Date/Time: Sun, 19 May 2024 06:11:14 +0000
Point and Figure - adjust minimum tick size
View Count: 844
[2018-09-04 11:43:28] |
manfretto - Posts: 117 |
Hi, is it possible to adjust minimum tick size for P&F chart? For example, Crude Oil futures mimimum tick size is .01 (70.10->70.11) and I would like to adjust it that I see a change by .1 (70.10-70.20) it means that any price between 70.10 and 70.19 is treated as 70.10. Second question, instead of X-O, is it possible to draw the price on the chart as below 41 4040 3939 38 Date Time Of Last Edit: 2018-09-04 14:25:18
[2018-09-04 18:04:35] |
You can adjust the Tick Size: Chart Settings: Tick Size (Chart >> Chart Settings >> Symbol >> Symbol Settings menu) The answer to the next question is you need to use the Numbers Bars study for that: Numbers Bars It supports displaying the price at each price level. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
