Date/Time: Sat, 18 May 2024 11:02:15 +0000
Compact Tool Values windows missing
View Count: 898
[2018-08-30 14:24:54] |
Meklon - Posts: 218 |
Hello support, For some strange reason the Compact Tool Values windows is missing from the screen as of this morning. I do have the "Show Compact Tool Values Window" option check marked on the windows menu, but when I activate the "Chart Values / Cross-hair" option it is no longer being displayed. I am running on a singe screen at the moment so it not possible that it may be on another monitor. All other windows from the Windows menu coming up without a problem. Resetting the Windows is not helping. Please advise. |
[2018-08-30 17:49:23] |
Follow the instructions here including using Chart >> Reset Child Windows: Chart Drawing Tools: Compact Tool Values Window Not Visible Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-31 15:52:50] |
Thank you support, that worked!
[2018-08-31 16:42:24] |
Yes of course it works. It always works. We had one user insist the documentation did not help them. But obviously they did not follow that one particular step.
