Date/Time: Mon, 13 May 2024 03:13:59 +0000
upvol dvol spreadsheet question
View Count: 621
[2018-09-24 17:49:37] |
User90074 - Posts: 1 |
Hi I'm using spreadsheets and seem to have inconsistent data on upvol and dvol .It may be that i don't understand how they are being populated. Is there documentation describing market stats for use in spreadsheets. For Example how is last calculated on UPVOL-NYSE. If it is the addition of the trades or volume why is it not consistently increasing? |
[2018-09-24 19:55:28] |
This does not make sense. You are not going to have inconsistencies with the chart data for that symbol on a Spreadsheet. That is inherently impossible. We need to remove the Spreadsheet out of this question altogether. Look at the chart data. Do you see any issue with the chart data? And how these are calculated is explained here: Sierra Chart Market Statistics: Symbols Sierra Chart Market Statistics: Calculations and Algorithms Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-24 19:55:48
[2018-09-24 19:58:35] |
Also it does not make sense that you would see a consistent rise with this symbol. Because not all symbols are going to remain up during the day.
