Date/Time: Sun, 19 May 2024 11:19:54 +0000
SpreadSheets
View Count: 579
[2018-08-26 22:21:36] |
User835963 - Posts: 18 |
Hello Support, is there a way when using spreadsheets to reference a different cell on the same spreadsheet or any other, will be something like this ID3.SG3@(ID3.SG10@3) OR ID3.SG3@S3 Regards, Heather |
[2018-08-27 10:09:54] |
All the different cell reference methods are fully documented here: Working with Spreadsheets: Cell and Range References Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
