Date/Time: Sun, 19 May 2024 00:53:25 +0000
Pivot Study
View Count: 1070
[2018-09-13 14:56:03] |
Glenn Infinity - Posts: 103 |
below is from a customer, can you assist? I am looking to put Camarilla pivots on my charts. I found, using a search of Sierra, under the Pivots Points - Variable Period there are 26 formulas and Formula Type 5(Camarilla Pivot Points) is the one I am looking for. How do I get that formula on a chart? Looking to use them on 2 minute 5 minute and a renko chart and have them reset on a 24 hour basis. |
[2018-09-13 17:16:38] |
It sounds like they just need the information for how to put a study on a chart, as they know they want the Pivot Points - Variable Period study. For information on adding a study, refer to the following: Chart Studies: Adding/Modifying Chart Studies Then they need to change the Input for Formula Type to a value of 5. Refer to the following for adjusting the settings of a study: Chart Studies: Study Settings Window And finally, just for completeness, here is the link to the Pivot Points - Variable Period study: Pivot Points: Pivot Points - Variable Period Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
