Date/Time: Mon, 29 Apr 2024 17:15:23 +0000
Number Bars / Imbalances / POCs / Templates
View Count: 5676
[2018-08-28 10:26:23] |
User371906 - Posts: 141 |
Hi, Are there any templates for Number Bars that have Imbalances or POCs (support and resistance levels inside Numbers Bar) in this forum to share? Tried to set up Imbalances but could not get it to work: Numbers Bars: Diagonal Comparison of Bid Volume and Ask Volume Have not been able to find a page for Number Bars POC to try and set it up. - Picture attached Thanks |
Number Bars POCs.JPG / V - Attached On 2018-08-28 10:11:24 UTC - Size: 40.31 KB - 1338 views |
[2018-08-28 18:32:32] |
We could create a Chartbook for you with a basic diagonal comparison. For what symbol did you want this for? And here is the Numbers Bars study input to highlight the Point of Control: Numbers Bars: Highlight Point Of Control In Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-28 18:41:22] |
Highly appreciative for this. Symbol is: F.US.EPU18 Thank you Regards |
[2018-08-29 13:06:25] |
Good morning, Please don't forget me with the Diagonal Comparison, anticipating being able to use it in todays trading. Once again thank you. Kindly g |
[2018-08-29 14:31:42] |
John - SC Support - Posts: 31168 |
Sorry for the delay. Here is the Chartbook with the Numbers Bars study set to color the text using the comparison of Diagonal Dominant Ask Vol Bid Vol Percentage. In addition, we have turned on the highlighting of the Point of Control as well as put on the Candlestick outline. The documentation for the particular text coloring can be found here: Numbers Bars: Text Coloring Based on Diagonal Dominant Side AskVol BidVol Percentage The Input for the Point of Control documentation can be found here: Numbers Bars: Highlight Point Of Control In And the Input for the Open/Close Marker boxes (the Candlestick Outline in this case) can be found here: Numbers Bars: Open and Close Marker Style For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
NumbersBarsDiagonalComp.Cht - Attached On 2018-08-29 14:31:36 UTC - Size: 54.02 KB - 917 views |
[2018-08-29 16:00:17] |
John, Want to state that I love this platform and the team supporting the traders who use it. Kudos to you and team!!! Muchas Gracias Regards g |
[2020-09-19 17:53:34] |
runitup858 - Posts: 8 |
Thank you this helped me alot.
