Date/Time: Sat, 18 May 2024 08:23:51 +0000
Why are my trend lines curved after upgrading to 1809
View Count: 851
[2018-09-27 11:32:17] |
auggie - Posts: 45 |
see attached image
Capture.JPG / V - Attached On 2018-09-27 11:31:17 UTC - Size: 38.35 KB - 315 views Attachment Deleted. |
[2018-09-28 03:47:52] |
This is because this is a logarithmic scale. Lines are now drawn properly on a logarithmic scale. More details can be found here: Problem with Ray and Parallel Ray on Log Scale | Post: 156745 Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-28 08:55:40] |
Please allow a setting for the user to specify straight or curved. I require straight for my work.
[2018-09-28 10:08:13] |
Yes we can do that. Should be out in about a week.
[2019-06-27 19:54:14] |
samual sprat - Posts: 343 |
Hi. Did this get fixed in the end? I've set my chart to log and on higher time-frames like daily/weekly etc the rays are all bendy and the anchor points don't match where the line is drawn. This affects ray, line, extended line, zigzags, pitchfork(s) Also in log scale it's very difficult when chart is zoomed out to select the line and therefore be able to move it or duplicate it or even delete it. To replicate this you can open a daily chart in log scale and use the drawing tools mentioned I've read I've read Problem with Ray and Parallel Ray on Log Scale | Post: 156745 and strangely this bending issue DOESN'T affect parallel rays so I'm hoping you can rectify this for the other tools Thanks S |
[2019-06-28 14:47:41] |
There is a global setting to change how the lines are drawn on a logarithmic scale. Refer to the following: Chart Drawing Tools: Support Curved Lines On Logarithmic Scale (Global Settings >> Tool Settings >> General >> Other) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-06-28 15:20:54] |
Oh wow that's amazing. I wish i'd asked sooner. Is there a way to make the anchor points match up btw?
[2019-06-28 15:33:05] |
We do not understand what you mean about making the Anchor points match up. Can you explain further, or include a screenshot?
