Date/Time: Sun, 28 Apr 2024 09:48:53 +0000
Volume Chart bar problem
View Count: 535
[2018-10-03 01:10:12] |
AC95949 - Posts: 1 |
Occasionally a bar will open multiple ticks away from close of previous bar. With a thick market like ES I would assume this would happen very very infrequently. Seems to happen when there is a burst of volume towards end of bar. Can this be looked into? http://www.sierrachart.com/image.php?Image=1538528686553.png Date Time Of Last Edit: 2018-10-03 01:27:35
[2018-10-03 01:47:08] |
There are only two things we can say in regards to this: Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration If that does not resolve the issue you need to use the Sierra Chart exchange data feed: Sierra Chart Exchange Data Feed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
