Date/Time: Wed, 01 May 2024 14:21:11 +0000
TD Ameritrade connection Problem
View Count: 1345
[2018-09-26 04:42:36] |
User821671 - Posts: 10 |
Apple Bootcamp Windows 7 32-bit. SC ran perfect for years. After install ver. 1809 TD Ameritrade connects / disconnects endlessly. Reinstalled previous version but problem persist. Web search no help. Edit - Screen Images no help. Will send Log on request.
[2018-09-26 05:04:44] |
We see no problem at all from our side. This looks like it is a TD Ameritrade server issue. We will have to contact them. Please understand, that we do not expect this to get resolved quickly. We really do not even know who to contact at TD Ameritrade about this. Be prepared to wait a few days. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-26 11:41:00] |
jomanos - Posts: 27 |
Can confirm that I have the same connect/disconnect problem with my TD Ameritrade feed. It was working fine yesterday. And it would appear it is a server side issue with TDA. Note that TDA did a system wide upgrade over the weekend. So, this data feed problem may be a residual effect of the upgrade? Maybe. Update: I spoke to tech support at TDA and they provided me with the email address for their API team. apidev@tdameritrade.com The tech support rep did say the API support team has grown. So, hopefully this problem can get resolved quickly. Update No. 2: I sent them an email explaining the problem and attached a copy of the message log from Sierra Chart. Hopefully, they'll respond today. Date Time Of Last Edit: 2018-09-26 12:08:51
[2018-09-26 12:49:58] |
User976133 - Posts: 38 |
Same problem here. It started on Saturday, got better Sunday through yesterday. Broke again today. Message sent to TD Ameritrade also. Hoping for a speedy resolution. |
[2018-09-26 18:51:50] |
Sierra Chart - Max - Posts: 5597 |
Can you try the following. Go to "File >> Data/Trade Service Settings". Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com Reconnect the feed by selecting, File >> Disconnect and File >> Connect To Data Feed. Let us know if this quick fix resolves the issue. Sierra Chart Support Date Time Of Last Edit: 2018-09-26 18:53:28
[2018-09-26 19:00:32] |
User701754 - Posts: 4 |
Can you try the following. Go to "File >> Data/Trade Service Settings". Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com Reconnect the feed by selecting, File >> Disconnect and File >> Connect To Data Feed. Let us know if this quick fix resolves the issue. It Didn't work for me |
[2018-09-26 19:07:45] |
Did as you instructed. And it did work for me. I have attached the message log after the reconnect and opening a chart for an equity symbol. Many thanks for the help! |
data_feed_override_20180926.txt - Attached On 2018-09-26 19:06:40 UTC - Size: 55 KB - 222 views |
[2018-09-26 19:09:26] |
IT DOES WORK!
[2018-09-26 19:15:14] |
Works here too Thanks! |
[2018-09-27 20:03:25] |
What an easy Fix... Thanks Go to "File >> Data/Trade Service Settings". Set Streamer Address Override to: streamer-ext-bin-tx.tdameritrade.com |
[2018-09-27 21:16:10] |
According to TD Ameritrade setting Streamer Address Override is no longer necessary. And we have verified that it is no longer necessary. So you should remove the Streamer Address Override. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-27 21:33:13] |
Ok. Done. Live data is working fine now. Many thanks for your efforts. |
[2018-09-28 02:29:41] |
Update: Logged back in tonight. And got the same previous connect/disconnect error messages. Had to resort back to including the override. |
[2018-09-28 02:47:09] |
Yes we noticed that as well. There is instability on the TD Ameritrade side in regards to this.
[2018-09-28 02:47:11] |
