Date/Time: Fri, 10 May 2024 10:05:51 +0000
The numbers indicating volume become very small after last upgrade. Can not read them.
View Count: 554
[2018-09-24 17:28:13] |
User307319 - Posts: 41 |
Dear Sierra, here is my screenshot http://www.sierrachart.com/image.php?Image=1537809509837.png Please, help - you see the micro numbers above/below candlesticks was normal size before. Please, help to adjust. Thank you. |
[2018-09-24 18:09:56] |
John - SC Support - Posts: 31509 |
There has been work done to make fonts more consistent. One of the effects of this is that the interpretation of the Width/Size setting for Subgraphs is now proper, so a setting of 1 makes it very small. Go to the study/studies that are displaying these numbers and change the Width/Size settings to a value that works for you. You will find the documentation for the Width/Size setting here: Chart Studies: Subgraphs Tab >> Line Width For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-24 19:49:55
[2018-09-25 13:29:46] |
Thank you very much, all set now.
