2018-10-06 19:29:42] |
greg9 - Posts: 9 |
I'm following the directions here Numbers Bars: Highlight Maximum/Minimum Value Based On However my Highlight Maximum Value In only has column 1, 2, 3.. . . Not the choices listed on the page. Something I'm doing wrong? What i'm looking to do is take a current numbers bar, maybe it has 15 price levels, I want to highlight the large order quantity bars, maybe there are 2 or 3 that highlight on the bar. I see that is is possible but can't get it to work. |
[2018-10-06 23:25:05] |
That input is different. It is called Highlight Maximum/Minimum Value Based On.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-10-06 23:30:48
[2020-12-28 13:33:56] |
User448728 - Posts: 14 |
Dear SC Team Is there a way to highlight only the maximum values for example every 10 Minutes? Please have a look at the attached screenshots. Kind regards |
ESH21_FUT_CME [C][M] Point & Figure 2-1 #7 2020-12-28 13_.png / V - Attached On 2020-12-28 13:26:21 UTC - Size: 73.25 KB - 243 views ESH21_FUT_CME [C][M] Point & Figure 2-1 #7 2020-12-28 13_.png / V - Attached On 2020-12-28 13:26:29 UTC - Size: 85.92 KB - 224 views settings numbers bars.PNG / V - Attached On 2020-12-28 13:26:44 UTC - Size: 53.88 KB - 213 views |
