Date/Time: Sat, 18 May 2024 15:56:38 +0000
Price bars
View Count: 601
[2018-08-29 17:08:36] |
User750920 - Posts: 274 |
Is it possible to drag (move the price bars) candlesticks away from the far right edge without changing the scale of the chart and keeping the Volume Profile at the right edge?
[2018-08-29 18:56:05] |
Yes refer to: Working With Charts: Right Side Fill Space And refer to: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-29 19:36:01] |
Sorry I am confused as to what I am supposed to do regarding the fill space and what to check/uncheck so the volume profile remains to the right and the bars can be moved left
[2018-08-29 19:56:02] |
Follow through the step-by-step instructions here: Volume By Price Study: Right Aligning Volume Profiles with Space on Right Side of Chart Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
