Date/Time: Sat, 11 May 2024 06:28:50 +0000
Daily Charts Not 5 day charts
View Count: 903
[2018-08-20 19:16:33] |
User297050 - Posts: 50 |
I am a new user and love the Sierra Charts as they are superior to anything I have used including TOS but my daily charts for futures are not valid as they are not 5 day charts based on the NY daily close. They have a partial day for Sunday and a partial day for Friday and the other days start at midnight (UGGGG). Is there a way to correct this into valid 5 day daily charts?
[2018-08-20 19:46:28] |
This is not clear for us. Did you want weekly chart bars? What timeframe do you want for the chart bars? Do you just want to see the day session charted only?
[2018-08-20 23:20:55] |
A true chart bar for the daily futures activity should only show 5 days in the week and the daily bar should end each day with the NY Close. Your charts do not show that way on my computer and my question is how do I get those daily charts to show correctly or are you committed to the daily chart bar beginning at midnight.
[2018-08-20 23:41:33] |
Ok I figured it out. I can change the default from midnight to midnight to what I want to see on the Chart Settings. Problem Solved.
[2018-08-20 23:46:09] |
Yes you just need to adjust the Session Times and related settings. They are all documented here: Chart Session Times Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
