Date/Time: Sun, 12 May 2024 05:35:54 +0000
New update problem, Color Bar Based on Alert, Value on High/Low sizing unreadable
View Count: 874
[2018-09-23 23:45:00] |
User838535 - Posts: 1 |
The new update changed the sizing of the value on high/low style within the Color Bar Based On Alert Condition. It is so small that it is unreadable. I tried to adjust it under subgraphs but it does not get bigger with the increase in size. I rolled back to a previous update in order to see these values. Would someone please check this out? Thank you
[2018-09-24 18:57:41] |
Adjust the Width/Size of the Subgraph which controls the font size: Chart Studies: Subgraphs Tab >> Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-24 18:58:08] |
There have been changes to how the fonts are handled and this has made a change to the display of subgraphs as Text. Therefore, if the Width/Size of the Subgraph is 1, it will be very small. But, you will be able to change the Width/Size setting to a larger number and have the text resize appropriately. We have verified that this is working properly in the current version (v1811) for the Color Bar Based on Alert Condition when the Subgraph is set to Value on High or Value on Low.
