Date/Time: Tue, 30 Apr 2024 07:11:06 +0000
Horizontal profile for subgraph
View Count: 695
[2018-09-17 10:51:14] |
User97684 - Posts: 136 |
Hi, By moving down the subgraph border by a little bit each time i get different values for the maximum volume bar - 200k, down to 160... what setting do i need to change so that i am sure which is the correct mode value ? Thanks |
horizontal_volume_1.png / V - Attached On 2018-09-17 10:50:22 UTC - Size: 75.47 KB - 264 views horizontal_volume_2.png / V - Attached On 2018-09-17 10:50:27 UTC - Size: 79 KB - 222 views horizontal_volume_3.png / V - Attached On 2018-09-17 10:50:31 UTC - Size: 79.7 KB - 204 views |
[2018-09-17 19:21:49] |
The proper solution to this is to use the Volume by Price study instead: Volume By Price Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-17 19:22:17
[2018-09-17 19:41:05] |
Thanks, so the volume by price can be used in a subgraph ? this is what i found previously "sierra chart engineering posts: 63745 In response to post #1, Sierra Chart does have a new study Subgraph Draw Style for drawing horizontal profiles: Chart Studies: Horizontal Profile (ACSIL: DRAWSTYLE_HORIZONTAL_PROFILE) |
[2018-09-18 04:03:30] |
The answer is no and we really cannot provide any further help. If that particular Subgraph Draw Style does not work as you require it to, then do not use it.
