Date/Time: Sun, 05 May 2024 11:23:24 +0000
Mis-aligned charts
View Count: 504
[2018-09-28 04:26:29] |
a Gem Tree - Posts: 60 |
Hey SC. I'm getting charts which are changing length (and therefor shape), depending on which time-frame bar I choose. I looked a little bit closer, and I noticed that some days have bars which should not exist - bars which start and end at the same closing time. I'm not sure if this is an SC issue, or a data provider issue. The charts I am looking at, are SB(H19), but I'm pretty sure I've had this problem with other commodities as well. The time period in question (the only one I've noticed so far), is a bar which starts and ends at 1pm (closing time for Sugar). Further corroborating the idea is that this 1PM bar has no volume to it. Any ideas as to what's going wrong? |
Sugar additional bar error.png / V - Attached On 2018-09-28 04:25:41 UTC - Size: 35.53 KB - 212 views Private File |
[2018-09-28 18:07:52] |
Adjust the Session Times in the chart to filter out data which is outside of the normal trading hours for that particular commodity. Refer to: Chart Session Times That particular bar with low volume you see is actual data from the ICE exchange. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
