Date/Time: Thu, 02 May 2024 20:31:24 +0000
Swing High and Low indicator font size became small after update
View Count: 970
[2018-09-17 15:59:50] |
User644165 - Posts: 25 |
Hi All, Swing High and Low indicator font size became small after update. In the previous version it worked perfectly. How can I fix it? Thanks. http://prntscr.com/kvg85k |
[2018-09-17 17:52:51] |
Adjust it through the Subgraph Width/Size setting: Chart Studies: Subgraphs Tab >> Line Width Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
