Date/Time: Mon, 06 May 2024 17:47:03 +0000
Ask/Bid Volume Difference Bars
View Count: 1075
[2018-09-27 17:13:14] |
User311951 - Posts: 31 |
Hi, Is it possible to have the Ask/Bid Volume Difference Bars thickness different to the thickness of the regular candlesticks in the same chart? Regards, Talai |
[2018-09-27 19:26:47] |
John - SC Support - Posts: 31401 |
To change the thickness of the Ask/Bid Volume Difference Bars, you need to adjust the Width/Size setting for each subgraph. You will find the information on this setting here: Chart Studies: Subgraphs Tab >> Line Width
[2018-09-28 03:33:46] |
We have updated the documentation here in regards to this: Chart Studies: Subgraphs Tab >> Line Width This has been added: In the case of when changing the width of a particular element of a price type bar, then it is necessary to disable the Use Chart Graphics Settings for Subgraph Colors option on the Subgraphs tab for the width to go into effect. Otherwise, it will be reverted back to the global setting for the particular Price Graph Type.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-28 03:34:08
[2021-03-03 05:33:51] |
Ttarama2013 - Posts: 2 |
Hi, Is it possible to convert Ask/Bid volume difference bars into histogram and calculate the numbers as percentage rather than raw contracts traded as in KISS OF of Ninjatrader |
KISS-NINJA.PNG / V - Attached On 2021-03-03 05:32:51 UTC - Size: 135.56 KB - 400 views |
[2021-03-03 06:19:43] |
You can modify the source code and do what you require. Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2021-03-03 07:22:35] |
User311344 - Posts: 136 |
Well few seconds job with Spreadsheet Formula study
[2021-03-03 07:38:45] |
Thanks Man. However, i have no idea with codes
[2021-03-03 08:33:06] |
Send me more details how you want to calculate that, here or in pm and I will give you the formula
