Date/Time: Mon, 06 May 2024 04:29:51 +0000
Senkou SPAN A&B
View Count: 560
[2018-10-05 16:06:01] |
User38606 - Posts: 80 |
Quick question: Why can't I see the price bars through Senkou Span A&B study? I placed it on the chart and it covers the chart bars. How can I turn bars visible through Senkou Span A&B study? Thxs
[2018-10-05 16:11:15] |
John - SC Support - Posts: 31379 |
First, select the option for Draw Study Underneath Main Price Graph on the main Settings and Inputs window for the Senkou A&B study. Refer to the documentation here for this: Chart Studies: Settings and Inputs Tab >> Draw Study Underneath Main Price Graph (in the same Chart Region) Second, you can change the Subgraphs from Fill Top and Fill Bottom to Transparent Fill Top and Transparent Fill Bottom and then use the Transparency level on the Subgraphs Tab of Study Settings window. Refer to the documentation here for this: Chart Studies: Subgraphs Tab >> Draw Style And also here: Chart Studies: Subgraphs Tab >> Transparency Level for Fill Styles For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
