Date/Time: Thu, 01 Oct 2026 09:18:05 +0000
BTCUSD-Bitfinex Issue
View Count: 2286
| [2018-08-25 09:14:39] |
| User952186 - Posts: 58 |
I can not view intraday and historical data for BTCUSD pair of Bitfinex. I installed the latest version which is 1785 and followed below procedure to remove old data files to be able to redownload the data. https://www.sierrachart.com/index.php?page=doc/IntradayDataEditor.html&CAID=default As soon as I find/select the BTCUSD pair SC says downloading historical data/intraday data completed but I only see a black screen with no OHLC bars. Could you please support me to overcome this issue? Thanks. |
| [2018-08-25 09:44:45] |
Follow the instructions here to clear the Message Log: Message Log: Clearing the Message Log Fully re-download the data in the chart by going to the chart and selecting "Edit >>Delete All Data and Download". After about a minute provide a copy of the Message Log following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-08-28 14:28:07] |
Thanks Please see it below. Software version: 1785 32-bit | 2018-08-28 17:24:02 Usage end date: 2018-09-28 | 2018-08-28 17:24:02 Enabled for: Advanced Features. | 2018-08-28 17:24:02 Enabled for: Advanced Features 2. | 2018-08-28 17:24:02 Enabled for: Sierra Chart Historical Data Service. | 2018-08-28 17:24:02 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-28 17:24:02 Current selected Data/Trading service: SC Data - All Services | 2018-08-28 17:24:02 Chart Update Interval: 500 | 2018-08-28 17:24:02 Time Zone: +03:00:00 (AST+03) | 2018-08-28 17:24:02 2018-08-28 17:24:02 Local computer time | 2018-08-28 17:24:02 2018-08-28 14:24:02 Local computer time in UTC | 2018-08-28 17:24:02 2018-08-28 17:24:02 Local computer time in SC Time Zone | 2018-08-28 17:24:02 2018-08-28 06:57:06 Server time in UTC | 2018-08-28 17:24:02 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-08-28 17:24:02 Program path: C:\SierraChart\ | 2018-08-28 17:24:02 Data Files path: C:\SierraChart\Data\ | 2018-08-28 17:24:02 OS Version Number: 10.0 | 2018-08-28 17:24:02 Locale Setting: C | 2018-08-28 17:24:02 HD Request # 915 | Downloading Historical Daily chart data for BTCUSD-BITFINEX. Starting date: 1968-08-28. Service: scdataallservices | 2018-08-28 17:24:19 HD Request # 915 | Requesting historical Daily data for BTCUSD-BITFINEX starting at 1968-08-27 | 2018-08-28 17:24:19 HD Request # 915 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for BTCUSD-BITFINEX | 2018-08-28 17:24:20 HD Request # 915 | Completion time: 1s | 2018-08-28 17:24:20 HD Request # 915 | Daily data download complete for BTCUSD-BITFINEX. Unique request ID: 777 | 2018-08-28 17:24:20 Removed historical data download ID 777 | 2018-08-28 17:24:20 BTCUSD-BITFINEX Daily #2 | Reloading chart. | 2018-08-28 17:24:20 BTCUSD-BITFINEX Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTCUSD-BITFINEX.dly | 2018-08-28 17:24:20 Opened cached Intraday file: C:\SierraChart\Data\BFTUSD-BITFINEX.scid | 2018-08-28 17:24:26 Opened cached Intraday file: C:\SierraChart\Data\SNTUSD-BITFINEX.scid | 2018-08-28 17:24:56 BTCUSD-BITFINEX 60 Min #2 | Reloading chart. | 2018-08-28 17:26:41 BTCUSD-BITFINEX 60 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-08-28 17:26:41 BTCUSD-BITFINEX Daily #2 | Reloading chart. | 2018-08-28 17:27:06 BTCUSD-BITFINEX Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTCUSD-BITFINEX.dly | 2018-08-28 17:27:06 HTTPS connection to historicaldata.sierrachart.com:443 (2178) | Socket gracefully closed by remote side. | 2018-08-28 17:27:20 HTTPS connection to historicaldata.sierrachart.com:443 (2178) | Received socket Close event. | 2018-08-28 17:27:20 HTTPS connection to historicaldata.sierrachart.com:443 (2178) | Initiating close of socket by core. | 2018-08-28 17:27:20 HTTPS connection to historicaldata.sierrachart.com:443 (2178) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-28 17:27:20 HTTPS connection to historicaldata.sierrachart.com:443 (2178) | Closed. | 2018-08-28 17:27:20 |
| [2018-08-28 17:51:35] |
Follow the instructions here to update the Symbol Settings: Global Symbol Settings: Update Global Symbol Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
| [2018-08-29 08:31:07] |
Thanks. Now It is just the black blank screen when I select the daily and intraday BTCUSD charts respectively. I normally see "data download" warning text box in the middle of the screen but now nothing happens. Software version: 1785 32-bit | 2018-08-29 11:28:27 Usage end date: 2018-09-28 | 2018-08-29 11:28:27 Enabled for: Advanced Features. | 2018-08-29 11:28:27 Enabled for: Advanced Features 2. | 2018-08-29 11:28:27 Enabled for: Sierra Chart Historical Data Service. | 2018-08-29 11:28:27 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-29 11:28:27 Current selected Data/Trading service: SC Data - All Services | 2018-08-29 11:28:27 Chart Update Interval: 500 | 2018-08-29 11:28:27 Time Zone: +03:00:00 (AST+03) | 2018-08-29 11:28:27 2018-08-29 11:28:27 Local computer time | 2018-08-29 11:28:27 2018-08-29 08:28:27 Local computer time in UTC | 2018-08-29 11:28:27 2018-08-29 11:28:27 Local computer time in SC Time Zone | 2018-08-29 11:28:27 2018-08-28 06:57:06 Server time in UTC | 2018-08-29 11:28:27 Local computer UTC time and Server UTC time difference: 0 seconds. | 2018-08-29 11:28:27 Program path: C:\SierraChart\ | 2018-08-29 11:28:27 Data Files path: C:\SierraChart\Data\ | 2018-08-29 11:28:27 OS Version Number: 10.0 | 2018-08-29 11:28:27 Locale Setting: C | 2018-08-29 11:28:27 BTCUSD-BITFINEX Daily #2 | Reloading chart. | 2018-08-29 11:28:35 BTCUSD-BITFINEX Daily #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTCUSD-BITFINEX.dly | 2018-08-29 11:28:35 BTCUSD-BITFINEX 360 Min #2 | Reloading chart. | 2018-08-29 11:28:36 BTCUSD-BITFINEX 360 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-08-29 11:28:36 |
| [2018-08-29 17:42:47] |
That Message Log does not have the information needed. This probably is not necessary but at this point we want you to perform a Full Reset of Symbol Settings: https://www.sierrachart.com/index.php?page=doc/GlobalSymbolSettings.php#FullResetSymbolSettingsSteps After this re-download all of the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download". Going forward you definitively should not have any problem. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-05 20:10:40
| [2018-08-30 20:34:28] |
Thank you Solved. |
| [2018-12-05 13:54:45] |
| ILIM KIRGIZ - Posts: 187 |
Hi there, I've faced with the same issue for bitfinex symbols: BCHUSD, XLMUSD, XTZUSD, VETUSD, MKRUSD. I've made a full reset of the symbols and Edit >> Delete All Data and Download for BCHUSD but it is still same. Could you please guide me to resolve this issue? Thanks Software version: 1842 32-bit | 2018-12-05 13:45:54 Usage end date: 2018-12-31 | 2018-12-05 13:45:54 Enabled for: Advanced Features. | 2018-12-05 13:45:54 Enabled for: Advanced Features 2. | 2018-12-05 13:45:54 Enabled for: Sierra Chart Historical Data Service. | 2018-12-05 13:45:54 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-12-05 13:45:54 Current selected Data/Trading service: LMAX Live Trading - DTC | 2018-12-05 13:45:54 Chart Update Interval: 500 | 2018-12-05 13:45:54 Time Zone: +00:00:00 (GMT+00BST+01,M3.5.0/01:00,M10.5.0/02:00) | 2018-12-05 13:45:54 2018-12-05 13:45:54 Local computer time | 2018-12-05 13:45:54 2018-12-05 13:45:54 Local computer time in UTC | 2018-12-05 13:45:54 2018-12-05 13:45:54 Local computer time in SC Time Zone | 2018-12-05 13:45:54 Program path: C:\SierraChart\ | 2018-12-05 13:45:54 Data Files path: C:\SierraChart\Data\ | 2018-12-05 13:45:54 OS Version Number: 10.0 | 2018-12-05 13:45:54 Locale Setting: C | 2018-12-05 13:45:54 DLLs: ChandelierStop.dll, Contracts_1.dll, Contracts_1_64.dll, Contracts_2.dll, Contracts_2_64.dll, Contracts_4.dll, Contracts_4_64.dll, JRS_SC.dll, MACD_zerolag_64.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2018-12-05 13:45:54 Opened cached Intraday file: C:\SierraChart\Data\XMRUSD-BITFINEX.scid | 2018-12-05 13:45:55 Intraday data recording state for symbol BCHUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:46:36 Reloading all charts with filename: BCHUSD-BITFINEX.scid | 2018-12-05 13:46:36 HD Request # 3353 | Downloading Intraday chart data for BCHUSD-BITFINEX to the file BCHUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:46:36 HD Request # 3353 | Download start date-time: 1991-07-20 14:46:36.000 | 2018-12-05 13:46:36 HD Request # 3353 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:46:36 Socket (2) | Creating socket. | 2018-12-05 13:46:36 Socket (2) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:46:36 BCHUSD-BITFINEX [M] 15 Min #4 | Reloading chart. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 15 Min #4 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BCHUSD-BITFINEX.scid | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 1 Min #8 | Reloading chart. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 1 Min #8 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BCHUSD-BITFINEX.scid | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 240 Min #2 | Reloading chart. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 240 Min #2 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BCHUSD-BITFINEX.scid | 2018-12-05 13:46:37 HD Request # 3353 | Setting DTC encoding to Binary VLS | 2018-12-05 13:46:37 HD Request # 3353 | Sending historical data logon request message. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 60 Min #3 | Reloading chart. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 60 Min #3 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BCHUSD-BITFINEX.scid | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 5 Min #5 | Reloading chart. | 2018-12-05 13:46:37 BCHUSD-BITFINEX [M] 5 Min #5 | Currently no data in file to display. Will start historical data download and real-time updates. File: C:\SierraChart\Data\BCHUSD-BITFINEX.scid | 2018-12-05 13:46:37 HD Request # 3353 | Requesting Intraday data. Start date-time: 1991-07-20 14:46:36. Record interval: 0. Symbol: BCHUSD-BITFINEX | 2018-12-05 13:46:37 HD Request # 3353 | Decompressing data. | 2018-12-05 13:46:37 HD Request # 3353 | Receiving Intraday data for BCHUSD-BITFINEX starting at 2018-01-10 06:05:48 | 2018-12-05 13:46:38 HD Request # 3353 | Timestamp of first Intraday data file record written: 2018-01-10 06:05:48 | 2018-12-05 13:46:38 Chart #3 has tagged chart #2 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:38 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:38 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:38 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:38 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:39 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:39 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:39 BCHUSD-BITFINEX [M] 240 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:39 Chart #2 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:39 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:39 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:46:39 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:46:39 Opened cached Intraday file: C:\SierraChart\Data\DSHUSD-BITFINEX.scid | 2018-12-05 13:47:04 Opened cached Intraday file: C:\SierraChart\Data\BTGUSD-BITFINEX.scid | 2018-12-05 13:47:04 DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:48:04 DTC Client socket (4) | Received socket Close event. | 2018-12-05 13:48:04 DTC Client socket (4) | Signaling to core to close socket | 2018-12-05 13:48:10 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:48:10 DTC Client socket (4) | Closed. | 2018-12-05 13:48:10 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:48:10 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:48:10 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 10048 | 2018-12-05 13:48:41 DTC Client socket (4) | Creating socket. | 2018-12-05 13:48:41 DTC Client socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:48:41 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:48:43 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:48:43 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:48:43 DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:48:50 DTC Client socket (4) | Received socket Close event. | 2018-12-05 13:48:50 DTC Client socket (4) | Signaling to core to close socket | 2018-12-05 13:49:17 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:17 DTC Client socket (4) | Closed. | 2018-12-05 13:49:17 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:17 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:17 DTC Client socket (0) | Ignored Send call based on current state. | 2018-12-05 13:49:17 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:49:17 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:17 DTC Client socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:17 DTC Client socket (3) | Received socket Close event. | 2018-12-05 13:49:17 BCHUSD-BITFINEX [M] 15 Min #4 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-10-28 00:45:00. Next Bar Date Time: 2018-10-28 00:00:00. Filename: BCHUSD-BITFINEX.scid | 2018-12-05 13:49:18 Socket (2) | Signaling to core to close socket | 2018-12-05 13:49:18 Socket (2) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:18 Socket (2) | Socket gracefully closed by remote side. | 2018-12-05 13:49:18 Socket (2) | Closed. | 2018-12-05 13:49:18 DTC Client socket (3) | Signaling to core to close socket | 2018-12-05 13:49:19 DTC Client socket (3) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:19 DTC Client socket (3) | Closed. | 2018-12-05 13:49:19 Historical data download thread signaled to stop. | 2018-12-05 13:49:19 HD Request # 3353 | Received 6567843 records from 2018-01-10 06:05:48 to 2018-11-15 16:52:09 (309.4 days) and wrote 6567842 records for BCHUSD-BITFINEX | 2018-12-05 13:49:19 HD Request # 3353 | Completion time: 2m 42s | 2018-12-05 13:49:19 HD Request # 3353 | Intraday data download complete for BCHUSD-BITFINEX. Unique request ID: 3958 | 2018-12-05 13:49:19 Removed historical data download ID 3958 | 2018-12-05 13:49:19 Real-time Intraday chart data file updates started for BCHUSD-BITFINEX | 2018-12-05 13:49:19 Intraday chart data file opened for BCHUSD-BITFINEX | 2018-12-05 13:49:19 SC DTC Data with Market Depth | Disconnected from the server. | 2018-12-05 13:49:19 SC DTC Data with Market Depth | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:19 Chart #2 has tagged chart #1 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:20 Chart #2 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:20 Chart #2 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:20 BCHUSD-BITFINEX [M] 60 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:21 Chart #3 has tagged chart #2 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:21 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:21 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:21 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:21 BCHUSD-BITFINEX [M] 5 Min #5 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-10-28 00:50:00. Next Bar Date Time: 2018-10-28 00:00:00. Filename: BCHUSD-BITFINEX.scid | 2018-12-05 13:49:21 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:22 Chart #5 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:23 Chart #5 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:23 BCHUSD-BITFINEX [M] 1 Min #8 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-10-28 00:51:00. Next Bar Date Time: 2018-10-28 00:00:00. Filename: BCHUSD-BITFINEX.scid | 2018-12-05 13:49:23 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:23 Chart #8 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:26 BCHUSD-BITFINEX [M] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:26 Chart #1 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:26 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:26 Chart #4 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 Chart #4 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 443 | 2018-12-05 13:49:27 DTC Client socket (2) | Creating socket. | 2018-12-05 13:49:27 DTC Client socket (2) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:49:27 BCHUSD-BITFINEX [M] 240 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:27 Chart #2 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:27 BCHUSD-BITFINEX [M] 60 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:27 DTC Client socket (2) | Socket gracefully closed by remote side. | 2018-12-05 13:49:27 DTC Client socket (2) | Received socket Close event. | 2018-12-05 13:49:27 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:27 DTC Client socket (2) | Signaling for receive thread to end. Bytes in receive buffer: 111 | 2018-12-05 13:49:27 DTC Client socket (2) | Signaling to core to close socket | 2018-12-05 13:49:27 DTC Client socket (2) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:27 DTC Client socket (2) | Closed. | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:27 DTC Client socket (0) | Ignored Send call based on current state. | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:49:27 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:27 SC DTC Data with Market Depth | Connecting to the server ds3.sierracharts.com. Port 10048 | 2018-12-05 13:49:27 DTC Client socket (2) | Creating socket. | 2018-12-05 13:49:27 DTC Client socket (2) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:27 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:27 SC DTC Data with Market Depth | Connected to server. | 2018-12-05 13:49:28 SC DTC Data with Market Depth | Starting socket receive thread. | 2018-12-05 13:49:28 SC DTC Data with Market Depth | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:28 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:28 SC DTC Data with Market Depth | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Sending logon request message. | 2018-12-05 13:49:31 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:31 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Received logon response. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Server Name: SC Realtime Server. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Server protocol version: 8. Client protocol version: 8 | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Successfully connected. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Trading is not supported. | 2018-12-05 13:49:31 Intraday data recording state for symbol AUD-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: AUD-X | 2018-12-05 13:49:31 Intraday data recording state for symbol BATUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BATUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol BCHUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BCHUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol BTCUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTCUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol BTGUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: BTGUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol CAD-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CAD-X | 2018-12-05 13:49:31 Intraday data recording state for symbol CHF-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: CHF-X | 2018-12-05 13:49:31 Intraday data recording state for symbol DSHUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: DSHUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol EOSUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EOSUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol ETCUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETCUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol ETHUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ETHUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol EUR-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: EUR-X | 2018-12-05 13:49:31 Intraday data recording state for symbol GBP-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: GBP-X | 2018-12-05 13:49:31 Intraday data recording state for symbol IOTUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: IOTUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol JPY-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: JPY-X | 2018-12-05 13:49:31 Intraday data recording state for symbol LTCUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: LTCUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol MKRUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: MKRUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol NEOUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NEOUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol NZD-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: NZD-X | 2018-12-05 13:49:31 Intraday data recording state for symbol OMGUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: OMGUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol QTMUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: QTMUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol TRXUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: TRXUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol USD-X is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USD-X | 2018-12-05 13:49:31 Intraday data recording state for symbol USDX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: USDX | 2018-12-05 13:49:31 Intraday data recording state for symbol VETUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: VETUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol XLMUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XLMUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol XMRUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XMRUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol XRPUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XRPUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol XTZUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: XTZUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol ZECUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ZECUSD-BITFINEX | 2018-12-05 13:49:31 Intraday data recording state for symbol ZRXUSD-BITFINEX is set to download 'Pending'. | 2018-12-05 13:49:31 SC DTC Data with Market Depth | Restarting real-time data updates for symbol: ZRXUSD-BITFINEX | 2018-12-05 13:49:31 HD Request # 3354 | Downloading Intraday chart data for AUD-X to the file AUD-X.scid. Service: fxstatscalc | 2018-12-05 13:49:31 HD Request # 3354 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:31 HD Request # 3354 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:31 Socket (3) | Creating socket. | 2018-12-05 13:49:31 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:31 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:31 HD Request # 3354 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:31 HD Request # 3354 | Sending historical data logon request message. | 2018-12-05 13:49:31 HD Request # 3354 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: AUD-X | 2018-12-05 13:49:32 HD Request # 3354 | Decompressing data. | 2018-12-05 13:49:32 HD Request # 3354 | Receiving Intraday data for AUD-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:32 HD Request # 3354 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:32 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:32 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:32 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:32 Socket (3) | Closed. | 2018-12-05 13:49:32 Historical data download thread signaled to stop. | 2018-12-05 13:49:34 HD Request # 3354 | Received 4 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:26 (12.0 seconds) and wrote 3 records for AUD-X | 2018-12-05 13:49:34 HD Request # 3354 | Completion time: 3s | 2018-12-05 13:49:34 HD Request # 3354 | Intraday data download complete for AUD-X. Unique request ID: 3959 | 2018-12-05 13:49:34 Removed historical data download ID 3959 | 2018-12-05 13:49:34 Real-time Intraday chart data file updates started for AUD-X | 2018-12-05 13:49:34 Intraday chart data file opened for AUD-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol AUD-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol BATUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Real-time data for symbol BCHUSD-BITFINEX is currently unavailable. | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol BTCUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol BTGUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol CAD-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol CHF-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol DSHUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol EOSUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol ETCUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol ETHUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol EUR-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol GBP-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol IOTUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol JPY-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol LTCUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol MKRUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol NEOUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol NZD-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol OMGUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol QTMUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol TRXUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol USD-X | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol USDX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol VETUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol XLMUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol XMRUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol XRPUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol XTZUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol ZECUSD-BITFINEX | 2018-12-05 13:49:34 SC DTC Data with Market Depth | Received security definition for symbol ZRXUSD-BITFINEX | 2018-12-05 13:49:34 HD Request # 3355 | Downloading Intraday chart data for BATUSD-BITFINEX to the file BATUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:34 HD Request # 3355 | Download start date-time: 2018-12-05 13:31:16.000 | 2018-12-05 13:49:34 HD Request # 3355 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:34 Socket (3) | Creating socket. | 2018-12-05 13:49:34 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 10048 | 2018-12-05 13:49:34 DTC Client socket (4) | Creating socket. | 2018-12-05 13:49:34 DTC Client socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:34 DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:34 DTC Client socket (4) | Received socket Close event. | 2018-12-05 13:49:34 DTC Client socket (4) | Signaling to core to close socket | 2018-12-05 13:49:34 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:34 DTC Client socket (4) | Closed. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:34 DTC Client socket (0) | Ignored Send call based on current state. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:49:34 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:34 HD Request # 3355 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:35 HD Request # 3355 | Sending historical data logon request message. | 2018-12-05 13:49:35 HD Request # 3355 | Requesting Intraday data. Start date-time: 2018-12-05 13:31:16. Record interval: 0. Symbol: BATUSD-BITFINEX | 2018-12-05 13:49:35 HD Request # 3355 | Decompressing data. | 2018-12-05 13:49:35 HD Request # 3355 | Receiving Intraday data for BATUSD-BITFINEX starting at 2018-12-05 13:31:16 | 2018-12-05 13:49:35 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:35 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:35 Historical data download thread signaled to stop. | 2018-12-05 13:49:35 HD Request # 3355 | Received 2 records from 2018-12-05 13:31:16 to 2018-12-05 13:31:16 (0.0 seconds) and wrote 0 records for BATUSD-BITFINEX | 2018-12-05 13:49:35 HD Request # 3355 | Completion time: 0s | 2018-12-05 13:49:35 HD Request # 3355 | Intraday data download complete for BATUSD-BITFINEX. Unique request ID: 3960 | 2018-12-05 13:49:35 Removed historical data download ID 3960 | 2018-12-05 13:49:35 Real-time Intraday chart data file updates started for BATUSD-BITFINEX | 2018-12-05 13:49:35 Intraday chart data file opened for BATUSD-BITFINEX | 2018-12-05 13:49:35 HD Request # 3356 | Downloading Intraday chart data for BCHUSD-BITFINEX to the file BCHUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:35 HD Request # 3356 | Download start date-time: 2018-11-15 16:52:09.000 | 2018-12-05 13:49:35 HD Request # 3356 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:35 Socket (4) | Creating socket. | 2018-12-05 13:49:35 Socket (4) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:35 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:35 Socket (3) | Closed. | 2018-12-05 13:49:35 HD Request # 3356 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:35 HD Request # 3356 | Sending historical data logon request message. | 2018-12-05 13:49:35 Opened cached Intraday file: C:\SierraChart\Data\AUD-X.scid | 2018-12-05 13:49:35 HD Request # 3356 | Requesting Intraday data. Start date-time: 2018-11-15 16:52:09. Record interval: 0. Symbol: BCHUSD-BITFINEX | 2018-12-05 13:49:36 HD Request # 3356 | Decompressing data. | 2018-12-05 13:49:36 HD Request # 3356 | Receiving Intraday data for BCHUSD-BITFINEX starting at 2018-11-15 16:52:09 | 2018-12-05 13:49:36 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:36 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:36 Historical data download thread signaled to stop. | 2018-12-05 13:49:36 HD Request # 3356 | Received 1 record from 2018-11-15 16:52:09 to 2018-11-15 16:52:09 (0.0 seconds) and wrote 0 records for BCHUSD-BITFINEX | 2018-12-05 13:49:36 HD Request # 3356 | Completion time: 0s | 2018-12-05 13:49:36 HD Request # 3356 | Intraday data download complete for BCHUSD-BITFINEX. Unique request ID: 3961 | 2018-12-05 13:49:36 Removed historical data download ID 3961 | 2018-12-05 13:49:36 Real-time Intraday chart data file updates started for BCHUSD-BITFINEX | 2018-12-05 13:49:36 Intraday chart data file opened for BCHUSD-BITFINEX | 2018-12-05 13:49:36 HD Request # 3357 | Downloading Intraday chart data for BTCUSD-BITFINEX to the file BTCUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:36 HD Request # 3357 | Download start date-time: 2018-12-05 13:49:11.000 | 2018-12-05 13:49:36 HD Request # 3357 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:36 Socket (3) | Creating socket. | 2018-12-05 13:49:36 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:36 Chart #3 has tagged chart #2 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:36 Chart #3 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:36 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:36 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:36 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:36 Socket (4) | Closed. | 2018-12-05 13:49:36 HD Request # 3357 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:36 HD Request # 3357 | Sending historical data logon request message. | 2018-12-05 13:49:36 HD Request # 3357 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:11. Record interval: 0. Symbol: BTCUSD-BITFINEX | 2018-12-05 13:49:36 HD Request # 3357 | Decompressing data. | 2018-12-05 13:49:36 HD Request # 3357 | Receiving Intraday data for BTCUSD-BITFINEX starting at 2018-12-05 13:49:11 | 2018-12-05 13:49:36 HD Request # 3357 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:36 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:36 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:36 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:37 Socket (3) | Closed. | 2018-12-05 13:49:37 Chart #5 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 Chart #5 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 Historical data download thread signaled to stop. | 2018-12-05 13:49:37 HD Request # 3357 | Received 12 records from 2018-12-05 13:49:11 to 2018-12-05 13:49:32 (21.0 seconds) and wrote 10 records for BTCUSD-BITFINEX | 2018-12-05 13:49:37 Added 2 Time and Sales records to Intraday data file for BTCUSD-BITFINEX after download. | 2018-12-05 13:49:37 HD Request # 3357 | Completion time: 1s | 2018-12-05 13:49:37 HD Request # 3357 | Intraday data download complete for BTCUSD-BITFINEX. Unique request ID: 3962 | 2018-12-05 13:49:37 Removed historical data download ID 3962 | 2018-12-05 13:49:37 Real-time Intraday chart data file updates started for BTCUSD-BITFINEX | 2018-12-05 13:49:37 Intraday chart data file opened for BTCUSD-BITFINEX | 2018-12-05 13:49:37 HD Request # 3358 | Downloading Intraday chart data for BTGUSD-BITFINEX to the file BTGUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:37 HD Request # 3358 | Download start date-time: 2018-12-05 13:47:06.000 | 2018-12-05 13:49:37 HD Request # 3358 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:37 Socket (3) | Creating socket. | 2018-12-05 13:49:37 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:37 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:37 HD Request # 3358 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:37 HD Request # 3358 | Sending historical data logon request message. | 2018-12-05 13:49:37 Chart #4 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 Chart #4 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:37 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:37 HD Request # 3358 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:06. Record interval: 0. Symbol: BTGUSD-BITFINEX | 2018-12-05 13:49:38 HD Request # 3358 | Decompressing data. | 2018-12-05 13:49:38 HD Request # 3358 | Receiving Intraday data for BTGUSD-BITFINEX starting at 2018-12-05 13:47:06 | 2018-12-05 13:49:38 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:38 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:38 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:38 Socket (3) | Closed. | 2018-12-05 13:49:38 Opened cached Intraday file: C:\SierraChart\Data\BTCUSD-BITFINEX.scid | 2018-12-05 13:49:38 Chart #8 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 Historical data download thread signaled to stop. | 2018-12-05 13:49:41 HD Request # 3358 | Received 1 record from 2018-12-05 13:47:06 to 2018-12-05 13:47:06 (0.0 seconds) and wrote 0 records for BTGUSD-BITFINEX | 2018-12-05 13:49:41 HD Request # 3358 | Completion time: 4s | 2018-12-05 13:49:41 HD Request # 3358 | Intraday data download complete for BTGUSD-BITFINEX. Unique request ID: 3963 | 2018-12-05 13:49:41 Removed historical data download ID 3963 | 2018-12-05 13:49:41 Real-time Intraday chart data file updates started for BTGUSD-BITFINEX | 2018-12-05 13:49:41 Intraday chart data file opened for BTGUSD-BITFINEX | 2018-12-05 13:49:41 HD Request # 3359 | Downloading Intraday chart data for CAD-X to the file CAD-X.scid. Service: fxstatscalc | 2018-12-05 13:49:41 HD Request # 3359 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:41 HD Request # 3359 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:41 Socket (3) | Creating socket. | 2018-12-05 13:49:41 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:41 BCHUSD-BITFINEX [M] 240 Min #2 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:41 Chart #2 has tagged chart #1 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 Chart #2 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 Chart #2 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 Chart #2 has tagged chart #4 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 BCHUSD-BITFINEX [M] 60 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:41 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:41 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:41 HD Request # 3359 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:41 HD Request # 3359 | Sending historical data logon request message. | 2018-12-05 13:49:41 HD Request # 3359 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: CAD-X | 2018-12-05 13:49:41 HD Request # 3359 | Decompressing data. | 2018-12-05 13:49:41 HD Request # 3359 | Receiving Intraday data for CAD-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:41 HD Request # 3359 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:41 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:41 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:41 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:42 Socket (3) | Closed. | 2018-12-05 13:49:42 Historical data download thread signaled to stop. | 2018-12-05 13:49:42 HD Request # 3359 | Received 7 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:38 (24.0 seconds) and wrote 6 records for CAD-X | 2018-12-05 13:49:42 HD Request # 3359 | Completion time: 0s | 2018-12-05 13:49:42 HD Request # 3359 | Intraday data download complete for CAD-X. Unique request ID: 3964 | 2018-12-05 13:49:42 Removed historical data download ID 3964 | 2018-12-05 13:49:42 Real-time Intraday chart data file updates started for CAD-X | 2018-12-05 13:49:42 Intraday chart data file opened for CAD-X | 2018-12-05 13:49:42 HD Request # 3360 | Downloading Intraday chart data for CHF-X to the file CHF-X.scid. Service: fxstatscalc | 2018-12-05 13:49:42 HD Request # 3360 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:42 HD Request # 3360 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:42 Socket (3) | Creating socket. | 2018-12-05 13:49:42 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:42 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 10048 | 2018-12-05 13:49:42 DTC Client socket (4) | Creating socket. | 2018-12-05 13:49:42 DTC Client socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:49:42 BCHUSD-BITFINEX [M] 15 Min #4 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:42 HD Request # 3360 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:42 HD Request # 3360 | Sending historical data logon request message. | 2018-12-05 13:49:42 Chart #4 has tagged chart #8 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:42 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:49:42 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:49:42 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:42 BCHUSD-BITFINEX [M] 1 Min #8 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:42 DTC Client socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:42 DTC Client socket (4) | Received socket Close event. | 2018-12-05 13:49:42 HD Request # 3360 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: CHF-X | 2018-12-05 13:49:42 HD Request # 3360 | Decompressing data. | 2018-12-05 13:49:42 HD Request # 3360 | Receiving Intraday data for CHF-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:42 HD Request # 3360 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:42 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:42 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:42 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:43 Socket (3) | Closed. | 2018-12-05 13:49:43 DTC Client socket (4) | Signaling for receive thread to end. Bytes in receive buffer: 111 | 2018-12-05 13:49:45 DTC Client socket (4) | Signaling to core to close socket | 2018-12-05 13:49:45 DTC Client socket (4) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:45 DTC Client socket (4) | Closed. | 2018-12-05 13:49:45 Historical data download thread signaled to stop. | 2018-12-05 13:49:45 HD Request # 3360 | Received 7 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:38 (24.0 seconds) and wrote 6 records for CHF-X | 2018-12-05 13:49:45 Added 1 Time and Sales records to Intraday data file for CHF-X after download. | 2018-12-05 13:49:45 HD Request # 3360 | Completion time: 4s | 2018-12-05 13:49:45 HD Request # 3360 | Intraday data download complete for CHF-X. Unique request ID: 3965 | 2018-12-05 13:49:45 Removed historical data download ID 3965 | 2018-12-05 13:49:45 Real-time Intraday chart data file updates started for CHF-X | 2018-12-05 13:49:45 Intraday chart data file opened for CHF-X | 2018-12-05 13:49:45 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:45 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:45 DTC Client socket (0) | Ignored Send call based on current state. | 2018-12-05 13:49:45 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:49:45 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:45 HD Request # 3361 | Downloading Intraday chart data for DSHUSD-BITFINEX to the file DSHUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:45 HD Request # 3361 | Download start date-time: 2018-12-05 13:48:28.000 | 2018-12-05 13:49:45 HD Request # 3361 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:45 Socket (3) | Creating socket. | 2018-12-05 13:49:45 Socket (3) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:45 BCHUSD-BITFINEX [M] Daily #1 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:45 Chart #1 has tagged chart #3 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:45 BCHUSD-BITFINEX [M] 60 Min #3 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:45 HD Request # 3361 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:45 HD Request # 3361 | Sending historical data logon request message. | 2018-12-05 13:49:45 Chart #3 has tagged chart #5 for full recalculation. Chartbook: MT.Cht | 2018-12-05 13:49:45 BCHUSD-BITFINEX [M] 5 Min #5 | Performing a full recalculation because it has been tagged. Chartbook: MT.Cht | 2018-12-05 13:49:46 HD Request # 3361 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:28. Record interval: 0. Symbol: DSHUSD-BITFINEX | 2018-12-05 13:49:46 HD Request # 3361 | Decompressing data. | 2018-12-05 13:49:46 HD Request # 3361 | Receiving Intraday data for DSHUSD-BITFINEX starting at 2018-12-05 13:48:28 | 2018-12-05 13:49:46 HD Request # 3361 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:27 | 2018-12-05 13:49:46 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:46 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:46 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:46 Socket (3) | Closed. | 2018-12-05 13:49:46 Historical data download thread signaled to stop. | 2018-12-05 13:49:46 HD Request # 3361 | Received 3 records from 2018-12-05 13:48:28 to 2018-12-05 13:49:27 (59.0 seconds) and wrote 1 record for DSHUSD-BITFINEX | 2018-12-05 13:49:46 HD Request # 3361 | Completion time: 0s | 2018-12-05 13:49:46 HD Request # 3361 | Intraday data download complete for DSHUSD-BITFINEX. Unique request ID: 3966 | 2018-12-05 13:49:46 Removed historical data download ID 3966 | 2018-12-05 13:49:46 Real-time Intraday chart data file updates started for DSHUSD-BITFINEX | 2018-12-05 13:49:46 Intraday chart data file opened for DSHUSD-BITFINEX | 2018-12-05 13:49:46 HD Request # 3362 | Downloading Intraday chart data for EOSUSD-BITFINEX to the file EOSUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:46 HD Request # 3362 | Download start date-time: 2018-12-05 13:48:15.000 | 2018-12-05 13:49:46 HD Request # 3362 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:46 Socket (3) | Creating socket. | 2018-12-05 13:49:46 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:46 HD Request # 3362 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:47 HD Request # 3362 | Sending historical data logon request message. | 2018-12-05 13:49:47 HD Request # 3362 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:15. Record interval: 0. Symbol: EOSUSD-BITFINEX | 2018-12-05 13:49:47 HD Request # 3362 | Decompressing data. | 2018-12-05 13:49:47 HD Request # 3362 | Receiving Intraday data for EOSUSD-BITFINEX starting at 2018-12-05 13:48:15 | 2018-12-05 13:49:47 HD Request # 3362 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:21 | 2018-12-05 13:49:47 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:47 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:47 Historical data download thread signaled to stop. | 2018-12-05 13:49:47 HD Request # 3362 | Received 12 records from 2018-12-05 13:48:15 to 2018-12-05 13:49:22 (67.0 seconds) and wrote 5 records for EOSUSD-BITFINEX | 2018-12-05 13:49:47 HD Request # 3362 | Completion time: 1s | 2018-12-05 13:49:47 HD Request # 3362 | Intraday data download complete for EOSUSD-BITFINEX. Unique request ID: 3967 | 2018-12-05 13:49:47 Removed historical data download ID 3967 | 2018-12-05 13:49:47 Real-time Intraday chart data file updates started for EOSUSD-BITFINEX | 2018-12-05 13:49:47 Intraday chart data file opened for EOSUSD-BITFINEX | 2018-12-05 13:49:47 HD Request # 3363 | Downloading Intraday chart data for ETCUSD-BITFINEX to the file ETCUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:47 HD Request # 3363 | Download start date-time: 2018-12-05 13:49:12.000 | 2018-12-05 13:49:47 HD Request # 3363 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:47 Socket (4) | Creating socket. | 2018-12-05 13:49:47 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 443 | 2018-12-05 13:49:47 DTC Client socket (5) | Creating socket. | 2018-12-05 13:49:47 DTC Client socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:47 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:47 Socket (3) | Closed. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Received logon response. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Server Name: SC Real-Time Server. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Logon error received from server: No data service given. | 2018-12-05 13:49:47 DTC Client socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:47 DTC Client socket (5) | Received socket Close event. | 2018-12-05 13:49:47 DTC Client socket (5) | Signaling to core to close socket | 2018-12-05 13:49:47 DTC Client socket (5) | Write in progress. Shutdown being delayed. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Disconnected from the server. | 2018-12-05 13:49:47 LMAX Live Trading - DTC (Data) | Data feed disconnected. Will reconnect in 2 seconds. | 2018-12-05 13:49:47 DTC Client socket (5) | Write has completed. Shutdown being performed. | 2018-12-05 13:49:47 DTC Client socket (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-12-05 13:49:47 DTC Client socket (5) | Closed. | 2018-12-05 13:49:47 Opened cached Intraday file: C:\SierraChart\Data\CAD-X.scid | 2018-12-05 13:49:47 Opened cached Intraday file: C:\SierraChart\Data\CHF-X.scid | 2018-12-05 13:49:47 Opened cached Intraday file: C:\SierraChart\Data\BTGUSD-BITFINEX.scid | 2018-12-05 13:49:47 HD Request # 3363 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:48 HD Request # 3363 | Sending historical data logon request message. | 2018-12-05 13:49:48 HD Request # 3363 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:12. Record interval: 0. Symbol: ETCUSD-BITFINEX | 2018-12-05 13:49:48 HD Request # 3363 | Decompressing data. | 2018-12-05 13:49:48 HD Request # 3363 | Receiving Intraday data for ETCUSD-BITFINEX starting at 2018-12-05 13:49:12 | 2018-12-05 13:49:48 HD Request # 3363 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:38 | 2018-12-05 13:49:48 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:48 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:48 Historical data download thread signaled to stop. | 2018-12-05 13:49:48 HD Request # 3363 | Received 3 records from 2018-12-05 13:49:12 to 2018-12-05 13:49:38 (26.0 seconds) and wrote 2 records for ETCUSD-BITFINEX | 2018-12-05 13:49:48 HD Request # 3363 | Completion time: 0s | 2018-12-05 13:49:48 HD Request # 3363 | Intraday data download complete for ETCUSD-BITFINEX. Unique request ID: 3968 | 2018-12-05 13:49:48 Removed historical data download ID 3968 | 2018-12-05 13:49:48 Real-time Intraday chart data file updates started for ETCUSD-BITFINEX | 2018-12-05 13:49:48 Intraday chart data file opened for ETCUSD-BITFINEX | 2018-12-05 13:49:48 HD Request # 3364 | Downloading Intraday chart data for ETHUSD-BITFINEX to the file ETHUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:48 HD Request # 3364 | Download start date-time: 2018-12-05 13:49:12.000 | 2018-12-05 13:49:48 HD Request # 3364 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:48 Socket (3) | Creating socket. | 2018-12-05 13:49:48 Socket (3) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:48 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:48 Socket (4) | Closed. | 2018-12-05 13:49:48 HD Request # 3364 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:48 HD Request # 3364 | Sending historical data logon request message. | 2018-12-05 13:49:48 HD Request # 3364 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:12. Record interval: 0. Symbol: ETHUSD-BITFINEX | 2018-12-05 13:49:49 HD Request # 3364 | Decompressing data. | 2018-12-05 13:49:49 HD Request # 3364 | Receiving Intraday data for ETHUSD-BITFINEX starting at 2018-12-05 13:49:12 | 2018-12-05 13:49:49 HD Request # 3364 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:49 Socket (3) | Signaling to core to close socket | 2018-12-05 13:49:49 Socket (3) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:49 Historical data download thread signaled to stop. | 2018-12-05 13:49:49 HD Request # 3364 | Received 4 records from 2018-12-05 13:49:12 to 2018-12-05 13:49:39 (27.0 seconds) and wrote 3 records for ETHUSD-BITFINEX | 2018-12-05 13:49:49 HD Request # 3364 | Completion time: 0s | 2018-12-05 13:49:49 HD Request # 3364 | Intraday data download complete for ETHUSD-BITFINEX. Unique request ID: 3969 | 2018-12-05 13:49:49 Removed historical data download ID 3969 | 2018-12-05 13:49:49 Real-time Intraday chart data file updates started for ETHUSD-BITFINEX | 2018-12-05 13:49:49 Intraday chart data file opened for ETHUSD-BITFINEX | 2018-12-05 13:49:49 HD Request # 3365 | Downloading Intraday chart data for EUR-X to the file EUR-X.scid. Service: fxstatscalc | 2018-12-05 13:49:49 HD Request # 3365 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:49 HD Request # 3365 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:49 Socket (4) | Creating socket. | 2018-12-05 13:49:49 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:49 Socket (3) | Socket gracefully closed by remote side. | 2018-12-05 13:49:49 Socket (3) | Closed. | 2018-12-05 13:49:49 HD Request # 3365 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:49 HD Request # 3365 | Sending historical data logon request message. | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Connecting to the server lmaxrt.sierracharts.com. Port 443 | 2018-12-05 13:49:49 DTC Client socket (3) | Creating socket. | 2018-12-05 13:49:49 DTC Client socket (3) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:49:49 HD Request # 3365 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: EUR-X | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Connected to server. | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Starting socket receive thread. | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Sending encoding request to server: Binary VLS | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:49 LMAX Live Trading - DTC (Data) | Sending logon request message. | 2018-12-05 13:49:49 HD Request # 3365 | Decompressing data. | 2018-12-05 13:49:49 HD Request # 3365 | Receiving Intraday data for EUR-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:49 HD Request # 3365 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:49 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:49 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:49 Historical data download thread signaled to stop. | 2018-12-05 13:49:49 HD Request # 3365 | Received 9 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:46 (32.0 seconds) and wrote 8 records for EUR-X | 2018-12-05 13:49:49 HD Request # 3365 | Completion time: 0s | 2018-12-05 13:49:49 HD Request # 3365 | Intraday data download complete for EUR-X. Unique request ID: 3970 | 2018-12-05 13:49:49 Removed historical data download ID 3970 | 2018-12-05 13:49:49 Real-time Intraday chart data file updates started for EUR-X | 2018-12-05 13:49:49 Intraday chart data file opened for EUR-X | 2018-12-05 13:49:49 HD Request # 3366 | Downloading Intraday chart data for GBP-X to the file GBP-X.scid. Service: fxstatscalc | 2018-12-05 13:49:49 HD Request # 3366 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:49 HD Request # 3366 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:49 Socket (5) | Creating socket. | 2018-12-05 13:49:49 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:49 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:50 Socket (4) | Closed. | 2018-12-05 13:49:50 HD Request # 3366 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:50 HD Request # 3366 | Sending historical data logon request message. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received logon response. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Server Name: SC Realtime Server. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Server protocol version: 8. Client protocol version: 8 | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Successfully connected. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Trading is not supported. | 2018-12-05 13:49:50 Intraday data recording state for symbol $TNX is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: $TNX | 2018-12-05 13:49:50 Intraday data recording state for symbol AUDCAD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDCAD | 2018-12-05 13:49:50 Intraday data recording state for symbol AUDCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol AUDJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol AUDNZD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDNZD | 2018-12-05 13:49:50 Intraday data recording state for symbol AUDUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: AUDUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol CADCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: CADCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol CADJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: CADJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol CHFJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: CHFJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol EURAUD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURAUD | 2018-12-05 13:49:50 Intraday data recording state for symbol EURCAD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURCAD | 2018-12-05 13:49:50 Intraday data recording state for symbol EURCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol EURGBP is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURGBP | 2018-12-05 13:49:50 Intraday data recording state for symbol EURJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol EURNZD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURNZD | 2018-12-05 13:49:50 Intraday data recording state for symbol EURTRY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURTRY | 2018-12-05 13:49:50 Intraday data recording state for symbol EURUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: EURUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPAUD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPAUD | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPCAD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPCAD | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPNZD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPNZD | 2018-12-05 13:49:50 Intraday data recording state for symbol GBPUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GBPUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol GDAXI is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: GDAXI | 2018-12-05 13:49:50 Intraday data recording state for symbol HSI is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: HSI | 2018-12-05 13:49:50 Intraday data recording state for symbol J225 is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: J225 | 2018-12-05 13:49:50 Intraday data recording state for symbol NZDCAD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDCAD | 2018-12-05 13:49:50 Intraday data recording state for symbol NZDCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol NZDJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol NZDUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: NZDUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol SPX is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: SPX | 2018-12-05 13:49:50 Intraday data recording state for symbol STOXX50E is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: STOXX50E | 2018-12-05 13:49:50 Intraday data recording state for symbol UK100 is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: UK100 | 2018-12-05 13:49:50 Intraday data recording state for symbol USDCAD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: USDCAD | 2018-12-05 13:49:50 Intraday data recording state for symbol USDCHF is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: USDCHF | 2018-12-05 13:49:50 Intraday data recording state for symbol USDJPY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: USDJPY | 2018-12-05 13:49:50 Intraday data recording state for symbol USDTRY is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: USDTRY | 2018-12-05 13:49:50 Intraday data recording state for symbol USDZAR is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: USDZAR | 2018-12-05 13:49:50 Intraday data recording state for symbol WS30 is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: WS30 | 2018-12-05 13:49:50 Intraday data recording state for symbol XAGUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XAGUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XAUUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XAUUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XBRUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XBRUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XNGUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XNGUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XPDUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XPDUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XPTUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XPTUSD | 2018-12-05 13:49:50 Intraday data recording state for symbol XTIUSD is set to download 'Pending'. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Restarting real-time data updates for symbol: XTIUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Real-time data for symbol $TNX is currently unavailable. | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol AUDCAD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol AUDCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol AUDJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol AUDNZD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol AUDUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol CADCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol CADJPY | 2018-12-05 13:49:50 HD Request # 3366 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: GBP-X | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol CHFJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURAUD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURCAD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURGBP | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURNZD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURTRY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol EURUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPAUD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPCAD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPNZD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GBPUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol GDAXI | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol HSI | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol J225 | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol NZDCAD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol NZDCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol NZDJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol NZDUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol SPX | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol STOXX50E | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol UK100 | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol USDCAD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol USDCHF | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol USDJPY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol USDTRY | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol USDZAR | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol WS30 | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XAGUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XAUUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XBRUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XNGUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XPDUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XPTUSD | 2018-12-05 13:49:50 LMAX Live Trading - DTC (Data) | Received security definition for symbol XTIUSD | 2018-12-05 13:49:50 HD Request # 3366 | Decompressing data. | 2018-12-05 13:49:50 HD Request # 3366 | Receiving Intraday data for GBP-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:50 HD Request # 3366 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:50 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:50 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:50 Historical data download thread signaled to stop. | 2018-12-05 13:49:50 HD Request # 3366 | Received 9 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:46 (32.0 seconds) and wrote 8 records for GBP-X | 2018-12-05 13:49:50 HD Request # 3366 | Completion time: 0s | 2018-12-05 13:49:50 HD Request # 3366 | Intraday data download complete for GBP-X. Unique request ID: 3971 | 2018-12-05 13:49:50 Removed historical data download ID 3971 | 2018-12-05 13:49:50 Real-time Intraday chart data file updates started for GBP-X | 2018-12-05 13:49:50 Intraday chart data file opened for GBP-X | 2018-12-05 13:49:50 HD Request # 3367 | Downloading Intraday chart data for IOTUSD-BITFINEX to the file IOTUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:50 HD Request # 3367 | Download start date-time: 2018-12-05 13:48:37.000 | 2018-12-05 13:49:50 HD Request # 3367 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:50 Socket (4) | Creating socket. | 2018-12-05 13:49:50 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:50 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:50 Socket (5) | Closed. | 2018-12-05 13:49:50 HD Request # 3367 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:51 HD Request # 3367 | Sending historical data logon request message. | 2018-12-05 13:49:51 HD Request # 3367 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:37. Record interval: 0. Symbol: IOTUSD-BITFINEX | 2018-12-05 13:49:51 HD Request # 3367 | Decompressing data. | 2018-12-05 13:49:51 HD Request # 3367 | Receiving Intraday data for IOTUSD-BITFINEX starting at 2018-12-05 13:49:39 | 2018-12-05 13:49:51 HD Request # 3367 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:39 | 2018-12-05 13:49:51 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:51 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:51 Historical data download thread signaled to stop. | 2018-12-05 13:49:51 HD Request # 3367 | Received 12 records from 2018-12-05 13:49:39 to 2018-12-05 13:49:39 (0.0 seconds) and wrote 12 records for IOTUSD-BITFINEX | 2018-12-05 13:49:51 HD Request # 3367 | Completion time: 0s | 2018-12-05 13:49:51 HD Request # 3367 | Intraday data download complete for IOTUSD-BITFINEX. Unique request ID: 3972 | 2018-12-05 13:49:51 Removed historical data download ID 3972 | 2018-12-05 13:49:51 Real-time Intraday chart data file updates started for IOTUSD-BITFINEX | 2018-12-05 13:49:51 Intraday chart data file opened for IOTUSD-BITFINEX | 2018-12-05 13:49:51 HD Request # 3368 | Downloading Intraday chart data for JPY-X to the file JPY-X.scid. Service: fxstatscalc | 2018-12-05 13:49:51 HD Request # 3368 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:51 HD Request # 3368 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:51 Socket (5) | Creating socket. | 2018-12-05 13:49:51 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:51 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:51 Socket (4) | Closed. | 2018-12-05 13:49:51 HD Request # 3368 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:51 HD Request # 3368 | Sending historical data logon request message. | 2018-12-05 13:49:51 HD Request # 3368 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: JPY-X | 2018-12-05 13:49:52 HD Request # 3368 | Decompressing data. | 2018-12-05 13:49:52 HD Request # 3368 | Receiving Intraday data for JPY-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:52 HD Request # 3368 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:52 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:52 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:52 Historical data download thread signaled to stop. | 2018-12-05 13:49:52 HD Request # 3368 | Received 9 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:46 (32.0 seconds) and wrote 8 records for JPY-X | 2018-12-05 13:49:52 Added 1 Time and Sales records to Intraday data file for JPY-X after download. | 2018-12-05 13:49:52 HD Request # 3368 | Completion time: 0s | 2018-12-05 13:49:52 HD Request # 3368 | Intraday data download complete for JPY-X. Unique request ID: 3973 | 2018-12-05 13:49:52 Removed historical data download ID 3973 | 2018-12-05 13:49:52 Real-time Intraday chart data file updates started for JPY-X | 2018-12-05 13:49:52 Intraday chart data file opened for JPY-X | 2018-12-05 13:49:52 HD Request # 3369 | Downloading Intraday chart data for LTCUSD-BITFINEX to the file LTCUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:52 HD Request # 3369 | Download start date-time: 2018-12-05 13:49:00.000 | 2018-12-05 13:49:52 HD Request # 3369 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:52 Socket (4) | Creating socket. | 2018-12-05 13:49:52 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:52 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:52 Socket (5) | Closed. | 2018-12-05 13:49:52 HD Request # 3369 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:52 HD Request # 3369 | Sending historical data logon request message. | 2018-12-05 13:49:52 HD Request # 3369 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:00. Record interval: 0. Symbol: LTCUSD-BITFINEX | 2018-12-05 13:49:52 HD Request # 3369 | Decompressing data. | 2018-12-05 13:49:53 HD Request # 3369 | Receiving Intraday data for LTCUSD-BITFINEX starting at 2018-12-05 13:49:00 | 2018-12-05 13:49:53 HD Request # 3369 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:21 | 2018-12-05 13:49:53 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:53 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:53 Historical data download thread signaled to stop. | 2018-12-05 13:49:53 HD Request # 3369 | Received 3 records from 2018-12-05 13:49:00 to 2018-12-05 13:49:21 (21.0 seconds) and wrote 1 record for LTCUSD-BITFINEX | 2018-12-05 13:49:53 HD Request # 3369 | Completion time: 1s | 2018-12-05 13:49:53 HD Request # 3369 | Intraday data download complete for LTCUSD-BITFINEX. Unique request ID: 3974 | 2018-12-05 13:49:53 Removed historical data download ID 3974 | 2018-12-05 13:49:53 Real-time Intraday chart data file updates started for LTCUSD-BITFINEX | 2018-12-05 13:49:53 Intraday chart data file opened for LTCUSD-BITFINEX | 2018-12-05 13:49:53 HD Request # 3370 | Downloading Intraday chart data for MKRUSD-BITFINEX to the file MKRUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:53 HD Request # 3370 | Download start date-time: 2018-09-24 19:51:59.000 | 2018-12-05 13:49:53 HD Request # 3370 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:53 Socket (5) | Creating socket. | 2018-12-05 13:49:53 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:53 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:53 Socket (4) | Closed. | 2018-12-05 13:49:53 HD Request # 3370 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:53 HD Request # 3370 | Sending historical data logon request message. | 2018-12-05 13:49:53 HD Request # 3370 | Requesting Intraday data. Start date-time: 2018-09-24 19:51:59. Record interval: 0. Symbol: MKRUSD-BITFINEX | 2018-12-05 13:49:53 HD Request # 3370 | Decompressing data. | 2018-12-05 13:49:53 HD Request # 3370 | Receiving Intraday data for MKRUSD-BITFINEX starting at 2018-09-24 19:51:59 | 2018-12-05 13:49:53 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:53 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:53 Historical data download thread signaled to stop. | 2018-12-05 13:49:53 HD Request # 3370 | Received 1 record from 2018-09-24 19:51:59 to 2018-09-24 19:51:59 (0.0 seconds) and wrote 0 records for MKRUSD-BITFINEX | 2018-12-05 13:49:53 HD Request # 3370 | Completion time: 0s | 2018-12-05 13:49:53 HD Request # 3370 | Intraday data download complete for MKRUSD-BITFINEX. Unique request ID: 3975 | 2018-12-05 13:49:53 Removed historical data download ID 3975 | 2018-12-05 13:49:53 Real-time Intraday chart data file updates started for MKRUSD-BITFINEX | 2018-12-05 13:49:53 Intraday chart data file opened for MKRUSD-BITFINEX | 2018-12-05 13:49:53 HD Request # 3371 | Downloading Intraday chart data for NEOUSD-BITFINEX to the file NEOUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:53 HD Request # 3371 | Download start date-time: 2018-12-05 13:48:32.000 | 2018-12-05 13:49:53 HD Request # 3371 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:53 Socket (4) | Creating socket. | 2018-12-05 13:49:53 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:53 Opened cached Intraday file: C:\SierraChart\Data\EUR-X.scid | 2018-12-05 13:49:53 Opened cached Intraday file: C:\SierraChart\Data\GBP-X.scid | 2018-12-05 13:49:53 Opened cached Intraday file: C:\SierraChart\Data\IOTUSD-BITFINEX.scid | 2018-12-05 13:49:53 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:53 Socket (5) | Closed. | 2018-12-05 13:49:53 HD Request # 3371 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:54 HD Request # 3371 | Sending historical data logon request message. | 2018-12-05 13:49:54 HD Request # 3371 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:32. Record interval: 0. Symbol: NEOUSD-BITFINEX | 2018-12-05 13:49:54 HD Request # 3371 | Decompressing data. | 2018-12-05 13:49:54 HD Request # 3371 | Receiving Intraday data for NEOUSD-BITFINEX starting at 2018-12-05 13:48:32 | 2018-12-05 13:49:54 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:54 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:54 Historical data download thread signaled to stop. | 2018-12-05 13:49:54 HD Request # 3371 | Received 8 records from 2018-12-05 13:48:32 to 2018-12-05 13:48:32 (0.0 seconds) and wrote 0 records for NEOUSD-BITFINEX | 2018-12-05 13:49:54 HD Request # 3371 | Completion time: 0s | 2018-12-05 13:49:54 HD Request # 3371 | Intraday data download complete for NEOUSD-BITFINEX. Unique request ID: 3976 | 2018-12-05 13:49:54 Removed historical data download ID 3976 | 2018-12-05 13:49:54 Real-time Intraday chart data file updates started for NEOUSD-BITFINEX | 2018-12-05 13:49:54 Intraday chart data file opened for NEOUSD-BITFINEX | 2018-12-05 13:49:54 HD Request # 3372 | Downloading Intraday chart data for NZD-X to the file NZD-X.scid. Service: fxstatscalc | 2018-12-05 13:49:54 HD Request # 3372 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:54 HD Request # 3372 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:54 Socket (5) | Creating socket. | 2018-12-05 13:49:54 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:54 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:54 Socket (4) | Closed. | 2018-12-05 13:49:54 HD Request # 3372 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:54 HD Request # 3372 | Sending historical data logon request message. | 2018-12-05 13:49:54 HD Request # 3372 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: NZD-X | 2018-12-05 13:49:55 HD Request # 3372 | Decompressing data. | 2018-12-05 13:49:55 HD Request # 3372 | Receiving Intraday data for NZD-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:55 HD Request # 3372 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:55 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:55 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:55 Historical data download thread signaled to stop. | 2018-12-05 13:49:55 HD Request # 3372 | Received 10 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:50 (36.0 seconds) and wrote 9 records for NZD-X | 2018-12-05 13:49:55 HD Request # 3372 | Completion time: 0s | 2018-12-05 13:49:55 HD Request # 3372 | Intraday data download complete for NZD-X. Unique request ID: 3977 | 2018-12-05 13:49:55 Removed historical data download ID 3977 | 2018-12-05 13:49:55 Real-time Intraday chart data file updates started for NZD-X | 2018-12-05 13:49:55 Intraday chart data file opened for NZD-X | 2018-12-05 13:49:55 HD Request # 3373 | Downloading Intraday chart data for OMGUSD-BITFINEX to the file OMGUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:55 HD Request # 3373 | Download start date-time: 2018-12-05 13:45:24.000 | 2018-12-05 13:49:55 HD Request # 3373 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:55 Socket (4) | Creating socket. | 2018-12-05 13:49:55 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:55 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:55 Socket (5) | Closed. | 2018-12-05 13:49:55 HD Request # 3373 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:55 HD Request # 3373 | Sending historical data logon request message. | 2018-12-05 13:49:55 HD Request # 3373 | Requesting Intraday data. Start date-time: 2018-12-05 13:45:24. Record interval: 0. Symbol: OMGUSD-BITFINEX | 2018-12-05 13:49:55 HD Request # 3373 | Decompressing data. | 2018-12-05 13:49:55 HD Request # 3373 | Receiving Intraday data for OMGUSD-BITFINEX starting at 2018-12-05 13:45:24 | 2018-12-05 13:49:55 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:55 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:55 Historical data download thread signaled to stop. | 2018-12-05 13:49:55 HD Request # 3373 | Received 1 record from 2018-12-05 13:45:24 to 2018-12-05 13:45:24 (0.0 seconds) and wrote 0 records for OMGUSD-BITFINEX | 2018-12-05 13:49:55 HD Request # 3373 | Completion time: 0s | 2018-12-05 13:49:55 HD Request # 3373 | Intraday data download complete for OMGUSD-BITFINEX. Unique request ID: 3978 | 2018-12-05 13:49:55 Removed historical data download ID 3978 | 2018-12-05 13:49:55 Real-time Intraday chart data file updates started for OMGUSD-BITFINEX | 2018-12-05 13:49:55 Intraday chart data file opened for OMGUSD-BITFINEX | 2018-12-05 13:49:55 HD Request # 3374 | Downloading Intraday chart data for QTMUSD-BITFINEX to the file QTMUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:55 HD Request # 3374 | Download start date-time: 2018-12-05 12:17:39.000 | 2018-12-05 13:49:55 HD Request # 3374 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:55 Socket (5) | Creating socket. | 2018-12-05 13:49:55 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:55 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:56 Socket (4) | Closed. | 2018-12-05 13:49:56 HD Request # 3374 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:56 HD Request # 3374 | Sending historical data logon request message. | 2018-12-05 13:49:56 HD Request # 3374 | Requesting Intraday data. Start date-time: 2018-12-05 12:17:39. Record interval: 0. Symbol: QTMUSD-BITFINEX | 2018-12-05 13:49:56 HD Request # 3374 | Decompressing data. | 2018-12-05 13:49:56 HD Request # 3374 | Receiving Intraday data for QTMUSD-BITFINEX starting at 2018-12-05 12:17:39 | 2018-12-05 13:49:56 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:56 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:56 Historical data download thread signaled to stop. | 2018-12-05 13:49:56 HD Request # 3374 | Received 1 record from 2018-12-05 12:17:39 to 2018-12-05 12:17:39 (0.0 seconds) and wrote 0 records for QTMUSD-BITFINEX | 2018-12-05 13:49:56 HD Request # 3374 | Completion time: 1s | 2018-12-05 13:49:56 HD Request # 3374 | Intraday data download complete for QTMUSD-BITFINEX. Unique request ID: 3979 | 2018-12-05 13:49:56 Removed historical data download ID 3979 | 2018-12-05 13:49:56 Real-time Intraday chart data file updates started for QTMUSD-BITFINEX | 2018-12-05 13:49:56 Intraday chart data file opened for QTMUSD-BITFINEX | 2018-12-05 13:49:56 HD Request # 3375 | Downloading Intraday chart data for TRXUSD-BITFINEX to the file TRXUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:56 HD Request # 3375 | Download start date-time: 2018-12-05 13:48:08.000 | 2018-12-05 13:49:56 HD Request # 3375 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:56 Socket (4) | Creating socket. | 2018-12-05 13:49:56 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:56 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:56 Socket (5) | Closed. | 2018-12-05 13:49:56 HD Request # 3375 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:56 HD Request # 3375 | Sending historical data logon request message. | 2018-12-05 13:49:56 Opened cached Intraday file: C:\SierraChart\Data\JPY-X.scid | 2018-12-05 13:49:56 Opened cached Intraday file: C:\SierraChart\Data\NZD-X.scid | 2018-12-05 13:49:56 HD Request # 3375 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:08. Record interval: 0. Symbol: TRXUSD-BITFINEX | 2018-12-05 13:49:57 HD Request # 3375 | Decompressing data. | 2018-12-05 13:49:57 HD Request # 3375 | Receiving Intraday data for TRXUSD-BITFINEX starting at 2018-12-05 13:49:25 | 2018-12-05 13:49:57 HD Request # 3375 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:25 | 2018-12-05 13:49:57 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:57 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:57 Historical data download thread signaled to stop. | 2018-12-05 13:49:57 HD Request # 3375 | Received 1 record from 2018-12-05 13:49:25 to 2018-12-05 13:49:25 (0.0 seconds) and wrote 1 record for TRXUSD-BITFINEX | 2018-12-05 13:49:57 HD Request # 3375 | Completion time: 0s | 2018-12-05 13:49:57 HD Request # 3375 | Intraday data download complete for TRXUSD-BITFINEX. Unique request ID: 3980 | 2018-12-05 13:49:57 Removed historical data download ID 3980 | 2018-12-05 13:49:57 Real-time Intraday chart data file updates started for TRXUSD-BITFINEX | 2018-12-05 13:49:57 Intraday chart data file opened for TRXUSD-BITFINEX | 2018-12-05 13:49:57 HD Request # 3376 | Downloading Intraday chart data for USD-X to the file USD-X.scid. Service: fxstatscalc | 2018-12-05 13:49:57 HD Request # 3376 | Download start date-time: 2018-12-05 13:49:14.000 | 2018-12-05 13:49:57 HD Request # 3376 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:57 Socket (5) | Creating socket. | 2018-12-05 13:49:57 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:57 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:57 Socket (4) | Closed. | 2018-12-05 13:49:57 HD Request # 3376 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:57 HD Request # 3376 | Sending historical data logon request message. | 2018-12-05 13:49:57 HD Request # 3376 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:14. Record interval: 0. Symbol: USD-X | 2018-12-05 13:49:57 HD Request # 3376 | Decompressing data. | 2018-12-05 13:49:58 HD Request # 3376 | Receiving Intraday data for USD-X starting at 2018-12-05 13:49:14 | 2018-12-05 13:49:58 HD Request # 3376 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:18 | 2018-12-05 13:49:58 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:58 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:58 Historical data download thread signaled to stop. | 2018-12-05 13:49:58 HD Request # 3376 | Received 11 records from 2018-12-05 13:49:14 to 2018-12-05 13:49:54 (40.0 seconds) and wrote 10 records for USD-X | 2018-12-05 13:49:58 HD Request # 3376 | Completion time: 1s | 2018-12-05 13:49:58 HD Request # 3376 | Intraday data download complete for USD-X. Unique request ID: 3981 | 2018-12-05 13:49:58 Removed historical data download ID 3981 | 2018-12-05 13:49:58 Real-time Intraday chart data file updates started for USD-X | 2018-12-05 13:49:58 Intraday chart data file opened for USD-X | 2018-12-05 13:49:58 HD Request # 3377 | Downloading Intraday chart data for USDX to the file USDX.scid. Service: fxstatscalc | 2018-12-05 13:49:58 HD Request # 3377 | Download start date-time: 2018-12-05 13:49:16.000 | 2018-12-05 13:49:58 HD Request # 3377 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:58 Socket (4) | Creating socket. | 2018-12-05 13:49:58 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:58 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:58 Socket (5) | Closed. | 2018-12-05 13:49:58 HD Request # 3377 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:58 HD Request # 3377 | Sending historical data logon request message. | 2018-12-05 13:49:58 HD Request # 3377 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:16. Record interval: 0. Symbol: USDX | 2018-12-05 13:49:58 HD Request # 3377 | Decompressing data. | 2018-12-05 13:49:58 HD Request # 3377 | Receiving Intraday data for USDX starting at 2018-12-05 13:49:16 | 2018-12-05 13:49:58 HD Request # 3377 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:17 | 2018-12-05 13:49:58 Socket (4) | Signaling to core to close socket | 2018-12-05 13:49:58 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:58 Historical data download thread signaled to stop. | 2018-12-05 13:49:58 HD Request # 3377 | Received 40 records from 2018-12-05 13:49:16 to 2018-12-05 13:49:56 (40.0 seconds) and wrote 39 records for USDX | 2018-12-05 13:49:58 Added 3 Time and Sales records to Intraday data file for USDX after download. | 2018-12-05 13:49:58 HD Request # 3377 | Completion time: 1s | 2018-12-05 13:49:58 HD Request # 3377 | Intraday data download complete for USDX. Unique request ID: 3982 | 2018-12-05 13:49:58 Removed historical data download ID 3982 | 2018-12-05 13:49:58 Real-time Intraday chart data file updates started for USDX | 2018-12-05 13:49:58 Intraday chart data file opened for USDX | 2018-12-05 13:49:58 HD Request # 3378 | Downloading Intraday chart data for VETUSD-BITFINEX to the file VETUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:58 HD Request # 3378 | Download start date-time: 2018-09-24 20:18:17.000 | 2018-12-05 13:49:58 HD Request # 3378 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:49:58 Socket (5) | Creating socket. | 2018-12-05 13:49:58 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:49:58 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:49:59 Socket (4) | Closed. | 2018-12-05 13:49:59 HD Request # 3378 | Setting DTC encoding to Binary VLS | 2018-12-05 13:49:59 HD Request # 3378 | Sending historical data logon request message. | 2018-12-05 13:49:59 HD Request # 3378 | Requesting Intraday data. Start date-time: 2018-09-24 20:18:17. Record interval: 0. Symbol: VETUSD-BITFINEX | 2018-12-05 13:49:59 HD Request # 3378 | Decompressing data. | 2018-12-05 13:49:59 HD Request # 3378 | Receiving Intraday data for VETUSD-BITFINEX starting at 2018-09-24 20:18:17 | 2018-12-05 13:49:59 Socket (5) | Signaling to core to close socket | 2018-12-05 13:49:59 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:49:59 Historical data download thread signaled to stop. | 2018-12-05 13:49:59 HD Request # 3378 | Received 3 records from 2018-09-24 20:18:17 to 2018-09-24 20:18:17 (0.0 seconds) and wrote 0 records for VETUSD-BITFINEX | 2018-12-05 13:49:59 HD Request # 3378 | Completion time: 0s | 2018-12-05 13:49:59 HD Request # 3378 | Intraday data download complete for VETUSD-BITFINEX. Unique request ID: 3983 | 2018-12-05 13:49:59 Removed historical data download ID 3983 | 2018-12-05 13:49:59 Real-time Intraday chart data file updates started for VETUSD-BITFINEX | 2018-12-05 13:49:59 Intraday chart data file opened for VETUSD-BITFINEX | 2018-12-05 13:49:59 HD Request # 3379 | Downloading Intraday chart data for XLMUSD-BITFINEX to the file XLMUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:49:59 HD Request # 3379 | Download start date-time: 2018-10-18 00:05:08.000 | 2018-12-05 13:49:59 HD Request # 3379 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:49:59 Socket (4) | Creating socket. | 2018-12-05 13:49:59 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:49:59 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:49:59 Socket (5) | Closed. | 2018-12-05 13:49:59 Opened cached Intraday file: C:\SierraChart\Data\USD-X.scid | 2018-12-05 13:49:59 Opened cached Intraday file: C:\SierraChart\Data\USDX.scid | 2018-12-05 13:49:59 HD Request # 3379 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:00 HD Request # 3379 | Sending historical data logon request message. | 2018-12-05 13:50:00 HD Request # 3379 | Requesting Intraday data. Start date-time: 2018-10-18 00:05:08. Record interval: 0. Symbol: XLMUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3379 | Decompressing data. | 2018-12-05 13:50:01 HD Request # 3379 | Receiving Intraday data for XLMUSD-BITFINEX starting at 2018-10-18 00:05:08 | 2018-12-05 13:50:01 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:01 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:01 Historical data download thread signaled to stop. | 2018-12-05 13:50:01 HD Request # 3379 | Received 1 record from 2018-10-18 00:05:08 to 2018-10-18 00:05:08 (0.0 seconds) and wrote 0 records for XLMUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3379 | Completion time: 0s | 2018-12-05 13:50:01 HD Request # 3379 | Intraday data download complete for XLMUSD-BITFINEX. Unique request ID: 3984 | 2018-12-05 13:50:01 Removed historical data download ID 3984 | 2018-12-05 13:50:01 Real-time Intraday chart data file updates started for XLMUSD-BITFINEX | 2018-12-05 13:50:01 Intraday chart data file opened for XLMUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3380 | Downloading Intraday chart data for XMRUSD-BITFINEX to the file XMRUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:50:01 HD Request # 3380 | Download start date-time: 2018-12-05 13:48:44.000 | 2018-12-05 13:50:01 HD Request # 3380 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:50:01 Socket (5) | Creating socket. | 2018-12-05 13:50:01 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:50:01 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:01 Socket (4) | Closed. | 2018-12-05 13:50:01 HD Request # 3380 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:01 HD Request # 3380 | Sending historical data logon request message. | 2018-12-05 13:50:01 HD Request # 3380 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:44. Record interval: 0. Symbol: XMRUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3380 | Decompressing data. | 2018-12-05 13:50:01 HD Request # 3380 | Receiving Intraday data for XMRUSD-BITFINEX starting at 2018-12-05 13:48:44 | 2018-12-05 13:50:01 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:01 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:01 Historical data download thread signaled to stop. | 2018-12-05 13:50:01 HD Request # 3380 | Received 1 record from 2018-12-05 13:48:44 to 2018-12-05 13:48:44 (0.0 seconds) and wrote 0 records for XMRUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3380 | Completion time: 0s | 2018-12-05 13:50:01 HD Request # 3380 | Intraday data download complete for XMRUSD-BITFINEX. Unique request ID: 3985 | 2018-12-05 13:50:01 Removed historical data download ID 3985 | 2018-12-05 13:50:01 Real-time Intraday chart data file updates started for XMRUSD-BITFINEX | 2018-12-05 13:50:01 Intraday chart data file opened for XMRUSD-BITFINEX | 2018-12-05 13:50:01 HD Request # 3381 | Downloading Intraday chart data for XRPUSD-BITFINEX to the file XRPUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:50:01 HD Request # 3381 | Download start date-time: 2018-12-05 13:48:19.000 | 2018-12-05 13:50:01 HD Request # 3381 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:50:01 Socket (4) | Creating socket. | 2018-12-05 13:50:01 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:50:01 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:02 Socket (5) | Closed. | 2018-12-05 13:50:02 HD Request # 3381 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:02 HD Request # 3381 | Sending historical data logon request message. | 2018-12-05 13:50:02 HD Request # 3381 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:19. Record interval: 0. Symbol: XRPUSD-BITFINEX | 2018-12-05 13:50:02 HD Request # 3381 | Decompressing data. | 2018-12-05 13:50:02 HD Request # 3381 | Receiving Intraday data for XRPUSD-BITFINEX starting at 2018-12-05 13:48:19 | 2018-12-05 13:50:02 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:02 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:02 Historical data download thread signaled to stop. | 2018-12-05 13:50:02 HD Request # 3381 | Received 1 record from 2018-12-05 13:48:19 to 2018-12-05 13:48:19 (0.0 seconds) and wrote 0 records for XRPUSD-BITFINEX | 2018-12-05 13:50:02 HD Request # 3381 | Completion time: 1s | 2018-12-05 13:50:02 HD Request # 3381 | Intraday data download complete for XRPUSD-BITFINEX. Unique request ID: 3986 | 2018-12-05 13:50:02 Removed historical data download ID 3986 | 2018-12-05 13:50:02 Real-time Intraday chart data file updates started for XRPUSD-BITFINEX | 2018-12-05 13:50:02 Intraday chart data file opened for XRPUSD-BITFINEX | 2018-12-05 13:50:02 HD Request # 3382 | Downloading Intraday chart data for XTZUSD-BITFINEX to the file XTZUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:50:02 HD Request # 3382 | Download start date-time: 2018-09-24 21:10:40.000 | 2018-12-05 13:50:02 HD Request # 3382 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:50:02 Socket (5) | Creating socket. | 2018-12-05 13:50:02 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:50:02 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:02 Socket (4) | Closed. | 2018-12-05 13:50:02 Opened cached Intraday file: C:\SierraChart\Data\ETHUSD-BITFINEX.scid | 2018-12-05 13:50:02 HD Request # 3382 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:02 HD Request # 3382 | Sending historical data logon request message. | 2018-12-05 13:50:02 HD Request # 3382 | Requesting Intraday data. Start date-time: 2018-09-24 21:10:40. Record interval: 0. Symbol: XTZUSD-BITFINEX | 2018-12-05 13:50:03 HD Request # 3382 | Decompressing data. | 2018-12-05 13:50:03 HD Request # 3382 | Receiving Intraday data for XTZUSD-BITFINEX starting at 2018-09-24 21:10:40 | 2018-12-05 13:50:03 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:03 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:03 Historical data download thread signaled to stop. | 2018-12-05 13:50:03 HD Request # 3382 | Received 1 record from 2018-09-24 21:10:40 to 2018-09-24 21:10:40 (0.0 seconds) and wrote 0 records for XTZUSD-BITFINEX | 2018-12-05 13:50:03 HD Request # 3382 | Completion time: 0s | 2018-12-05 13:50:03 HD Request # 3382 | Intraday data download complete for XTZUSD-BITFINEX. Unique request ID: 3987 | 2018-12-05 13:50:03 Removed historical data download ID 3987 | 2018-12-05 13:50:03 Real-time Intraday chart data file updates started for XTZUSD-BITFINEX | 2018-12-05 13:50:03 Intraday chart data file opened for XTZUSD-BITFINEX | 2018-12-05 13:50:03 HD Request # 3383 | Downloading Intraday chart data for ZECUSD-BITFINEX to the file ZECUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:50:03 HD Request # 3383 | Download start date-time: 2018-12-05 13:49:15.000 | 2018-12-05 13:50:03 HD Request # 3383 | Using server: ds3.sierracharts.com port 10150 | 2018-12-05 13:50:03 Socket (4) | Creating socket. | 2018-12-05 13:50:03 Socket (4) | Connecting to IP: 65.182.172.42. | 2018-12-05 13:50:03 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:03 Socket (5) | Closed. | 2018-12-05 13:50:03 HD Request # 3383 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:03 HD Request # 3383 | Sending historical data logon request message. | 2018-12-05 13:50:03 HD Request # 3383 | Requesting Intraday data. Start date-time: 2018-12-05 13:49:15. Record interval: 0. Symbol: ZECUSD-BITFINEX | 2018-12-05 13:50:03 HD Request # 3383 | Decompressing data. | 2018-12-05 13:50:04 HD Request # 3383 | Receiving Intraday data for ZECUSD-BITFINEX starting at 2018-12-05 12:49:35 | 2018-12-05 13:50:04 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:04 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:04 Historical data download thread signaled to stop. | 2018-12-05 13:50:04 HD Request # 3383 | Received 96 records from 2018-12-05 12:49:35 to 2018-12-05 13:49:14 (59.7 minutes) and wrote 0 records for ZECUSD-BITFINEX | 2018-12-05 13:50:04 HD Request # 3383 | Completion time: 1s | 2018-12-05 13:50:04 HD Request # 3383 | Intraday data download complete for ZECUSD-BITFINEX. Unique request ID: 3988 | 2018-12-05 13:50:04 Removed historical data download ID 3988 | 2018-12-05 13:50:04 Real-time Intraday chart data file updates started for ZECUSD-BITFINEX | 2018-12-05 13:50:04 Intraday chart data file opened for ZECUSD-BITFINEX | 2018-12-05 13:50:04 HD Request # 3384 | Downloading Intraday chart data for ZRXUSD-BITFINEX to the file ZRXUSD-BITFINEX.scid. Service: bitfinex | 2018-12-05 13:50:04 HD Request # 3384 | Download start date-time: 2018-12-05 13:35:34.000 | 2018-12-05 13:50:04 HD Request # 3384 | Using server: ds4.sierracharts.com port 10149 | 2018-12-05 13:50:04 Socket (5) | Creating socket. | 2018-12-05 13:50:04 Socket (5) | Connecting to IP: 192.81.56.146. | 2018-12-05 13:50:04 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:04 Socket (4) | Closed. | 2018-12-05 13:50:04 HD Request # 3384 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:04 HD Request # 3384 | Sending historical data logon request message. | 2018-12-05 13:50:04 HD Request # 3384 | Requesting Intraday data. Start date-time: 2018-12-05 13:35:34. Record interval: 0. Symbol: ZRXUSD-BITFINEX | 2018-12-05 13:50:04 HD Request # 3384 | Decompressing data. | 2018-12-05 13:50:04 HD Request # 3384 | Receiving Intraday data for ZRXUSD-BITFINEX starting at 2018-12-05 13:35:34 | 2018-12-05 13:50:04 HD Request # 3384 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:36 | 2018-12-05 13:50:04 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:04 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:04 Historical data download thread signaled to stop. | 2018-12-05 13:50:04 HD Request # 3384 | Received 2 records from 2018-12-05 13:35:34 to 2018-12-05 13:49:36 (14.0 minutes) and wrote 1 record for ZRXUSD-BITFINEX | 2018-12-05 13:50:04 HD Request # 3384 | Completion time: 0s | 2018-12-05 13:50:04 HD Request # 3384 | Intraday data download complete for ZRXUSD-BITFINEX. Unique request ID: 3989 | 2018-12-05 13:50:04 Removed historical data download ID 3989 | 2018-12-05 13:50:04 Real-time Intraday chart data file updates started for ZRXUSD-BITFINEX | 2018-12-05 13:50:04 Intraday chart data file opened for ZRXUSD-BITFINEX | 2018-12-05 13:50:04 HD Request # 3385 | Downloading Intraday chart data for $TNX to the file $TNX.scid. Service: cboe.index | 2018-12-05 13:50:04 HD Request # 3385 | Download start date-time: 1991-07-20 14:50:04.000 | 2018-12-05 13:50:04 HD Request # 3385 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:04 Socket (4) | Creating socket. | 2018-12-05 13:50:04 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:04 HD Request # 3385 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:04 HD Request # 3385 | Sending historical data logon request message. | 2018-12-05 13:50:04 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:04 Socket (5) | Closed. | 2018-12-05 13:50:04 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:05 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:05 HD Request # 3385 | Error downloading historical Intraday data for $TNX. Historical data logon error: Data files folder not set for service code: cboe.index | 2018-12-05 13:50:05 Historical data download thread signaled to stop. | 2018-12-05 13:50:05 HD Request # 3385 | Received 0 records from 00:00:00 to 00:00:00 (0.0 seconds) and wrote 0 records for $TNX | 2018-12-05 13:50:05 HD Request # 3385 | Completion time: 0s | 2018-12-05 13:50:05 HD Request # 3385 | Intraday data download complete for $TNX. Unique request ID: 3990 | 2018-12-05 13:50:05 Removed historical data download ID 3990 | 2018-12-05 13:50:05 Real-time Intraday chart data file updates started for $TNX | 2018-12-05 13:50:05 Intraday chart data file opened for $TNX | 2018-12-05 13:50:05 HD Request # 3386 | Downloading Intraday chart data for AUDCAD to the file AUDCAD.scid. Service: lmax | 2018-12-05 13:50:05 HD Request # 3386 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:05 HD Request # 3386 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:05 Socket (5) | Creating socket. | 2018-12-05 13:50:05 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:05 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:05 Socket (4) | Closed. | 2018-12-05 13:50:05 HD Request # 3386 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:05 HD Request # 3386 | Sending historical data logon request message. | 2018-12-05 13:50:05 HD Request # 3386 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: AUDCAD | 2018-12-05 13:50:05 HD Request # 3386 | Decompressing data. | 2018-12-05 13:50:05 HD Request # 3386 | Receiving Intraday data for AUDCAD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:05 HD Request # 3386 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:05 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:05 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:05 Historical data download thread signaled to stop. | 2018-12-05 13:50:05 HD Request # 3386 | Received 104 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:04 (2.0 minutes) and wrote 103 records for AUDCAD | 2018-12-05 13:50:05 HD Request # 3386 | Completion time: 1s | 2018-12-05 13:50:05 HD Request # 3386 | Intraday data download complete for AUDCAD. Unique request ID: 3991 | 2018-12-05 13:50:05 Removed historical data download ID 3991 | 2018-12-05 13:50:05 Real-time Intraday chart data file updates started for AUDCAD | 2018-12-05 13:50:05 Intraday chart data file opened for AUDCAD | 2018-12-05 13:50:05 HD Request # 3387 | Downloading Intraday chart data for AUDCHF to the file AUDCHF.scid. Service: lmax | 2018-12-05 13:50:05 HD Request # 3387 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:05 HD Request # 3387 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:05 Socket (4) | Creating socket. | 2018-12-05 13:50:05 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:05 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:05 Socket (5) | Closed. | 2018-12-05 13:50:05 HD Request # 3387 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:05 HD Request # 3387 | Sending historical data logon request message. | 2018-12-05 13:50:05 HD Request # 3387 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: AUDCHF | 2018-12-05 13:50:06 HD Request # 3387 | Decompressing data. | 2018-12-05 13:50:06 HD Request # 3387 | Receiving Intraday data for AUDCHF starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:06 HD Request # 3387 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:06 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:06 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:06 Historical data download thread signaled to stop. | 2018-12-05 13:50:06 HD Request # 3387 | Received 81 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:03 (2.0 minutes) and wrote 80 records for AUDCHF | 2018-12-05 13:50:06 Added 1 Time and Sales records to Intraday data file for AUDCHF after download. | 2018-12-05 13:50:06 HD Request # 3387 | Completion time: 0s | 2018-12-05 13:50:06 HD Request # 3387 | Intraday data download complete for AUDCHF. Unique request ID: 3992 | 2018-12-05 13:50:06 Removed historical data download ID 3992 | 2018-12-05 13:50:06 Real-time Intraday chart data file updates started for AUDCHF | 2018-12-05 13:50:06 Intraday chart data file opened for AUDCHF | 2018-12-05 13:50:06 HD Request # 3388 | Downloading Intraday chart data for AUDJPY to the file AUDJPY.scid. Service: lmax | 2018-12-05 13:50:06 HD Request # 3388 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:06 HD Request # 3388 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:06 Socket (5) | Creating socket. | 2018-12-05 13:50:06 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:06 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:06 Socket (4) | Closed. | 2018-12-05 13:50:06 HD Request # 3388 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:06 HD Request # 3388 | Sending historical data logon request message. | 2018-12-05 13:50:06 HD Request # 3388 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: AUDJPY | 2018-12-05 13:50:06 HD Request # 3388 | Decompressing data. | 2018-12-05 13:50:06 HD Request # 3388 | Receiving Intraday data for AUDJPY starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:06 HD Request # 3388 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:06 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:06 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:06 Historical data download thread signaled to stop. | 2018-12-05 13:50:06 HD Request # 3388 | Received 211 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:03 (2.0 minutes) and wrote 210 records for AUDJPY | 2018-12-05 13:50:06 Added 3 Time and Sales records to Intraday data file for AUDJPY after download. | 2018-12-05 13:50:06 HD Request # 3388 | Completion time: 0s | 2018-12-05 13:50:06 HD Request # 3388 | Intraday data download complete for AUDJPY. Unique request ID: 3993 | 2018-12-05 13:50:06 Removed historical data download ID 3993 | 2018-12-05 13:50:06 Real-time Intraday chart data file updates started for AUDJPY | 2018-12-05 13:50:06 Intraday chart data file opened for AUDJPY | 2018-12-05 13:50:06 HD Request # 3389 | Downloading Intraday chart data for AUDNZD to the file AUDNZD.scid. Service: lmax | 2018-12-05 13:50:06 HD Request # 3389 | Download start date-time: 2018-12-05 13:47:59.000 | 2018-12-05 13:50:06 HD Request # 3389 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:06 Socket (4) | Creating socket. | 2018-12-05 13:50:06 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:06 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:06 Socket (5) | Closed. | 2018-12-05 13:50:06 HD Request # 3389 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:06 HD Request # 3389 | Sending historical data logon request message. | 2018-12-05 13:50:06 HD Request # 3389 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:59. Record interval: 0. Symbol: AUDNZD | 2018-12-05 13:50:06 HD Request # 3389 | Decompressing data. | 2018-12-05 13:50:07 HD Request # 3389 | Receiving Intraday data for AUDNZD starting at 2018-12-05 13:47:59 | 2018-12-05 13:50:07 HD Request # 3389 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:07 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:07 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:07 Historical data download thread signaled to stop. | 2018-12-05 13:50:07 HD Request # 3389 | Received 195 records from 2018-12-05 13:47:59 to 2018-12-05 13:50:03 (2.1 minutes) and wrote 194 records for AUDNZD | 2018-12-05 13:50:07 Added 3 Time and Sales records to Intraday data file for AUDNZD after download. | 2018-12-05 13:50:07 HD Request # 3389 | Completion time: 0s | 2018-12-05 13:50:07 HD Request # 3389 | Intraday data download complete for AUDNZD. Unique request ID: 3994 | 2018-12-05 13:50:07 Removed historical data download ID 3994 | 2018-12-05 13:50:07 Real-time Intraday chart data file updates started for AUDNZD | 2018-12-05 13:50:07 Intraday chart data file opened for AUDNZD | 2018-12-05 13:50:07 HD Request # 3390 | Downloading Intraday chart data for AUDUSD to the file AUDUSD.scid. Service: lmax | 2018-12-05 13:50:07 HD Request # 3390 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:07 HD Request # 3390 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:07 Socket (5) | Creating socket. | 2018-12-05 13:50:07 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:07 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:07 Socket (4) | Closed. | 2018-12-05 13:50:07 HD Request # 3390 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:07 HD Request # 3390 | Sending historical data logon request message. | 2018-12-05 13:50:07 HD Request # 3390 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: AUDUSD | 2018-12-05 13:50:07 HD Request # 3390 | Decompressing data. | 2018-12-05 13:50:07 HD Request # 3390 | Receiving Intraday data for AUDUSD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:07 HD Request # 3390 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:07 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:07 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:07 Historical data download thread signaled to stop. | 2018-12-05 13:50:07 HD Request # 3390 | Received 160 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:01 (2.0 minutes) and wrote 158 records for AUDUSD | 2018-12-05 13:50:07 HD Request # 3390 | Completion time: 0s | 2018-12-05 13:50:07 HD Request # 3390 | Intraday data download complete for AUDUSD. Unique request ID: 3995 | 2018-12-05 13:50:07 Removed historical data download ID 3995 | 2018-12-05 13:50:07 Real-time Intraday chart data file updates started for AUDUSD | 2018-12-05 13:50:07 Intraday chart data file opened for AUDUSD | 2018-12-05 13:50:07 HD Request # 3391 | Downloading Intraday chart data for CADCHF to the file CADCHF.scid. Service: lmax | 2018-12-05 13:50:07 HD Request # 3391 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:07 HD Request # 3391 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:07 Socket (4) | Creating socket. | 2018-12-05 13:50:07 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:07 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:07 Socket (5) | Closed. | 2018-12-05 13:50:07 HD Request # 3391 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:07 HD Request # 3391 | Sending historical data logon request message. | 2018-12-05 13:50:07 HD Request # 3391 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: CADCHF | 2018-12-05 13:50:07 HD Request # 3391 | Decompressing data. | 2018-12-05 13:50:07 HD Request # 3391 | Receiving Intraday data for CADCHF starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:07 HD Request # 3391 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:07 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:07 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:07 Historical data download thread signaled to stop. | 2018-12-05 13:50:07 HD Request # 3391 | Received 87 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:05 (2.0 minutes) and wrote 86 records for CADCHF | 2018-12-05 13:50:07 HD Request # 3391 | Completion time: 1s | 2018-12-05 13:50:07 HD Request # 3391 | Intraday data download complete for CADCHF. Unique request ID: 3996 | 2018-12-05 13:50:07 Removed historical data download ID 3996 | 2018-12-05 13:50:07 Real-time Intraday chart data file updates started for CADCHF | 2018-12-05 13:50:07 Intraday chart data file opened for CADCHF | 2018-12-05 13:50:07 HD Request # 3392 | Downloading Intraday chart data for CADJPY to the file CADJPY.scid. Service: lmax | 2018-12-05 13:50:07 HD Request # 3392 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:07 HD Request # 3392 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:07 Socket (5) | Creating socket. | 2018-12-05 13:50:07 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:07 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:07 Socket (4) | Closed. | 2018-12-05 13:50:07 HD Request # 3392 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:07 HD Request # 3392 | Sending historical data logon request message. | 2018-12-05 13:50:07 HD Request # 3392 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: CADJPY | 2018-12-05 13:50:07 HD Request # 3392 | Decompressing data. | 2018-12-05 13:50:08 HD Request # 3392 | Receiving Intraday data for CADJPY starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:08 HD Request # 3392 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:08 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:08 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:08 Historical data download thread signaled to stop. | 2018-12-05 13:50:08 HD Request # 3392 | Received 115 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:05 (2.0 minutes) and wrote 114 records for CADJPY | 2018-12-05 13:50:08 HD Request # 3392 | Completion time: 0s | 2018-12-05 13:50:08 HD Request # 3392 | Intraday data download complete for CADJPY. Unique request ID: 3997 | 2018-12-05 13:50:08 Removed historical data download ID 3997 | 2018-12-05 13:50:08 Real-time Intraday chart data file updates started for CADJPY | 2018-12-05 13:50:08 Intraday chart data file opened for CADJPY | 2018-12-05 13:50:08 HD Request # 3393 | Downloading Intraday chart data for CHFJPY to the file CHFJPY.scid. Service: lmax | 2018-12-05 13:50:08 HD Request # 3393 | Download start date-time: 2018-12-05 13:48:00.000 | 2018-12-05 13:50:08 HD Request # 3393 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:08 Socket (4) | Creating socket. | 2018-12-05 13:50:08 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:08 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:08 Socket (5) | Closed. | 2018-12-05 13:50:08 HD Request # 3393 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:08 HD Request # 3393 | Sending historical data logon request message. | 2018-12-05 13:50:08 HD Request # 3393 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:00. Record interval: 0. Symbol: CHFJPY | 2018-12-05 13:50:08 HD Request # 3393 | Decompressing data. | 2018-12-05 13:50:08 HD Request # 3393 | Receiving Intraday data for CHFJPY starting at 2018-12-05 13:48:00 | 2018-12-05 13:50:08 HD Request # 3393 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:08 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:08 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:08 Historical data download thread signaled to stop. | 2018-12-05 13:50:08 HD Request # 3393 | Received 139 records from 2018-12-05 13:48:00 to 2018-12-05 13:50:04 (2.1 minutes) and wrote 134 records for CHFJPY | 2018-12-05 13:50:08 HD Request # 3393 | Completion time: 0s | 2018-12-05 13:50:08 HD Request # 3393 | Intraday data download complete for CHFJPY. Unique request ID: 3998 | 2018-12-05 13:50:08 Removed historical data download ID 3998 | 2018-12-05 13:50:08 Real-time Intraday chart data file updates started for CHFJPY | 2018-12-05 13:50:08 Intraday chart data file opened for CHFJPY | 2018-12-05 13:50:08 HD Request # 3394 | Downloading Intraday chart data for EURAUD to the file EURAUD.scid. Service: lmax | 2018-12-05 13:50:08 HD Request # 3394 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:08 HD Request # 3394 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:08 Socket (5) | Creating socket. | 2018-12-05 13:50:08 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:08 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:08 Socket (4) | Closed. | 2018-12-05 13:50:08 HD Request # 3394 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:08 HD Request # 3394 | Sending historical data logon request message. | 2018-12-05 13:50:08 HD Request # 3394 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: EURAUD | 2018-12-05 13:50:08 HD Request # 3394 | Decompressing data. | 2018-12-05 13:50:08 HD Request # 3394 | Receiving Intraday data for EURAUD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:08 HD Request # 3394 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:08 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:08 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:08 Historical data download thread signaled to stop. | 2018-12-05 13:50:08 HD Request # 3394 | Received 323 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:04 (2.1 minutes) and wrote 321 records for EURAUD | 2018-12-05 13:50:08 HD Request # 3394 | Completion time: 1s | 2018-12-05 13:50:08 HD Request # 3394 | Intraday data download complete for EURAUD. Unique request ID: 3999 | 2018-12-05 13:50:08 Removed historical data download ID 3999 | 2018-12-05 13:50:08 Real-time Intraday chart data file updates started for EURAUD | 2018-12-05 13:50:08 Intraday chart data file opened for EURAUD | 2018-12-05 13:50:08 HD Request # 3395 | Downloading Intraday chart data for EURCAD to the file EURCAD.scid. Service: lmax | 2018-12-05 13:50:08 HD Request # 3395 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:08 HD Request # 3395 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:08 Socket (4) | Creating socket. | 2018-12-05 13:50:08 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:08 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:08 Socket (5) | Closed. | 2018-12-05 13:50:08 HD Request # 3395 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:08 HD Request # 3395 | Sending historical data logon request message. | 2018-12-05 13:50:08 HD Request # 3395 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: EURCAD | 2018-12-05 13:50:08 HD Request # 3395 | Decompressing data. | 2018-12-05 13:50:09 HD Request # 3395 | Receiving Intraday data for EURCAD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:09 HD Request # 3395 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:09 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:09 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:09 Historical data download thread signaled to stop. | 2018-12-05 13:50:09 HD Request # 3395 | Received 341 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:05 (2.0 minutes) and wrote 337 records for EURCAD | 2018-12-05 13:50:09 HD Request # 3395 | Completion time: 0s | 2018-12-05 13:50:09 HD Request # 3395 | Intraday data download complete for EURCAD. Unique request ID: 4000 | 2018-12-05 13:50:09 Removed historical data download ID 4000 | 2018-12-05 13:50:09 Real-time Intraday chart data file updates started for EURCAD | 2018-12-05 13:50:09 Intraday chart data file opened for EURCAD | 2018-12-05 13:50:09 HD Request # 3396 | Downloading Intraday chart data for EURCHF to the file EURCHF.scid. Service: lmax | 2018-12-05 13:50:09 HD Request # 3396 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:09 HD Request # 3396 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:09 Socket (5) | Creating socket. | 2018-12-05 13:50:09 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:09 Opened cached Intraday file: C:\SierraChart\Data\AUDCAD.scid | 2018-12-05 13:50:09 Opened cached Intraday file: C:\SierraChart\Data\AUDJPY.scid | 2018-12-05 13:50:09 Opened cached Intraday file: C:\SierraChart\Data\AUDNZD.scid | 2018-12-05 13:50:09 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:09 Socket (4) | Closed. | 2018-12-05 13:50:09 HD Request # 3396 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:09 HD Request # 3396 | Sending historical data logon request message. | 2018-12-05 13:50:09 HD Request # 3396 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: EURCHF | 2018-12-05 13:50:09 HD Request # 3396 | Decompressing data. | 2018-12-05 13:50:09 HD Request # 3396 | Receiving Intraday data for EURCHF starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:09 HD Request # 3396 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:09 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:09 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:09 Historical data download thread signaled to stop. | 2018-12-05 13:50:09 HD Request # 3396 | Received 161 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:05 (2.0 minutes) and wrote 160 records for EURCHF | 2018-12-05 13:50:09 HD Request # 3396 | Completion time: 0s | 2018-12-05 13:50:09 HD Request # 3396 | Intraday data download complete for EURCHF. Unique request ID: 4001 | 2018-12-05 13:50:09 Removed historical data download ID 4001 | 2018-12-05 13:50:09 Real-time Intraday chart data file updates started for EURCHF | 2018-12-05 13:50:09 Intraday chart data file opened for EURCHF | 2018-12-05 13:50:09 HD Request # 3397 | Downloading Intraday chart data for EURGBP to the file EURGBP.scid. Service: lmax | 2018-12-05 13:50:09 HD Request # 3397 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:09 HD Request # 3397 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:09 Socket (4) | Creating socket. | 2018-12-05 13:50:09 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:09 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:09 Socket (5) | Closed. | 2018-12-05 13:50:09 HD Request # 3397 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:09 HD Request # 3397 | Sending historical data logon request message. | 2018-12-05 13:50:09 HD Request # 3397 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: EURGBP | 2018-12-05 13:50:09 HD Request # 3397 | Decompressing data. | 2018-12-05 13:50:09 HD Request # 3397 | Receiving Intraday data for EURGBP starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:09 HD Request # 3397 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:09 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:09 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:09 Historical data download thread signaled to stop. | 2018-12-05 13:50:09 HD Request # 3397 | Received 310 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:08 (2.1 minutes) and wrote 309 records for EURGBP | 2018-12-05 13:50:09 Added 1 Time and Sales records to Intraday data file for EURGBP after download. | 2018-12-05 13:50:09 HD Request # 3397 | Completion time: 1s | 2018-12-05 13:50:09 HD Request # 3397 | Intraday data download complete for EURGBP. Unique request ID: 4002 | 2018-12-05 13:50:09 Removed historical data download ID 4002 | 2018-12-05 13:50:09 Real-time Intraday chart data file updates started for EURGBP | 2018-12-05 13:50:09 Intraday chart data file opened for EURGBP | 2018-12-05 13:50:09 HD Request # 3398 | Downloading Intraday chart data for EURJPY to the file EURJPY.scid. Service: lmax | 2018-12-05 13:50:09 HD Request # 3398 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:09 HD Request # 3398 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:09 Socket (5) | Creating socket. | 2018-12-05 13:50:09 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:09 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:09 Socket (4) | Closed. | 2018-12-05 13:50:09 HD Request # 3398 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:09 HD Request # 3398 | Sending historical data logon request message. | 2018-12-05 13:50:09 HD Request # 3398 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: EURJPY | 2018-12-05 13:50:10 HD Request # 3398 | Decompressing data. | 2018-12-05 13:50:10 HD Request # 3398 | Receiving Intraday data for EURJPY starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:10 HD Request # 3398 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:10 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:10 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:10 Historical data download thread signaled to stop. | 2018-12-05 13:50:10 HD Request # 3398 | Received 255 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:08 (2.1 minutes) and wrote 254 records for EURJPY | 2018-12-05 13:50:10 Added 3 Time and Sales records to Intraday data file for EURJPY after download. | 2018-12-05 13:50:10 HD Request # 3398 | Completion time: 0s | 2018-12-05 13:50:10 HD Request # 3398 | Intraday data download complete for EURJPY. Unique request ID: 4003 | 2018-12-05 13:50:10 Removed historical data download ID 4003 | 2018-12-05 13:50:10 Real-time Intraday chart data file updates started for EURJPY | 2018-12-05 13:50:10 Intraday chart data file opened for EURJPY | 2018-12-05 13:50:10 HD Request # 3399 | Downloading Intraday chart data for EURNZD to the file EURNZD.scid. Service: lmax | 2018-12-05 13:50:10 HD Request # 3399 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:10 HD Request # 3399 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:10 Socket (4) | Creating socket. | 2018-12-05 13:50:10 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:10 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:10 Socket (5) | Closed. | 2018-12-05 13:50:10 HD Request # 3399 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:10 HD Request # 3399 | Sending historical data logon request message. | 2018-12-05 13:50:10 HD Request # 3399 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: EURNZD | 2018-12-05 13:50:10 HD Request # 3399 | Decompressing data. | 2018-12-05 13:50:10 HD Request # 3399 | Receiving Intraday data for EURNZD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:10 HD Request # 3399 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:10 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:10 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:10 Historical data download thread signaled to stop. | 2018-12-05 13:50:10 HD Request # 3399 | Received 155 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:08 (2.1 minutes) and wrote 154 records for EURNZD | 2018-12-05 13:50:10 HD Request # 3399 | Completion time: 0s | 2018-12-05 13:50:10 HD Request # 3399 | Intraday data download complete for EURNZD. Unique request ID: 4004 | 2018-12-05 13:50:10 Removed historical data download ID 4004 | 2018-12-05 13:50:10 Real-time Intraday chart data file updates started for EURNZD | 2018-12-05 13:50:10 Intraday chart data file opened for EURNZD | 2018-12-05 13:50:10 HD Request # 3400 | Downloading Intraday chart data for EURTRY to the file EURTRY.scid. Service: lmax | 2018-12-05 13:50:10 HD Request # 3400 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:10 HD Request # 3400 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:10 Socket (5) | Creating socket. | 2018-12-05 13:50:10 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:10 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:10 Socket (4) | Closed. | 2018-12-05 13:50:10 HD Request # 3400 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:10 HD Request # 3400 | Sending historical data logon request message. | 2018-12-05 13:50:10 HD Request # 3400 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: EURTRY | 2018-12-05 13:50:10 HD Request # 3400 | Decompressing data. | 2018-12-05 13:50:10 HD Request # 3400 | Receiving Intraday data for EURTRY starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:10 HD Request # 3400 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:10 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:10 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:10 Historical data download thread signaled to stop. | 2018-12-05 13:50:10 HD Request # 3400 | Received 172 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:08 (2.1 minutes) and wrote 168 records for EURTRY | 2018-12-05 13:50:10 HD Request # 3400 | Completion time: 0s | 2018-12-05 13:50:10 HD Request # 3400 | Intraday data download complete for EURTRY. Unique request ID: 4005 | 2018-12-05 13:50:10 Removed historical data download ID 4005 | 2018-12-05 13:50:10 Real-time Intraday chart data file updates started for EURTRY | 2018-12-05 13:50:10 Intraday chart data file opened for EURTRY | 2018-12-05 13:50:10 HD Request # 3401 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: lmax | 2018-12-05 13:50:10 HD Request # 3401 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:10 HD Request # 3401 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:10 Socket (4) | Creating socket. | 2018-12-05 13:50:10 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:10 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:10 Socket (5) | Closed. | 2018-12-05 13:50:10 HD Request # 3401 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:10 HD Request # 3401 | Sending historical data logon request message. | 2018-12-05 13:50:10 HD Request # 3401 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: EURUSD | 2018-12-05 13:50:11 HD Request # 3401 | Decompressing data. | 2018-12-05 13:50:11 HD Request # 3401 | Receiving Intraday data for EURUSD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:11 HD Request # 3401 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:11 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:11 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:11 Historical data download thread signaled to stop. | 2018-12-05 13:50:11 HD Request # 3401 | Received 153 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:07 (2.1 minutes) and wrote 152 records for EURUSD | 2018-12-05 13:50:11 Added 2 Time and Sales records to Intraday data file for EURUSD after download. | 2018-12-05 13:50:11 HD Request # 3401 | Completion time: 0s | 2018-12-05 13:50:11 HD Request # 3401 | Intraday data download complete for EURUSD. Unique request ID: 4006 | 2018-12-05 13:50:11 Removed historical data download ID 4006 | 2018-12-05 13:50:11 Real-time Intraday chart data file updates started for EURUSD | 2018-12-05 13:50:11 Intraday chart data file opened for EURUSD | 2018-12-05 13:50:11 HD Request # 3402 | Downloading Intraday chart data for GBPAUD to the file GBPAUD.scid. Service: lmax | 2018-12-05 13:50:11 HD Request # 3402 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:11 HD Request # 3402 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:11 Socket (5) | Creating socket. | 2018-12-05 13:50:11 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:11 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:11 Socket (4) | Closed. | 2018-12-05 13:50:11 HD Request # 3402 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:11 HD Request # 3402 | Sending historical data logon request message. | 2018-12-05 13:50:11 HD Request # 3402 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: GBPAUD | 2018-12-05 13:50:11 HD Request # 3402 | Decompressing data. | 2018-12-05 13:50:11 HD Request # 3402 | Receiving Intraday data for GBPAUD starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:11 HD Request # 3402 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:11 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:11 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:11 Historical data download thread signaled to stop. | 2018-12-05 13:50:11 HD Request # 3402 | Received 375 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 374 records for GBPAUD | 2018-12-05 13:50:11 HD Request # 3402 | Completion time: 0s | 2018-12-05 13:50:11 HD Request # 3402 | Intraday data download complete for GBPAUD. Unique request ID: 4007 | 2018-12-05 13:50:11 Removed historical data download ID 4007 | 2018-12-05 13:50:11 Real-time Intraday chart data file updates started for GBPAUD | 2018-12-05 13:50:11 Intraday chart data file opened for GBPAUD | 2018-12-05 13:50:11 HD Request # 3403 | Downloading Intraday chart data for GBPCAD to the file GBPCAD.scid. Service: lmax | 2018-12-05 13:50:11 HD Request # 3403 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:11 HD Request # 3403 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:11 Socket (4) | Creating socket. | 2018-12-05 13:50:11 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:11 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:11 Socket (5) | Closed. | 2018-12-05 13:50:11 HD Request # 3403 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:11 HD Request # 3403 | Sending historical data logon request message. | 2018-12-05 13:50:11 HD Request # 3403 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: GBPCAD | 2018-12-05 13:50:11 HD Request # 3403 | Decompressing data. | 2018-12-05 13:50:11 HD Request # 3403 | Receiving Intraday data for GBPCAD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:11 HD Request # 3403 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:11 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:11 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:11 Historical data download thread signaled to stop. | 2018-12-05 13:50:11 HD Request # 3403 | Received 232 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 231 records for GBPCAD | 2018-12-05 13:50:11 HD Request # 3403 | Completion time: 0s | 2018-12-05 13:50:11 HD Request # 3403 | Intraday data download complete for GBPCAD. Unique request ID: 4008 | 2018-12-05 13:50:11 Removed historical data download ID 4008 | 2018-12-05 13:50:11 Real-time Intraday chart data file updates started for GBPCAD | 2018-12-05 13:50:11 Intraday chart data file opened for GBPCAD | 2018-12-05 13:50:11 HD Request # 3404 | Downloading Intraday chart data for GBPCHF to the file GBPCHF.scid. Service: lmax | 2018-12-05 13:50:11 HD Request # 3404 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:11 HD Request # 3404 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:11 Socket (5) | Creating socket. | 2018-12-05 13:50:11 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:11 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:11 Socket (4) | Closed. | 2018-12-05 13:50:11 HD Request # 3404 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:12 HD Request # 3404 | Sending historical data logon request message. | 2018-12-05 13:50:12 HD Request # 3404 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: GBPCHF | 2018-12-05 13:50:12 HD Request # 3404 | Decompressing data. | 2018-12-05 13:50:12 HD Request # 3404 | Receiving Intraday data for GBPCHF starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:12 HD Request # 3404 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:12 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:12 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:12 Historical data download thread signaled to stop. | 2018-12-05 13:50:12 HD Request # 3404 | Received 182 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 181 records for GBPCHF | 2018-12-05 13:50:12 HD Request # 3404 | Completion time: 0s | 2018-12-05 13:50:12 HD Request # 3404 | Intraday data download complete for GBPCHF. Unique request ID: 4009 | 2018-12-05 13:50:12 Removed historical data download ID 4009 | 2018-12-05 13:50:12 Real-time Intraday chart data file updates started for GBPCHF | 2018-12-05 13:50:12 Intraday chart data file opened for GBPCHF | 2018-12-05 13:50:12 HD Request # 3405 | Downloading Intraday chart data for GBPJPY to the file GBPJPY.scid. Service: lmax | 2018-12-05 13:50:12 HD Request # 3405 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:12 HD Request # 3405 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:12 Socket (4) | Creating socket. | 2018-12-05 13:50:12 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\AUDCHF.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\AUDUSD.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\CADJPY.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\CHFJPY.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURAUD.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURCAD.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURGBP.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURJPY.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURNZD.scid | 2018-12-05 13:50:12 Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid | 2018-12-05 13:50:12 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:12 Socket (5) | Closed. | 2018-12-05 13:50:12 HD Request # 3405 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:12 HD Request # 3405 | Sending historical data logon request message. | 2018-12-05 13:50:12 HD Request # 3405 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: GBPJPY | 2018-12-05 13:50:12 HD Request # 3405 | Decompressing data. | 2018-12-05 13:50:12 HD Request # 3405 | Receiving Intraday data for GBPJPY starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:12 HD Request # 3405 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:12 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:12 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:12 Historical data download thread signaled to stop. | 2018-12-05 13:50:12 HD Request # 3405 | Received 323 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 322 records for GBPJPY | 2018-12-05 13:50:12 Added 2 Time and Sales records to Intraday data file for GBPJPY after download. | 2018-12-05 13:50:12 HD Request # 3405 | Completion time: 0s | 2018-12-05 13:50:12 HD Request # 3405 | Intraday data download complete for GBPJPY. Unique request ID: 4010 | 2018-12-05 13:50:12 Removed historical data download ID 4010 | 2018-12-05 13:50:12 Real-time Intraday chart data file updates started for GBPJPY | 2018-12-05 13:50:12 Intraday chart data file opened for GBPJPY | 2018-12-05 13:50:12 HD Request # 3406 | Downloading Intraday chart data for GBPNZD to the file GBPNZD.scid. Service: lmax | 2018-12-05 13:50:12 HD Request # 3406 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:12 HD Request # 3406 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:12 Socket (5) | Creating socket. | 2018-12-05 13:50:12 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:12 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:12 Socket (4) | Closed. | 2018-12-05 13:50:12 HD Request # 3406 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:12 HD Request # 3406 | Sending historical data logon request message. | 2018-12-05 13:50:12 HD Request # 3406 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: GBPNZD | 2018-12-05 13:50:12 HD Request # 3406 | Decompressing data. | 2018-12-05 13:50:12 HD Request # 3406 | Receiving Intraday data for GBPNZD starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:12 HD Request # 3406 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:12 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:12 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:12 Historical data download thread signaled to stop. | 2018-12-05 13:50:12 HD Request # 3406 | Received 219 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 218 records for GBPNZD | 2018-12-05 13:50:12 Added 2 Time and Sales records to Intraday data file for GBPNZD after download. | 2018-12-05 13:50:12 HD Request # 3406 | Completion time: 0s | 2018-12-05 13:50:12 HD Request # 3406 | Intraday data download complete for GBPNZD. Unique request ID: 4011 | 2018-12-05 13:50:12 Removed historical data download ID 4011 | 2018-12-05 13:50:12 Real-time Intraday chart data file updates started for GBPNZD | 2018-12-05 13:50:12 Intraday chart data file opened for GBPNZD | 2018-12-05 13:50:12 HD Request # 3407 | Downloading Intraday chart data for GBPUSD to the file GBPUSD.scid. Service: lmax | 2018-12-05 13:50:12 HD Request # 3407 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:12 HD Request # 3407 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:12 Socket (4) | Creating socket. | 2018-12-05 13:50:12 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:12 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:12 Socket (5) | Closed. | 2018-12-05 13:50:12 HD Request # 3407 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:12 HD Request # 3407 | Sending historical data logon request message. | 2018-12-05 13:50:12 HD Request # 3407 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: GBPUSD | 2018-12-05 13:50:13 HD Request # 3407 | Decompressing data. | 2018-12-05 13:50:13 HD Request # 3407 | Receiving Intraday data for GBPUSD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:13 HD Request # 3407 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:13 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:13 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:13 Historical data download thread signaled to stop. | 2018-12-05 13:50:13 HD Request # 3407 | Received 368 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 367 records for GBPUSD | 2018-12-05 13:50:13 Added 4 Time and Sales records to Intraday data file for GBPUSD after download. | 2018-12-05 13:50:13 HD Request # 3407 | Completion time: 0s | 2018-12-05 13:50:13 HD Request # 3407 | Intraday data download complete for GBPUSD. Unique request ID: 4012 | 2018-12-05 13:50:13 Removed historical data download ID 4012 | 2018-12-05 13:50:13 Real-time Intraday chart data file updates started for GBPUSD | 2018-12-05 13:50:13 Intraday chart data file opened for GBPUSD | 2018-12-05 13:50:13 HD Request # 3408 | Downloading Intraday chart data for GDAXI to the file GDAXI.scid. Service: lmax | 2018-12-05 13:50:13 HD Request # 3408 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:13 HD Request # 3408 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:13 Socket (5) | Creating socket. | 2018-12-05 13:50:13 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:13 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:13 Socket (4) | Closed. | 2018-12-05 13:50:13 HD Request # 3408 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:13 HD Request # 3408 | Sending historical data logon request message. | 2018-12-05 13:50:13 HD Request # 3408 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: GDAXI | 2018-12-05 13:50:13 HD Request # 3408 | Decompressing data. | 2018-12-05 13:50:13 HD Request # 3408 | Receiving Intraday data for GDAXI starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:13 HD Request # 3408 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:09 | 2018-12-05 13:50:13 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:13 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:13 Historical data download thread signaled to stop. | 2018-12-05 13:50:13 HD Request # 3408 | Received 146 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:09 (2.1 minutes) and wrote 144 records for GDAXI | 2018-12-05 13:50:13 HD Request # 3408 | Completion time: 0s | 2018-12-05 13:50:13 HD Request # 3408 | Intraday data download complete for GDAXI. Unique request ID: 4013 | 2018-12-05 13:50:13 Removed historical data download ID 4013 | 2018-12-05 13:50:13 Real-time Intraday chart data file updates started for GDAXI | 2018-12-05 13:50:13 Intraday chart data file opened for GDAXI | 2018-12-05 13:50:13 HD Request # 3409 | Downloading Intraday chart data for HSI to the file HSI.scid. Service: lmax | 2018-12-05 13:50:13 HD Request # 3409 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:13 HD Request # 3409 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:13 Socket (4) | Creating socket. | 2018-12-05 13:50:13 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:13 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:13 Socket (5) | Closed. | 2018-12-05 13:50:13 HD Request # 3409 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:13 HD Request # 3409 | Sending historical data logon request message. | 2018-12-05 13:50:13 HD Request # 3409 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: HSI | 2018-12-05 13:50:14 HD Request # 3409 | Decompressing data. | 2018-12-05 13:50:14 HD Request # 3409 | Receiving Intraday data for HSI starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:14 HD Request # 3409 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:14 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:14 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:14 Historical data download thread signaled to stop. | 2018-12-05 13:50:14 HD Request # 3409 | Received 134 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:12 (2.2 minutes) and wrote 133 records for HSI | 2018-12-05 13:50:14 HD Request # 3409 | Completion time: 0s | 2018-12-05 13:50:14 HD Request # 3409 | Intraday data download complete for HSI. Unique request ID: 4014 | 2018-12-05 13:50:14 Removed historical data download ID 4014 | 2018-12-05 13:50:14 Real-time Intraday chart data file updates started for HSI | 2018-12-05 13:50:14 Intraday chart data file opened for HSI | 2018-12-05 13:50:14 HD Request # 3410 | Downloading Intraday chart data for J225 to the file J225.scid. Service: lmax | 2018-12-05 13:50:14 HD Request # 3410 | Download start date-time: 2018-12-05 13:46:32.000 | 2018-12-05 13:50:14 HD Request # 3410 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:14 Socket (5) | Creating socket. | 2018-12-05 13:50:14 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:14 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:14 Socket (4) | Closed. | 2018-12-05 13:50:14 HD Request # 3410 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:14 HD Request # 3410 | Sending historical data logon request message. | 2018-12-05 13:50:14 HD Request # 3410 | Requesting Intraday data. Start date-time: 2018-12-05 13:46:32. Record interval: 0. Symbol: J225 | 2018-12-05 13:50:14 HD Request # 3410 | Decompressing data. | 2018-12-05 13:50:14 HD Request # 3410 | Receiving Intraday data for J225 starting at 2018-12-05 13:46:32 | 2018-12-05 13:50:14 HD Request # 3410 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:41 | 2018-12-05 13:50:14 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:14 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:14 Historical data download thread signaled to stop. | 2018-12-05 13:50:14 HD Request # 3410 | Received 71 records from 2018-12-05 13:46:32 to 2018-12-05 13:50:09 (3.6 minutes) and wrote 69 records for J225 | 2018-12-05 13:50:14 HD Request # 3410 | Completion time: 0s | 2018-12-05 13:50:14 HD Request # 3410 | Intraday data download complete for J225. Unique request ID: 4015 | 2018-12-05 13:50:14 Removed historical data download ID 4015 | 2018-12-05 13:50:14 Real-time Intraday chart data file updates started for J225 | 2018-12-05 13:50:14 Intraday chart data file opened for J225 | 2018-12-05 13:50:14 HD Request # 3411 | Downloading Intraday chart data for NZDCAD to the file NZDCAD.scid. Service: lmax | 2018-12-05 13:50:14 HD Request # 3411 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:14 HD Request # 3411 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:14 Socket (4) | Creating socket. | 2018-12-05 13:50:14 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:14 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:14 Socket (5) | Closed. | 2018-12-05 13:50:14 HD Request # 3411 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:14 HD Request # 3411 | Sending historical data logon request message. | 2018-12-05 13:50:14 HD Request # 3411 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: NZDCAD | 2018-12-05 13:50:14 HD Request # 3411 | Decompressing data. | 2018-12-05 13:50:14 HD Request # 3411 | Receiving Intraday data for NZDCAD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:14 HD Request # 3411 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:14 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:14 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:14 Historical data download thread signaled to stop. | 2018-12-05 13:50:14 HD Request # 3411 | Received 92 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:12 (2.1 minutes) and wrote 91 records for NZDCAD | 2018-12-05 13:50:14 HD Request # 3411 | Completion time: 0s | 2018-12-05 13:50:14 HD Request # 3411 | Intraday data download complete for NZDCAD. Unique request ID: 4016 | 2018-12-05 13:50:14 Removed historical data download ID 4016 | 2018-12-05 13:50:14 Real-time Intraday chart data file updates started for NZDCAD | 2018-12-05 13:50:14 Intraday chart data file opened for NZDCAD | 2018-12-05 13:50:14 HD Request # 3412 | Downloading Intraday chart data for NZDCHF to the file NZDCHF.scid. Service: lmax | 2018-12-05 13:50:14 HD Request # 3412 | Download start date-time: 2018-12-05 13:48:00.000 | 2018-12-05 13:50:14 HD Request # 3412 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:14 Socket (5) | Creating socket. | 2018-12-05 13:50:14 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:14 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:14 Socket (4) | Closed. | 2018-12-05 13:50:14 HD Request # 3412 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:14 HD Request # 3412 | Sending historical data logon request message. | 2018-12-05 13:50:14 HD Request # 3412 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:00. Record interval: 0. Symbol: NZDCHF | 2018-12-05 13:50:15 HD Request # 3412 | Decompressing data. | 2018-12-05 13:50:15 HD Request # 3412 | Receiving Intraday data for NZDCHF starting at 2018-12-05 13:48:00 | 2018-12-05 13:50:15 HD Request # 3412 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:15 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:15 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:15 Historical data download thread signaled to stop. | 2018-12-05 13:50:15 HD Request # 3412 | Received 70 records from 2018-12-05 13:48:00 to 2018-12-05 13:50:12 (2.2 minutes) and wrote 67 records for NZDCHF | 2018-12-05 13:50:15 Added 1 Time and Sales records to Intraday data file for NZDCHF after download. | 2018-12-05 13:50:15 HD Request # 3412 | Completion time: 0s | 2018-12-05 13:50:15 HD Request # 3412 | Intraday data download complete for NZDCHF. Unique request ID: 4017 | 2018-12-05 13:50:15 Removed historical data download ID 4017 | 2018-12-05 13:50:15 Real-time Intraday chart data file updates started for NZDCHF | 2018-12-05 13:50:15 Intraday chart data file opened for NZDCHF | 2018-12-05 13:50:15 HD Request # 3413 | Downloading Intraday chart data for NZDJPY to the file NZDJPY.scid. Service: lmax | 2018-12-05 13:50:15 HD Request # 3413 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:15 HD Request # 3413 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:15 Socket (4) | Creating socket. | 2018-12-05 13:50:15 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:15 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:15 Socket (5) | Closed. | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GDAXI.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\CADCHF.scid | 2018-12-05 13:50:15 HD Request # 3413 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:15 HD Request # 3413 | Sending historical data logon request message. | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\EURCHF.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPAUD.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPCAD.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPCHF.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPJPY.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPNZD.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\GBPUSD.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\NZDCAD.scid | 2018-12-05 13:50:15 Opened cached Intraday file: C:\SierraChart\Data\EURTRY.scid | 2018-12-05 13:50:15 HD Request # 3413 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: NZDJPY | 2018-12-05 13:50:15 HD Request # 3413 | Decompressing data. | 2018-12-05 13:50:15 HD Request # 3413 | Receiving Intraday data for NZDJPY starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:15 HD Request # 3413 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:15 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:15 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:15 Historical data download thread signaled to stop. | 2018-12-05 13:50:15 HD Request # 3413 | Received 160 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:12 (2.2 minutes) and wrote 158 records for NZDJPY | 2018-12-05 13:50:15 HD Request # 3413 | Completion time: 0s | 2018-12-05 13:50:15 HD Request # 3413 | Intraday data download complete for NZDJPY. Unique request ID: 4018 | 2018-12-05 13:50:15 Removed historical data download ID 4018 | 2018-12-05 13:50:15 Real-time Intraday chart data file updates started for NZDJPY | 2018-12-05 13:50:15 Intraday chart data file opened for NZDJPY | 2018-12-05 13:50:15 HD Request # 3414 | Downloading Intraday chart data for NZDUSD to the file NZDUSD.scid. Service: lmax | 2018-12-05 13:50:15 HD Request # 3414 | Download start date-time: 2018-12-05 13:48:00.000 | 2018-12-05 13:50:15 HD Request # 3414 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:15 Socket (5) | Creating socket. | 2018-12-05 13:50:15 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:15 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:15 Socket (4) | Closed. | 2018-12-05 13:50:15 HD Request # 3414 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:15 HD Request # 3414 | Sending historical data logon request message. | 2018-12-05 13:50:15 HD Request # 3414 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:00. Record interval: 0. Symbol: NZDUSD | 2018-12-05 13:50:15 HD Request # 3414 | Decompressing data. | 2018-12-05 13:50:15 HD Request # 3414 | Receiving Intraday data for NZDUSD starting at 2018-12-05 13:48:00 | 2018-12-05 13:50:15 HD Request # 3414 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:06 | 2018-12-05 13:50:15 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:15 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:15 Historical data download thread signaled to stop. | 2018-12-05 13:50:15 HD Request # 3414 | Received 122 records from 2018-12-05 13:48:00 to 2018-12-05 13:50:12 (2.2 minutes) and wrote 120 records for NZDUSD | 2018-12-05 13:50:15 HD Request # 3414 | Completion time: 0s | 2018-12-05 13:50:15 HD Request # 3414 | Intraday data download complete for NZDUSD. Unique request ID: 4019 | 2018-12-05 13:50:15 Removed historical data download ID 4019 | 2018-12-05 13:50:15 Real-time Intraday chart data file updates started for NZDUSD | 2018-12-05 13:50:15 Intraday chart data file opened for NZDUSD | 2018-12-05 13:50:15 HD Request # 3415 | Downloading Intraday chart data for SPX to the file SPX.scid. Service: lmax | 2018-12-05 13:50:15 HD Request # 3415 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:15 HD Request # 3415 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:15 Socket (4) | Creating socket. | 2018-12-05 13:50:15 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:15 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:15 Socket (5) | Closed. | 2018-12-05 13:50:15 HD Request # 3415 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:15 HD Request # 3415 | Sending historical data logon request message. | 2018-12-05 13:50:15 HD Request # 3415 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: SPX | 2018-12-05 13:50:16 HD Request # 3415 | Decompressing data. | 2018-12-05 13:50:16 HD Request # 3415 | Receiving Intraday data for SPX starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:16 HD Request # 3415 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:20 | 2018-12-05 13:50:16 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:16 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:16 Historical data download thread signaled to stop. | 2018-12-05 13:50:16 HD Request # 3415 | Received 74 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:11 (2.2 minutes) and wrote 73 records for SPX | 2018-12-05 13:50:16 HD Request # 3415 | Completion time: 0s | 2018-12-05 13:50:16 HD Request # 3415 | Intraday data download complete for SPX. Unique request ID: 4020 | 2018-12-05 13:50:16 Removed historical data download ID 4020 | 2018-12-05 13:50:16 Real-time Intraday chart data file updates started for SPX | 2018-12-05 13:50:16 Intraday chart data file opened for SPX | 2018-12-05 13:50:16 HD Request # 3416 | Downloading Intraday chart data for STOXX50E to the file STOXX50E.scid. Service: lmax | 2018-12-05 13:50:16 HD Request # 3416 | Download start date-time: 2018-12-05 13:47:30.000 | 2018-12-05 13:50:16 HD Request # 3416 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:16 Socket (5) | Creating socket. | 2018-12-05 13:50:16 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:16 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:16 Socket (4) | Closed. | 2018-12-05 13:50:16 HD Request # 3416 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:16 HD Request # 3416 | Sending historical data logon request message. | 2018-12-05 13:50:16 HD Request # 3416 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:30. Record interval: 0. Symbol: STOXX50E | 2018-12-05 13:50:16 HD Request # 3416 | Decompressing data. | 2018-12-05 13:50:16 HD Request # 3416 | Receiving Intraday data for STOXX50E starting at 2018-12-05 13:47:30 | 2018-12-05 13:50:16 HD Request # 3416 | Timestamp of first Intraday data file record written: 2018-12-05 13:49:16 | 2018-12-05 13:50:16 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:16 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:16 Historical data download thread signaled to stop. | 2018-12-05 13:50:16 HD Request # 3416 | Received 4 records from 2018-12-05 13:47:30 to 2018-12-05 13:49:16 (106.0 seconds) and wrote 3 records for STOXX50E | 2018-12-05 13:50:16 HD Request # 3416 | Completion time: 0s | 2018-12-05 13:50:16 HD Request # 3416 | Intraday data download complete for STOXX50E. Unique request ID: 4021 | 2018-12-05 13:50:16 Removed historical data download ID 4021 | 2018-12-05 13:50:16 Real-time Intraday chart data file updates started for STOXX50E | 2018-12-05 13:50:16 Intraday chart data file opened for STOXX50E | 2018-12-05 13:50:16 HD Request # 3417 | Downloading Intraday chart data for UK100 to the file UK100.scid. Service: lmax | 2018-12-05 13:50:16 HD Request # 3417 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:16 HD Request # 3417 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:16 Socket (4) | Creating socket. | 2018-12-05 13:50:16 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:16 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:16 Socket (5) | Closed. | 2018-12-05 13:50:16 HD Request # 3417 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:16 HD Request # 3417 | Sending historical data logon request message. | 2018-12-05 13:50:16 HD Request # 3417 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: UK100 | 2018-12-05 13:50:16 HD Request # 3417 | Decompressing data. | 2018-12-05 13:50:16 HD Request # 3417 | Receiving Intraday data for UK100 starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:16 HD Request # 3417 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:07 | 2018-12-05 13:50:16 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:16 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:16 Historical data download thread signaled to stop. | 2018-12-05 13:50:16 HD Request # 3417 | Received 133 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:14 (2.2 minutes) and wrote 132 records for UK100 | 2018-12-05 13:50:16 Added 2 Time and Sales records to Intraday data file for UK100 after download. | 2018-12-05 13:50:16 HD Request # 3417 | Completion time: 0s | 2018-12-05 13:50:16 HD Request # 3417 | Intraday data download complete for UK100. Unique request ID: 4022 | 2018-12-05 13:50:16 Removed historical data download ID 4022 | 2018-12-05 13:50:16 Real-time Intraday chart data file updates started for UK100 | 2018-12-05 13:50:16 Intraday chart data file opened for UK100 | 2018-12-05 13:50:16 HD Request # 3418 | Downloading Intraday chart data for USDCAD to the file USDCAD.scid. Service: lmax | 2018-12-05 13:50:16 HD Request # 3418 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:16 HD Request # 3418 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:16 Socket (5) | Creating socket. | 2018-12-05 13:50:16 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:16 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:16 Socket (4) | Closed. | 2018-12-05 13:50:16 HD Request # 3418 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:16 HD Request # 3418 | Sending historical data logon request message. | 2018-12-05 13:50:16 HD Request # 3418 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: USDCAD | 2018-12-05 13:50:17 HD Request # 3418 | Decompressing data. | 2018-12-05 13:50:17 HD Request # 3418 | Receiving Intraday data for USDCAD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:17 HD Request # 3418 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:17 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:17 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:17 Historical data download thread signaled to stop. | 2018-12-05 13:50:17 HD Request # 3418 | Received 194 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:14 (2.2 minutes) and wrote 192 records for USDCAD | 2018-12-05 13:50:17 Added 2 Time and Sales records to Intraday data file for USDCAD after download. | 2018-12-05 13:50:17 HD Request # 3418 | Completion time: 0s | 2018-12-05 13:50:17 HD Request # 3418 | Intraday data download complete for USDCAD. Unique request ID: 4023 | 2018-12-05 13:50:17 Removed historical data download ID 4023 | 2018-12-05 13:50:17 Real-time Intraday chart data file updates started for USDCAD | 2018-12-05 13:50:17 Intraday chart data file opened for USDCAD | 2018-12-05 13:50:17 HD Request # 3419 | Downloading Intraday chart data for USDCHF to the file USDCHF.scid. Service: lmax | 2018-12-05 13:50:17 HD Request # 3419 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:17 HD Request # 3419 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:17 Socket (4) | Creating socket. | 2018-12-05 13:50:17 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:17 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:17 Socket (5) | Closed. | 2018-12-05 13:50:17 HD Request # 3419 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:17 HD Request # 3419 | Sending historical data logon request message. | 2018-12-05 13:50:17 HD Request # 3419 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: USDCHF | 2018-12-05 13:50:17 HD Request # 3419 | Decompressing data. | 2018-12-05 13:50:17 HD Request # 3419 | Receiving Intraday data for USDCHF starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:17 HD Request # 3419 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:17 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:17 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:17 Historical data download thread signaled to stop. | 2018-12-05 13:50:17 HD Request # 3419 | Received 118 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:14 (2.2 minutes) and wrote 116 records for USDCHF | 2018-12-05 13:50:17 HD Request # 3419 | Completion time: 0s | 2018-12-05 13:50:17 HD Request # 3419 | Intraday data download complete for USDCHF. Unique request ID: 4024 | 2018-12-05 13:50:17 Removed historical data download ID 4024 | 2018-12-05 13:50:17 Real-time Intraday chart data file updates started for USDCHF | 2018-12-05 13:50:17 Intraday chart data file opened for USDCHF | 2018-12-05 13:50:17 HD Request # 3420 | Downloading Intraday chart data for USDJPY to the file USDJPY.scid. Service: lmax | 2018-12-05 13:50:17 HD Request # 3420 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:17 HD Request # 3420 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:17 Socket (5) | Creating socket. | 2018-12-05 13:50:17 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:17 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:17 Socket (4) | Closed. | 2018-12-05 13:50:17 HD Request # 3420 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:17 HD Request # 3420 | Sending historical data logon request message. | 2018-12-05 13:50:17 HD Request # 3420 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: USDJPY | 2018-12-05 13:50:17 HD Request # 3420 | Decompressing data. | 2018-12-05 13:50:17 HD Request # 3420 | Receiving Intraday data for USDJPY starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:17 HD Request # 3420 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:17 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:17 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:17 Historical data download thread signaled to stop. | 2018-12-05 13:50:17 HD Request # 3420 | Received 260 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:16 (2.3 minutes) and wrote 258 records for USDJPY | 2018-12-05 13:50:17 HD Request # 3420 | Completion time: 1s | 2018-12-05 13:50:17 HD Request # 3420 | Intraday data download complete for USDJPY. Unique request ID: 4025 | 2018-12-05 13:50:17 Removed historical data download ID 4025 | 2018-12-05 13:50:17 Real-time Intraday chart data file updates started for USDJPY | 2018-12-05 13:50:17 Intraday chart data file opened for USDJPY | 2018-12-05 13:50:17 HD Request # 3421 | Downloading Intraday chart data for USDTRY to the file USDTRY.scid. Service: lmax | 2018-12-05 13:50:17 HD Request # 3421 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:17 HD Request # 3421 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:17 Socket (4) | Creating socket. | 2018-12-05 13:50:17 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:17 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:17 Socket (5) | Closed. | 2018-12-05 13:50:17 HD Request # 3421 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:17 HD Request # 3421 | Sending historical data logon request message. | 2018-12-05 13:50:17 HD Request # 3421 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: USDTRY | 2018-12-05 13:50:18 HD Request # 3421 | Decompressing data. | 2018-12-05 13:50:18 HD Request # 3421 | Receiving Intraday data for USDTRY starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:18 HD Request # 3421 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:18 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:18 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:18 Historical data download thread signaled to stop. | 2018-12-05 13:50:18 HD Request # 3421 | Received 93 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:12 (2.2 minutes) and wrote 90 records for USDTRY | 2018-12-05 13:50:18 HD Request # 3421 | Completion time: 0s | 2018-12-05 13:50:18 HD Request # 3421 | Intraday data download complete for USDTRY. Unique request ID: 4026 | 2018-12-05 13:50:18 Removed historical data download ID 4026 | 2018-12-05 13:50:18 Real-time Intraday chart data file updates started for USDTRY | 2018-12-05 13:50:18 Intraday chart data file opened for USDTRY | 2018-12-05 13:50:18 HD Request # 3422 | Downloading Intraday chart data for USDZAR to the file USDZAR.scid. Service: lmax | 2018-12-05 13:50:18 HD Request # 3422 | Download start date-time: 2018-12-05 13:48:02.000 | 2018-12-05 13:50:18 HD Request # 3422 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:18 Socket (5) | Creating socket. | 2018-12-05 13:50:18 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:18 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:18 Socket (4) | Closed. | 2018-12-05 13:50:18 HD Request # 3422 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:18 HD Request # 3422 | Sending historical data logon request message. | 2018-12-05 13:50:18 Opened cached Intraday file: C:\SierraChart\Data\UK100.scid | 2018-12-05 13:50:18 Opened cached Intraday file: C:\SierraChart\Data\USDTRY.scid | 2018-12-05 13:50:18 HD Request # 3422 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:02. Record interval: 0. Symbol: USDZAR | 2018-12-05 13:50:18 HD Request # 3422 | Decompressing data. | 2018-12-05 13:50:18 HD Request # 3422 | Receiving Intraday data for USDZAR starting at 2018-12-05 13:48:02 | 2018-12-05 13:50:18 HD Request # 3422 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:18 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:18 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:18 Historical data download thread signaled to stop. | 2018-12-05 13:50:18 HD Request # 3422 | Received 365 records from 2018-12-05 13:48:02 to 2018-12-05 13:50:16 (2.2 minutes) and wrote 364 records for USDZAR | 2018-12-05 13:50:18 Added 3 Time and Sales records to Intraday data file for USDZAR after download. | 2018-12-05 13:50:18 HD Request # 3422 | Completion time: 0s | 2018-12-05 13:50:18 HD Request # 3422 | Intraday data download complete for USDZAR. Unique request ID: 4027 | 2018-12-05 13:50:18 Removed historical data download ID 4027 | 2018-12-05 13:50:18 Real-time Intraday chart data file updates started for USDZAR | 2018-12-05 13:50:18 Intraday chart data file opened for USDZAR | 2018-12-05 13:50:18 HD Request # 3423 | Downloading Intraday chart data for WS30 to the file WS30.scid. Service: lmax | 2018-12-05 13:50:18 HD Request # 3423 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:18 HD Request # 3423 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:18 Socket (4) | Creating socket. | 2018-12-05 13:50:18 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:18 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:18 Socket (5) | Closed. | 2018-12-05 13:50:18 HD Request # 3423 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:18 HD Request # 3423 | Sending historical data logon request message. | 2018-12-05 13:50:18 HD Request # 3423 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: WS30 | 2018-12-05 13:50:18 HD Request # 3423 | Decompressing data. | 2018-12-05 13:50:18 HD Request # 3423 | Receiving Intraday data for WS30 starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:18 HD Request # 3423 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:18 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:18 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:18 Historical data download thread signaled to stop. | 2018-12-05 13:50:18 HD Request # 3423 | Received 87 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:11 (2.2 minutes) and wrote 86 records for WS30 | 2018-12-05 13:50:18 HD Request # 3423 | Completion time: 1s | 2018-12-05 13:50:18 HD Request # 3423 | Intraday data download complete for WS30. Unique request ID: 4028 | 2018-12-05 13:50:18 Removed historical data download ID 4028 | 2018-12-05 13:50:18 Real-time Intraday chart data file updates started for WS30 | 2018-12-05 13:50:18 Intraday chart data file opened for WS30 | 2018-12-05 13:50:18 HD Request # 3424 | Downloading Intraday chart data for XAGUSD to the file XAGUSD.scid. Service: lmax | 2018-12-05 13:50:18 HD Request # 3424 | Download start date-time: 2018-12-05 13:47:52.000 | 2018-12-05 13:50:18 HD Request # 3424 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:18 Socket (5) | Creating socket. | 2018-12-05 13:50:18 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:18 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:18 Socket (4) | Closed. | 2018-12-05 13:50:18 HD Request # 3424 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:18 HD Request # 3424 | Sending historical data logon request message. | 2018-12-05 13:50:18 HD Request # 3424 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:52. Record interval: 0. Symbol: XAGUSD | 2018-12-05 13:50:19 HD Request # 3424 | Decompressing data. | 2018-12-05 13:50:19 HD Request # 3424 | Receiving Intraday data for XAGUSD starting at 2018-12-05 13:47:52 | 2018-12-05 13:50:19 HD Request # 3424 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:05 | 2018-12-05 13:50:19 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:19 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:19 Historical data download thread signaled to stop. | 2018-12-05 13:50:19 HD Request # 3424 | Received 41 records from 2018-12-05 13:47:52 to 2018-12-05 13:49:58 (2.1 minutes) and wrote 40 records for XAGUSD | 2018-12-05 13:50:19 HD Request # 3424 | Completion time: 0s | 2018-12-05 13:50:19 HD Request # 3424 | Intraday data download complete for XAGUSD. Unique request ID: 4029 | 2018-12-05 13:50:19 Removed historical data download ID 4029 | 2018-12-05 13:50:19 Real-time Intraday chart data file updates started for XAGUSD | 2018-12-05 13:50:19 Intraday chart data file opened for XAGUSD | 2018-12-05 13:50:19 HD Request # 3425 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: lmax | 2018-12-05 13:50:19 HD Request # 3425 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:19 HD Request # 3425 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:19 Socket (4) | Creating socket. | 2018-12-05 13:50:19 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:19 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:19 Socket (5) | Closed. | 2018-12-05 13:50:19 HD Request # 3425 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:19 HD Request # 3425 | Sending historical data logon request message. | 2018-12-05 13:50:19 HD Request # 3425 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: XAUUSD | 2018-12-05 13:50:19 HD Request # 3425 | Decompressing data. | 2018-12-05 13:50:19 HD Request # 3425 | Receiving Intraday data for XAUUSD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:19 HD Request # 3425 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:19 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:19 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:19 Historical data download thread signaled to stop. | 2018-12-05 13:50:19 HD Request # 3425 | Received 63 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:10 (2.2 minutes) and wrote 62 records for XAUUSD | 2018-12-05 13:50:19 HD Request # 3425 | Completion time: 0s | 2018-12-05 13:50:19 HD Request # 3425 | Intraday data download complete for XAUUSD. Unique request ID: 4030 | 2018-12-05 13:50:19 Removed historical data download ID 4030 | 2018-12-05 13:50:19 Real-time Intraday chart data file updates started for XAUUSD | 2018-12-05 13:50:19 Intraday chart data file opened for XAUUSD | 2018-12-05 13:50:19 HD Request # 3426 | Downloading Intraday chart data for XBRUSD to the file XBRUSD.scid. Service: lmax | 2018-12-05 13:50:19 HD Request # 3426 | Download start date-time: 2018-12-05 13:47:56.000 | 2018-12-05 13:50:19 HD Request # 3426 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:19 Socket (5) | Creating socket. | 2018-12-05 13:50:19 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:19 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:19 Socket (4) | Closed. | 2018-12-05 13:50:19 HD Request # 3426 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:19 HD Request # 3426 | Sending historical data logon request message. | 2018-12-05 13:50:19 HD Request # 3426 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:56. Record interval: 0. Symbol: XBRUSD | 2018-12-05 13:50:19 HD Request # 3426 | Decompressing data. | 2018-12-05 13:50:19 HD Request # 3426 | Receiving Intraday data for XBRUSD starting at 2018-12-05 13:47:56 | 2018-12-05 13:50:19 HD Request # 3426 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:04 | 2018-12-05 13:50:19 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:19 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:19 Historical data download thread signaled to stop. | 2018-12-05 13:50:19 HD Request # 3426 | Received 58 records from 2018-12-05 13:47:56 to 2018-12-05 13:50:03 (2.1 minutes) and wrote 57 records for XBRUSD | 2018-12-05 13:50:19 HD Request # 3426 | Completion time: 1s | 2018-12-05 13:50:19 HD Request # 3426 | Intraday data download complete for XBRUSD. Unique request ID: 4031 | 2018-12-05 13:50:19 Removed historical data download ID 4031 | 2018-12-05 13:50:19 Real-time Intraday chart data file updates started for XBRUSD | 2018-12-05 13:50:19 Intraday chart data file opened for XBRUSD | 2018-12-05 13:50:19 HD Request # 3427 | Downloading Intraday chart data for XNGUSD to the file XNGUSD.scid. Service: lmax | 2018-12-05 13:50:19 HD Request # 3427 | Download start date-time: 2018-12-05 13:48:01.000 | 2018-12-05 13:50:19 HD Request # 3427 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:19 Socket (4) | Creating socket. | 2018-12-05 13:50:19 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:19 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:19 Socket (5) | Closed. | 2018-12-05 13:50:19 HD Request # 3427 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:19 HD Request # 3427 | Sending historical data logon request message. | 2018-12-05 13:50:19 HD Request # 3427 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:01. Record interval: 0. Symbol: XNGUSD | 2018-12-05 13:50:20 HD Request # 3427 | Decompressing data. | 2018-12-05 13:50:20 HD Request # 3427 | Receiving Intraday data for XNGUSD starting at 2018-12-05 13:48:01 | 2018-12-05 13:50:20 HD Request # 3427 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:20 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:20 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:20 Historical data download thread signaled to stop. | 2018-12-05 13:50:20 HD Request # 3427 | Received 53 records from 2018-12-05 13:48:01 to 2018-12-05 13:50:16 (2.3 minutes) and wrote 52 records for XNGUSD | 2018-12-05 13:50:20 Added 1 Time and Sales records to Intraday data file for XNGUSD after download. | 2018-12-05 13:50:20 HD Request # 3427 | Completion time: 0s | 2018-12-05 13:50:20 HD Request # 3427 | Intraday data download complete for XNGUSD. Unique request ID: 4032 | 2018-12-05 13:50:20 Removed historical data download ID 4032 | 2018-12-05 13:50:20 Real-time Intraday chart data file updates started for XNGUSD | 2018-12-05 13:50:20 Intraday chart data file opened for XNGUSD | 2018-12-05 13:50:20 HD Request # 3428 | Downloading Intraday chart data for XPDUSD to the file XPDUSD.scid. Service: lmax | 2018-12-05 13:50:20 HD Request # 3428 | Download start date-time: 2018-12-05 13:47:33.000 | 2018-12-05 13:50:20 HD Request # 3428 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:20 Socket (5) | Creating socket. | 2018-12-05 13:50:20 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:20 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:20 Socket (4) | Closed. | 2018-12-05 13:50:20 HD Request # 3428 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:20 HD Request # 3428 | Sending historical data logon request message. | 2018-12-05 13:50:20 HD Request # 3428 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:33. Record interval: 0. Symbol: XPDUSD | 2018-12-05 13:50:20 HD Request # 3428 | Decompressing data. | 2018-12-05 13:50:20 HD Request # 3428 | Receiving Intraday data for XPDUSD starting at 2018-12-05 13:47:33 | 2018-12-05 13:50:20 HD Request # 3428 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:43 | 2018-12-05 13:50:20 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:20 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:20 Historical data download thread signaled to stop. | 2018-12-05 13:50:20 HD Request # 3428 | Received 8 records from 2018-12-05 13:47:33 to 2018-12-05 13:50:07 (2.6 minutes) and wrote 7 records for XPDUSD | 2018-12-05 13:50:20 HD Request # 3428 | Completion time: 0s | 2018-12-05 13:50:20 HD Request # 3428 | Intraday data download complete for XPDUSD. Unique request ID: 4033 | 2018-12-05 13:50:20 Removed historical data download ID 4033 | 2018-12-05 13:50:20 Real-time Intraday chart data file updates started for XPDUSD | 2018-12-05 13:50:20 Intraday chart data file opened for XPDUSD | 2018-12-05 13:50:20 HD Request # 3429 | Downloading Intraday chart data for XPTUSD to the file XPTUSD.scid. Service: lmax | 2018-12-05 13:50:20 HD Request # 3429 | Download start date-time: 2018-12-05 13:47:59.000 | 2018-12-05 13:50:20 HD Request # 3429 | Using server: lmaxhd.sierracharts.com port 10150 | 2018-12-05 13:50:20 Socket (4) | Creating socket. | 2018-12-05 13:50:20 Socket (4) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:20 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:20 Socket (5) | Closed. | 2018-12-05 13:50:20 HD Request # 3429 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:20 HD Request # 3429 | Sending historical data logon request message. | 2018-12-05 13:50:20 HD Request # 3429 | Requesting Intraday data. Start date-time: 2018-12-05 13:47:59. Record interval: 0. Symbol: XPTUSD | 2018-12-05 13:50:20 HD Request # 3429 | Decompressing data. | 2018-12-05 13:50:20 HD Request # 3429 | Receiving Intraday data for XPTUSD starting at 2018-12-05 13:47:59 | 2018-12-05 13:50:20 HD Request # 3429 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:07 | 2018-12-05 13:50:20 Socket (4) | Signaling to core to close socket | 2018-12-05 13:50:20 Socket (4) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:20 Historical data download thread signaled to stop. | 2018-12-05 13:50:20 HD Request # 3429 | Received 44 records from 2018-12-05 13:47:59 to 2018-12-05 13:50:08 (2.1 minutes) and wrote 43 records for XPTUSD | 2018-12-05 13:50:20 HD Request # 3429 | Completion time: 0s | 2018-12-05 13:50:20 HD Request # 3429 | Intraday data download complete for XPTUSD. Unique request ID: 4034 | 2018-12-05 13:50:20 Removed historical data download ID 4034 | 2018-12-05 13:50:20 Real-time Intraday chart data file updates started for XPTUSD | 2018-12-05 13:50:20 Intraday chart data file opened for XPTUSD | 2018-12-05 13:50:20 HD Request # 3430 | Downloading Intraday chart data for XTIUSD to the file XTIUSD.scid. Service: lmax | 2018-12-05 13:50:20 HD Request # 3430 | Download start date-time: 2018-12-05 13:48:03.000 | 2018-12-05 13:50:20 HD Request # 3430 | Using server: lmaxhd.sierracharts.com port 10149 | 2018-12-05 13:50:20 Socket (5) | Creating socket. | 2018-12-05 13:50:20 Socket (5) | Connecting to IP: 54.36.166.122. | 2018-12-05 13:50:20 Socket (4) | Socket gracefully closed by remote side. | 2018-12-05 13:50:20 Socket (4) | Closed. | 2018-12-05 13:50:20 HD Request # 3430 | Setting DTC encoding to Binary VLS | 2018-12-05 13:50:20 HD Request # 3430 | Sending historical data logon request message. | 2018-12-05 13:50:20 HD Request # 3430 | Requesting Intraday data. Start date-time: 2018-12-05 13:48:03. Record interval: 0. Symbol: XTIUSD | 2018-12-05 13:50:21 HD Request # 3430 | Decompressing data. | 2018-12-05 13:50:21 HD Request # 3430 | Receiving Intraday data for XTIUSD starting at 2018-12-05 13:48:03 | 2018-12-05 13:50:21 HD Request # 3430 | Timestamp of first Intraday data file record written: 2018-12-05 13:48:03 | 2018-12-05 13:50:21 Socket (5) | Signaling to core to close socket | 2018-12-05 13:50:21 Socket (5) | Shutdown started. Waiting for graceful close. | 2018-12-05 13:50:21 Historical data download thread signaled to stop. | 2018-12-05 13:50:21 HD Request # 3430 | Received 39 records from 2018-12-05 13:48:03 to 2018-12-05 13:50:06 (2.1 minutes) and wrote 37 records for XTIUSD | 2018-12-05 13:50:21 HD Request # 3430 | Completion time: 0s | 2018-12-05 13:50:21 HD Request # 3430 | Intraday data download complete for XTIUSD. Unique request ID: 4035 | 2018-12-05 13:50:21 Removed historical data download ID 4035 | 2018-12-05 13:50:21 Real-time Intraday chart data file updates started for XTIUSD | 2018-12-05 13:50:21 Intraday chart data file opened for XTIUSD | 2018-12-05 13:50:21 Socket (5) | Socket gracefully closed by remote side. | 2018-12-05 13:50:21 Socket (5) | Closed. | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\XPTUSD.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\WS30.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\SPX.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\HSI.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\LTCUSD-BITFINEX.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\USDZAR.scid | 2018-12-05 13:50:21 Opened cached Intraday file: C:\SierraChart\Data\NEOUSD-BITFINEX.scid | 2018-12-05 13:50:24 Opened cached Intraday file: C:\SierraChart\Data\NZDUSD.scid | 2018-12-05 13:50:24 Opened cached Intraday file: C:\SierraChart\Data\USDCAD.scid | 2018-12-05 13:50:24 Opened cached Intraday file: C:\SierraChart\Data\XNGUSD.scid | 2018-12-05 13:50:27 Opened cached Intraday file: C:\SierraChart\Data\XRPUSD-BITFINEX.scid | 2018-12-05 13:50:27 Opened cached Intraday file: C:\SierraChart\Data\NZDCHF.scid | 2018-12-05 13:50:27 Opened cached Intraday file: C:\SierraChart\Data\USDCHF.scid | 2018-12-05 13:50:27 Opened cached Intraday file: C:\SierraChart\Data\USDJPY.scid | 2018-12-05 13:50:27 Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid | 2018-12-05 13:50:30 Opened cached Intraday file: C:\SierraChart\Data\XAGUSD.scid | 2018-12-05 13:50:30 Opened cached Intraday file: C:\SierraChart\Data\EOSUSD-BITFINEX.scid | 2018-12-05 13:50:30 Opened cached Intraday file: C:\SierraChart\Data\NZDJPY.scid | 2018-12-05 13:50:30 Opened cached Intraday file: C:\SierraChart\Data\ZECUSD-BITFINEX.scid | 2018-12-05 13:50:36 Opened cached Intraday file: C:\SierraChart\Data\XBRUSD.scid | 2018-12-05 13:50:39 Opened cached Intraday file: C:\SierraChart\Data\XTIUSD.scid | 2018-12-05 13:50:39 Opened cached Intraday file: C:\SierraChart\Data\ETCUSD-BITFINEX.scid | 2018-12-05 13:50:39 Opened cached Intraday file: C:\SierraChart\Data\STOXX50E.scid | 2018-12-05 13:50:45 Opened cached Intraday file: C:\SierraChart\Data\J225.scid | 2018-12-05 13:50:45 Opened cached Intraday file: C:\SierraChart\Data\XPDUSD.scid | 2018-12-05 13:50:48 Opened cached Intraday file: C:\SierraChart\Data\OMGUSD-BITFINEX.scid | 2018-12-05 13:50:51 Opened cached Intraday file: C:\SierraChart\Data\DSHUSD-BITFINEX.scid | 2018-12-05 13:51:06 Opened cached Intraday file: C:\SierraChart\Data\XMRUSD-BITFINEX.scid | 2018-12-05 13:52:57 |
| [2018-12-07 07:27:18] |
| ILIM KIRGIZ - Posts: 187 |
Hi again, Out of order timestamps detected. Performing a full recalculation because it has been tagged. What would be the solution to my problem? Thanks. Ilim |
| [2018-12-09 11:21:16] |
Will someone guide me about this issue, please? Thanks. |
| [2018-12-09 20:33:21] |
Any data issues with Bitfinex symbols we decline support for other than the few major symbols they offer.
| [2018-12-10 06:27:41] |
thank you for reply but bchusd is a major symbol. Isn't it?
| [2018-12-10 19:08:29] |
We do not want to get involved in this. This is going to be a Bitfinex issue. This is just simply not worth our time. We cannot control external service issues.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-12-10 19:08:54
| [2018-12-11 06:21:51] |
Could you please just let me know that you see the latest data for BCHUSD in your side or not. I'll handle the rest per your answer. Thanks. |
| [2018-12-11 21:05:58] |
No we do not. The data is not coming from Bitfinex. And we are not going to look into this. They do not have our respect.
| [2018-12-12 06:15:27] |
ok thanks for letting me know and saving my time as well.
