Date/Time: Mon, 13 May 2024 03:49:17 +0000
Chart
View Count: 573
[2018-08-20 23:36:20] |
robna - Posts: 18 |
My chart has gone hatwire completely. I cannot open my chart. It flashes all kings of things off and on my screen. |
[2018-08-21 20:25:14] |
Disregard the prior message. It was deleted. It was meant for another thread. We want you to not use your current Chartbook. Restart Sierra Chart in Safe Mode following the instructions here: Sierra Chart - Software Login Instructions: Using Safe Mode start with new charts and then attach the Chartbook you are having a problem with and we will test it. Here are instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
