Date/Time: Thu, 02 May 2024 08:51:32 +0000
Ask Volume Bid Volume Difference Text - Font extremely small since v.1807 update
View Count: 1093
[2018-09-18 10:22:50] |
Dema - Posts: 42 |
Hi Team, The Ask Volume Bid Volume Difference Text font is extremely small since v.1807 update. I have checked the Global and Chart graphics settings, and all fonts appear "normal" size. Please see screenshot which shows the tiny Ask Volume Bid Volume Difference Text (one study paints above bar, the other duplicate below bar) vs the Numbers Bars text size. Any suggestions? Thanks in advance! Date Time Of Last Edit: 2018-09-18 10:23:20
Capture.PNG / V - Attached On 2018-09-18 10:22:24 UTC - Size: 8.93 KB - 263 views |
[2018-09-18 13:06:42] |
You need to adjust the Width/Size setting for the Subgraph of that study: Chart Studies: Subgraphs Tab >> Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-18 13:38:06] |
Ufo de Jager - Posts: 16 |
Same problem here, adjusting width/size does not help.
[2018-09-18 16:59:49] |
User657944 - Posts: 173 |
Same issue with hi/low swing I immediatly reloaded the 1803 version that works impossible to see the numbers and work size it's invisible.
[2018-09-18 18:33:34] |
Same problem here, adjusting width/size does not help. This cannot be true. Adjusting the Subgraph width will change the text size. Tell us the name of the study, the exact name, and the version you are running.The study does not display any text: Same issue with hi/low swing I immediatly reloaded the 1803 version that works impossible to see the numbers and work size it's invisible.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-18 18:34:17
[2018-09-19 11:20:16] |
The study is: "Spreadsheet System/Alert". And then the first row (subgraph) I use Draw Style "Value On Low". Picture "Sierra01.png" is version 1808_64, picture "Sierra02.png" is version 1803_64
Sierra01.PNG / V - Attached On 2018-09-19 11:14:45 UTC - Size: 42.17 KB - 295 views Sierra02.PNG / V - Attached On 2018-09-19 11:14:52 UTC - Size: 46.43 KB - 307 views Attachment Deleted. |
[2018-09-19 11:23:12] |
You just need to increase the Width/Size of that particular Subgraph. We have verified that does work properly. It does not surprise us there is a difference, you just need to adjust the size appropriately. This is all.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-19 11:26:06
[2018-09-19 11:35:37] |
I did, but only till size 3. In previous versions, that would make the text really big. I just tried 10 and now it's bigger. So the size adjustment is now the same 'method'/format as in spreadsheets and text editors. Thanks!
[2018-09-20 01:19:30] |
Dema - Posts: 42 |
Thanks team, confirming that increasing that setting (from default 1 to 10) worked perfectly.
[2018-09-20 01:57:41] |
Okay this also confirms, that there was not proper translation of that value. That is meant to be a point size converted to what is called a logical height. We did a recent review and reorganization of this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
