Date/Time: Sun, 19 May 2024 03:47:32 +0000
Determining the angle of a study
View Count: 1397
[2018-09-01 23:19:22] |
Mark Sear - Posts: 42 |
Hi. I am trying to understand how the STUDY ANGLE works. I want to do something very simple (I thought). I want to understand what angle a Keltner channel or Bollinger band has relative to flat. If the study was running completely flat I would expect the angle to return 0. However, no matter what setting I select I cannot get a simple angle to return correctly for me. I have attached an example (apologies - I couldn't get your method to work). As you will see from the settings also attached, the study is returning and answer of -75 degrees for the slope. I simply cannot see how this is possible as that is close to vertical, and neither line is vertical. The Bollinger is set to 20-periods, and I have tried selecting in input length of every value from 1 to 20 but none of the angles make any sense to me at all (they do not correspond in any way to the angle seen on screen). The instrument is CFD GER30. I have also tried modifying the tick value, but that doesn't work either. Please can you explain how I get this simple angle working? Thanks. |
Attachment Deleted. line-angles.png / V - Attached On 2018-09-01 23:01:39 UTC - Size: 331.25 KB - 482 views input-data.PNG / V - Attached On 2018-09-01 23:04:42 UTC - Size: 220.83 KB - 330 views |
[2018-09-04 02:42:58] |
Based on the documentation and based upon the data being referenced in the screenshots you provided, when you perform a manual calculation of what the slope should be using a rise over run calculation, what do you get? This should not be difficult. The documentation is quite clear. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-09-04 02:44:29
