Date/Time: Sun, 05 May 2024 05:17:11 +0000
Possible On 1 Chart? (Numbers Bars)
View Count: 1106
[2018-09-17 13:57:48] |
infpz - Posts: 826 |
1. Set the background color of column 1 in the numbers bar study to ask/bid volume split profile 2. Show the imbalances over 400% on the bid and ask side separately with a different color than black e.g bid red/ ask blue 3. Show the candle stick on the numbers bar as fully filled candle on the top or next to the the bid ask clusters. I do not believe #3 can be done, correct? |
[2018-09-17 20:13:52] |
1. Yes. 2. Yes. 3. You can display a candlestick outline around the entire numbers bar but not a portion of it. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-09-17 20:52:08] |
You have this correct. You can do 1 and 2, but not exactly 3. 1. Refer to the following: Numbers Bars: Numbers Bars Background Types and look for the section on the Ask/Bid Volume Split Profile. 2. If you want to color the numbers, then you would use the Text Coloring Based on Dominant Side AskVol BidVol Percentage and then set your Column # Percent Compare Threshold how you want and adjust the colors in the Column # Range # Up/Down Color setting. Refer to the following for each of these settings: Text Coloring Based on Dominant Side AskVol BidVol Percentage: Numbers Bars: Text Coloring Based on Dominant Side AskVol BidVol Percentage) Column # Percent Compare Threshold: Numbers Bars: Column # Percent Compare Thresholds Column # Range # Up/Down Color: Numbers Bars: Color Settings and Logic for Numbers Bars 3. A regular candlestick is not available, but items similar to it are. Refer to the following and the two sections after it for what you can display related to this: Numbers Bars: Open and Close Marker Style Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
