Date/Time: Sat, 18 May 2024 18:02:50 +0000
Sales support
View Count: 557
[2018-08-30 17:42:24] |
User288945 - Posts: 22 |
I do Elliott Wave analysis and one feature that I am looking for is the ability to use cross-hairs and select a low and a high on different bars and have the difference displayed on the screen. Is this a built-in capability? What programming language is recommended for developing trading algos?
[2018-08-30 17:44:12] |
For the first question, this can be done and you will need to use the Chart Calculator tool: Chart Drawing Tools: Chart Calculator If you want to develop an automated trading system the best way would be to use the Advanced Custom Study Interface and Language which is documented here: Advanced Custom Study Interface and Language (ACSIL) The language is C++. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-30 17:44:38
