Date/Time: Wed, 08 May 2024 03:00:31 +0000
charts problem
View Count: 560
[2018-09-14 17:27:58] |
User666132 - Posts: 3 |
I have sant you print screen in attached file. I can login platform. I still do not have real time charts
Private File |
[2018-09-14 18:56:59] |
Refer to help topic 3.4: http://www.sierrachart.com/index.php?page=doc/helpdetails3.html#NotReceivingRealTimeDataFromDataFeed We have looked at the image you provided, you really must contact Transact support for help with the connection issue. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-14 18:57:56
