Date/Time: Thu, 02 May 2024 23:30:08 +0000
PMO study for Sierra
View Count: 1591
[2018-09-10 05:51:22] |
User360283 - Posts: 440 |
Is there a PMO study or equivalent for Sierra? Thanks https://stockcharts.com/articles/decisionpoint/2018/02/whats-the-difference-between-the-pmo-price-momentum-oscillator-and-macdppo.html |
[2018-09-20 09:40:55] |
Waiting for an answer. Thanks
[2018-09-20 14:58:10] |
We need some time to look into this.
[2018-09-24 21:15:46] |
SC Support Tom - Posts: 450 |
Hello, I am looking into this. In order for me to program this study for Sierra Chart, I need to know two things. First, what is the meaning of Smoothing Function? It is not defined anywhere in the link that you provided. Second, Custom Smoothing Function is defined recursively, but nowhere in the link is it ever initialized. What should be its initial value? |
[2018-09-25 00:18:05] |
Tom - I don't know.
[2018-09-25 16:38:03] |
Hello, Would this link and Excel file (provided by the link) help you in Post #4? DecisionPoint Price Momentum Oscillator (PMO): https://stockcharts.com/school/doku.php?id=chart_school:technical_indicators:dppmo Yes thank you, this answers both of my questions. Smoothing Function is the same as Custom Smoothing Function, and Custom Smoothing Function is initialized using a simple average. A request if you're able to create the PMO indicator: Can you allow for the Custom Smoothing Function to be user-defined, e.g using the Open or HL Average, instead of the Close price? Yes, my intention was to allow for an Input Data input, just as in most of our other studies. I will program this and submit it to Sierra Chart Engineering today. |
[2018-09-25 16:50:57] |
U_winks - Posts: 190 |
Thanks very much for your time and effort, Tom! :)
[2018-09-25 18:19:38] |
thanks
[2018-09-27 16:21:52] |
John - SC Support - Posts: 31334 |
The Price Momentum Oscillator study will be available in the next pre-release (1813). When available, you can download the software following these instructions: Software Download: Fast Update
[2018-09-28 15:20:46] |
User701453 - Posts: 176 |
John - SC Support Its great that you took the time to create the PMO study a SC user needed. Could you also create this indicator a user requested? Trendline(Ray) Study |
[2018-09-28 16:45:48] |
Although not exactly what you are looking for, but have you tried the Calculator drawing tool? You can display the Price of the endpoint of the calculator and display it at the end of the line. This price will then update as you change the line.
[2018-09-28 17:30:05] |
Not what I was looking for... If a hand drawn trendline(Ray Tool) provided its value as a subgraph, then a user could use the Trading System Based on alert study. To place trades when current price crosses over and closes above or below the trendline. That would allow users an easy way to have a Trend Line trading system without having to code a full blown trading system by hand. |
[2018-09-28 17:36:43] |
Just so you area aware, you can reference the Anchor points of a drawing and use those in Alerts. You will find the documentation for this here: Study/Chart Alerts And Scanning: Referencing Chart Drawings
[2018-09-28 17:55:43] |
Thanks, I will test that over the weekend. Unrelated to the Trend line post..I have a math problem I been trying to solve for a couple of days and I`m stuck. The details is explained on this post for help. Negative numbers Date Time Of Last Edit: 2018-09-28 18:01:21
[2018-10-19 09:29:50] |
Tom I've been having some serious performance issues after installing the PMO. My PC is an I7 2GB RAM 720 MB Disc that is cleaned and scrubbed. When the PMO is applied to a second chart the performance becomes very slow. Thought you might want to look into this. Thanks |
[2018-10-19 09:49:48] |
We had a quick look at "Price Momentum Oscillator". There is nothing in that study which would cause any type of performance issue.
[2018-10-19 12:27:02] |
Rino - Posts: 124 |
Forgive me. 2GB RAM? (Mistake?) I have 16. It is recommended between 12 and 16. |
[2018-10-19 12:27:36] |
Chartbook has 6 charts all ES 4Min, 60Min, 2 Dailys (1 minimized), Weekly and Flex Renko PMO is on my Flex Renko 5-4-1 chart. When I add the PMO to the 60 Min it gets very slow. Hope this helps. |
[2018-10-19 12:40:51] |
20GB
[2018-10-19 16:45:50] |
Make sure you are using the "Price Momentum Oscillator" you see listed in Analysis >> Studies. Update Sierra Chart if needed to the current version: Software Download: Fast Update Do not use any DLL file that you have found on this Support Board. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-10-19 17:26:08] |
Now on V 1823 32 bit Is this the version you were referring to? Previously when running a System Mechanic scan I kept getting low memory errors that were corrected. I will keep monitoring. Thanks |
[2018-10-19 21:39:54] |
Are you running any custom studies? If so, one of those may be the cause of the issue. The Sierra Chart built in studies will not be a problem.
[2021-02-03 07:44:30] |
User870514 - Posts: 25 |
I would like to experiment/ extend the PMO study referenced in post 10. Is it possible to obtain a copy of the source please? Thanks |
[2021-02-03 10:42:25] |
Refer to: How to Build an Advanced Custom Study from Source Code Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
