Date/Time: Sun, 19 May 2024 02:33:59 +0000
Testing latest version with LMAX, SC have open position that doesn't exist on LMAX
View Count: 712
[2018-08-31 14:26:09] |
AlexPereira - Posts: 197 |
Hi, I am using the latest version with LMAX (v1794) and every time I connect to data services, I have a position on EURUSD. That position doesn't exist on LMAX (checking through LMAX web client). My current workarounds, is to either restrict the "Order Fills Start Date-Time" or go into "Trade Activity Log" and do a "Clear". Is there something I should do ? Should I use or not use "Use Fill Calculated Positions-Global" ? Thanks! |
[2018-08-31 18:03:17] |
This is not unusual when using LMAX and does not relate to the new version. It could not. It is fully explained here: LMAX Trading Service: How Current Trade Positions Are Determined You really do need to set "Order Fills Start Date-Time" to the point in time that your position has been flat and should be fine going forward in time. With LMAX this is always on and cannot be disabled: "Use Fill Calculated Positions-Global" Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-31 18:04:33
[2018-09-01 01:01:12] |
Ok, thanks. I never needed to use it before ( in previous year and half of SC usage with LMAX ). I am not sure, but it started happening when I used and traded using the 64bit version on linux, which has problems in the "trade and activity" information. ( like I reported in a previous post ). With LMAX this is always on and cannot be disabled:
"Use Fill Calculated Positions-Global" I also thought that, from reading the documentation, but I noticed that i had it disabled, so I asked to be sure. Thanks for the help, I also thought asking because you stated that were doing changes in LMAX in the demo and were going to do it in real environment this week. |
