Date/Time: Sat, 04 May 2024 01:46:30 +0000
Price Change graph of poor rendering
View Count: 586
[2018-09-12 17:55:21] |
User68117 - Posts: 64 |
Hello, can you please advise me where the SierrChart error is that it misrepresents the Price Changes chart on different PCs? In my work I have a graph drawn somehow, I will come home SierrChart - I get the data and the chart at the same time looks different. A friend who has the same broker, the same data (CQG), has a completely different plot. Where can be a bug ??? Interestingly, for example, at the Reversal chart or Renko chart it sits and the charts are fine. Check the enclosed screens. Everything is beautifully seen on the Volume Zone Oscillator, where there are really great differences due to the otherwise drawn candles in the chart. thank you for answer |
PC Work.png / V - Attached On 2018-09-12 17:54:31 UTC - Size: 100.79 KB - 227 views PC home.png / V - Attached On 2018-09-12 17:54:41 UTC - Size: 387.61 KB - 242 views PC Friend.png / V - Attached On 2018-09-12 17:54:48 UTC - Size: 67.21 KB - 233 views |
[2018-09-13 04:46:48] |
These types of charts are going to be hard to get an exact match. You are going to need a perfect data feed . Therefore, you need to use the Sierra Chart Exchange Data Feed: Sierra Chart Exchange Data Feed We will not help with CQG data. Set Sierra Chart to a Tick by Tick Data Configuration. Follow the instructions here to do this: Tick by Tick Data Configuration Make sure the Chart Settings are exactly an exact match between each chart and also that the time zone is the same: Chart Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-13 04:47:12
