Date/Time: Tue, 08 Jul 2025 10:17:23 +0000
cannot log in
View Count: 1568
[2013-10-24 00:25:41]
User67522 - Posts: 6
This is extremely frustrating
Tried logging in with what topstep gave me as log in instructions username etc as you suggested that does not work and when i use your log in info i cannot log in at all -------------
please advise,thanks
maria
[2013-10-24 00:46:28]
100 - Posts: 147
Your Sierra Data goes into the intial log in - b4 u see the platform
The log in info given to you by top step should be placed into the data trade servie settings - connection details. you should have password username from topstep, and the data service should match what u use with top step
[2013-10-24 02:19:36]
ok but now when i use the log in for sierra i cannot log in at all where as this AM i had no problem
[2013-10-24 02:22:18]
that worked but where were my orders from 10 23 on euro and es????
also this hsould be set to sim correct
[2013-10-24 05:00:36]
We can see that you are successfully logged into Sierra Chart.
Are you connected to the data and trade Server? If File >> Connect To Data Feed is disabled, then you are connected.
In the case of Top Step Trader you must not be in Trade Simulation Mode in Sierra Chart. Refer to:
https://www.sierrachart.com/index.php?l=doc/doc_Trading.html#DifferenceBetweenSimAndNonSim
