Date/Time: Sun, 19 May 2024 10:21:28 +0000
iqfeed data errors 'filtered'
View Count: 861
[2018-09-04 08:30:02] |
User21339 - Posts: 61 |
charts arent updating. DTN assure me my feed is fine and shows im connected to SC on their end and data is flowing. SC message log errors out constantly with 'error filtered for EXU18' Dec contract change doesnt change the errors. I tried deleting the SCID file and start again, but still same errors occur. I thought it was an error DTN IQFEED side because when i change the feed to 'SC data all services' Data flows with no errors in the logfile. Charts wont update realtime is the issue here. Tried using 32bit and 64bit exe files but no change and also restarting system failed to fix the problem. If its a data issue the only feed i want is the Eurex feed, so perhaps i should open a subscription with you for that. any suggestions on fixing this? screenshot of error in the logfile here. https://goo.gl/yZAbfr Thanks. |
[2018-09-04 09:34:16] |
We do think there is some data error with the IQ Feed data causing if this if this is not something that you normally see. Or perhaps there could have been an abnormal amount of price movement with that symbol causing the problem. However, if you are not having the same issue with the Sierra Chart EUREX data for that particular market, then that would seem to be not the case. The short-term solution is just to disable the error filtering: https://www.sierrachart.com/index.php?page=doc/ErrorFilter.html#DisablingErrorFiltering If its a data issue the only feed i want is the Eurex feed, so perhaps i should open a subscription with you for that.
Unless you have a specific need for IQ Feed we do think this would be a good idea.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-04 09:35:46
[2018-09-04 11:34:25] |
wwwingman - Posts: 185 |
I may have the same pb. Something does not work anymore on SOME of my instances, but not all, with the real time update of charts of Sierra+IQFeed recently. I tried to clean all my scid, load on one machine or multiple instances. But real time update seem to have a problem. When opening SC T&S I see orders that seem to be garbage or coming from other markets. When opening the IQFeed T&S in parallel, it seems IQFeed tool does receive the right data. I use IQFeed 6.0.0.5 with SC 1795. Enclosed-by screenshot. |
2018-09-04_06-21-13.png / V - Attached On 2018-09-04 11:28:28 UTC - Size: 242.79 KB - 280 views |
[2018-09-04 14:05:01] |
FWIW : I had similar filitered erros. I rolled back to 1781 and it seems all my problems are solved.
[2018-09-04 14:45:42] |
LucentTrader - Posts: 35 |
I faced the same issue. I rolled back to 1794. Issue resolved.
[2018-09-04 16:44:16] |
We are looking into this now.
[2018-09-04 17:42:07] |
We have this resolved and we will have a new release out in about 20 minutes.
[2018-09-04 18:11:55] |
This issue is now resolved in the latest revision of prerelease 1797. Update to the "Prerelease" following these instructions here: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
