Date/Time: Mon, 20 May 2024 16:21:36 +0000
wrong user name
View Count: 755
[2018-08-17 07:14:45] |
Grateful55 - Posts: 32 |
my account is saying wrong user name but its letting me sign in but not pulling up my charts I have the current version
[2018-08-17 07:32:30] |
Provide a copy of the Message Log by following these instructions: Support Board Posting Information: How to Post Your Message Log (Required In Some Cases) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-17 08:02:11] |
Reading Internal Order ID file. | 2018-08-17 07:58:30 Reading Trade Orders file. | 2018-08-17 07:58:30 Reading Trade Positions and Account Balance file. | 2018-08-17 07:58:30 Listening on UDP port 22904. | 2018-08-17 07:58:30 Software version: 1785 64-bit | 2018-08-17 07:58:30 Safe Mode enabled | 2018-08-17 07:58:30 Usage end date: 2018-11-09 | 2018-08-17 07:58:30 Enabled for: Advanced Features. | 2018-08-17 07:58:30 Enabled for: Advanced Features 2. | 2018-08-17 07:58:30 Enabled for: Sierra Chart Historical Data Service. | 2018-08-17 07:58:30 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-08-17 07:58:30 Enabled for: INDEXES_DATA_BARCHART | 2018-08-17 07:58:30 Enabled for: CME (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: CBOT (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: COMEX (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: NYMEX (Trading Account Required) | 2018-08-17 07:58:30 Received 1 data feed usernames. | 2018-08-17 07:58:30 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-17 07:58:30 Current selected Data/Trading service: CTS T4 FIX | 2018-08-17 07:58:30 Chart Update Interval: 500 | 2018-08-17 07:58:30 Time Zone: +00:00:00 (UTC+00) | 2018-08-17 07:58:30 2018-08-17 02:58:30 Local computer time | 2018-08-17 07:58:30 2018-08-17 07:58:30 Local computer time in UTC | 2018-08-17 07:58:30 2018-08-17 07:58:30 Local computer time in SC Time Zone | 2018-08-17 07:58:30 2018-08-17 07:58:20 Server time in UTC | 2018-08-17 07:58:30 Local computer UTC time and Server UTC time difference: 7 seconds. | 2018-08-17 07:58:30 Program path: C:\SierraChart\ | 2018-08-17 07:58:30 Data Files path: C:\SierraChart\Data\ | 2018-08-17 07:58:30 OS Version Number: 10.0 | 2018-08-17 07:58:30 Locale Setting: C | 2018-08-17 07:58:30 Checking for new symbol settings for service code cts | 2018-08-17 07:58:30 HTTPS connection to www.sierrachart.com:443 (8) | Creating socket. Using TLS 1.2. | 2018-08-17 07:58:30 HTTPS connection to www.sierrachart.com:443 (8) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:58:30 Received 5 login tokens. | 2018-08-17 07:58:30 Symbol settings are up-to-date for cts | 2018-08-17 07:58:31 HTTPS connection to www.sierrachart.com:443 (9) | Creating socket. Using TLS 1.2. | 2018-08-17 07:58:32 HTTPS connection to www.sierrachart.com:443 (9) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Closed. | 2018-08-17 07:58:32 HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2018-08-17 07:58:36 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:36 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:36 CTS FIX socket (10) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:36 CTS FIX socket (10) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Received socket Close event. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Initiating close of socket by core. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Closed. | 2018-08-17 07:58:36 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:36 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:36 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:36 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:36 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:36 CTS FIX socket (10) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:36 CTS FIX socket (10) | Initiating close of socket by core. | 2018-08-17 07:58:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:36 CTS FIX socket (10) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:36 CTS FIX socket (10) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:36 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:36 CTS FIX socket (10) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 CTS FIX socket (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:36 * CTS FIX socket (10) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:36 CTS FIX socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 CTS FIX socket (10) | Closed. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (9) | Socket gracefully closed by remote side. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Received socket Close event. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Initiating close of socket by core. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Closed. | 2018-08-17 07:58:38 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:39 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:39 CTS FIX socket (11) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:39 CTS FIX socket (11) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:39 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:39 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:39 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:39 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:39 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:39 CTS FIX socket (11) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:39 CTS FIX socket (11) | Initiating close of socket by core. | 2018-08-17 07:58:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:39 CTS FIX socket (11) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:39 CTS FIX socket (11) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:39 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:39 CTS FIX socket (11) | Socket gracefully closed by remote side. | 2018-08-17 07:58:39 CTS FIX socket (11) | Received socket Close event. | 2018-08-17 07:58:39 CTS FIX socket (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:39 * CTS FIX socket (11) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:39 CTS FIX socket (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:39 CTS FIX socket (11) | Closed. | 2018-08-17 07:58:39 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:42 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:42 CTS FIX socket (12) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:42 CTS FIX socket (12) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:42 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:43 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:43 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:43 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:43 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:43 CTS FIX socket (12) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:43 CTS FIX socket (12) | Initiating close of socket by core. | 2018-08-17 07:58:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:43 CTS FIX socket (12) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:43 CTS FIX socket (12) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:43 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:43 CTS FIX socket (12) | Socket gracefully closed by remote side. | 2018-08-17 07:58:43 CTS FIX socket (12) | Received socket Close event. | 2018-08-17 07:58:43 CTS FIX socket (12) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:43 * CTS FIX socket (12) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:43 CTS FIX socket (12) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:43 CTS FIX socket (12) | Closed. | 2018-08-17 07:58:43 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:46 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:46 CTS FIX socket (13) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:46 CTS FIX socket (13) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:58:46 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:46 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:46 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:46 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:46 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:46 CTS FIX socket (13) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:46 CTS FIX socket (13) | Initiating close of socket by core. | 2018-08-17 07:58:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:46 CTS FIX socket (13) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:46 CTS FIX socket (13) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:46 CTS FIX socket (13) | Socket gracefully closed by remote side. | 2018-08-17 07:58:46 CTS FIX socket (13) | Received socket Close event. | 2018-08-17 07:58:46 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:46 CTS FIX socket (13) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:46 CTS FIX socket (13) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:46 CTS FIX socket (13) | Closed. | 2018-08-17 07:58:46 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:49 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:49 CTS FIX socket (14) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:49 CTS FIX socket (14) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:49 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:49 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:49 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:49 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:49 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:49 CTS FIX socket (14) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:49 CTS FIX socket (14) | Initiating close of socket by core. | 2018-08-17 07:58:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:49 CTS FIX socket (14) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:49 CTS FIX socket (14) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:49 CTS FIX socket (14) | Socket gracefully closed by remote side. | 2018-08-17 07:58:49 CTS FIX socket (14) | Received socket Close event. | 2018-08-17 07:58:49 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:49 CTS FIX socket (14) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:49 * CTS FIX socket (14) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:49 CTS FIX socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:49 CTS FIX socket (14) | Closed. | 2018-08-17 07:58:49 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:52 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:52 CTS FIX socket (15) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:52 CTS FIX socket (15) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:52 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:53 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:53 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:53 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:53 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:53 CTS FIX socket (15) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:53 CTS FIX socket (15) | Initiating close of socket by core. | 2018-08-17 07:58:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:53 CTS FIX socket (15) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:53 CTS FIX socket (15) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:53 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:53 CTS FIX socket (15) | Socket gracefully closed by remote side. | 2018-08-17 07:58:53 CTS FIX socket (15) | Received socket Close event. | 2018-08-17 07:58:53 CTS FIX socket (15) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:53 * CTS FIX socket (15) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:53 CTS FIX socket (15) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:53 CTS FIX socket (15) | Closed. | 2018-08-17 07:58:53 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:56 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:56 CTS FIX socket (16) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:56 CTS FIX socket (16) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:56 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:56 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:56 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:56 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:56 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:56 CTS FIX socket (16) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:56 CTS FIX socket (16) | Initiating close of socket by core. | 2018-08-17 07:58:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:56 CTS FIX socket (16) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:56 CTS FIX socket (16) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:56 CTS FIX socket (16) | Socket gracefully closed by remote side. | 2018-08-17 07:58:56 CTS FIX socket (16) | Received socket Close event. | 2018-08-17 07:58:56 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:56 CTS FIX socket (16) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:56 * CTS FIX socket (16) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:56 CTS FIX socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:56 CTS FIX socket (16) | Closed. | 2018-08-17 07:58:56 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:59 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:59 CTS FIX socket (17) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:59 CTS FIX socket (17) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:59 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:59 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:59 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:59 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:59 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:59 CTS FIX socket (17) | Initiating close of socket by core. | 2018-08-17 07:58:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:59 CTS FIX socket (17) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:59 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:59 CTS FIX socket (17) | Socket gracefully closed by remote side. | 2018-08-17 07:58:59 CTS FIX socket (17) | Received socket Close event. | 2018-08-17 07:58:59 CTS FIX socket (17) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:59 * CTS FIX socket (17) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:59 CTS FIX socket (17) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:59 CTS FIX socket (17) | Closed. | 2018-08-17 07:58:59 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:02 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:02 CTS FIX socket (18) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:03 CTS FIX socket (18) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:03 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:03 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:04 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:04 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:04 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:04 CTS FIX socket (18) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:04 CTS FIX socket (18) | Initiating close of socket by core. | 2018-08-17 07:59:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:04 CTS FIX socket (18) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:04 CTS FIX socket (18) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:04 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:04 CTS FIX socket (18) | Socket gracefully closed by remote side. | 2018-08-17 07:59:04 CTS FIX socket (18) | Received socket Close event. | 2018-08-17 07:59:04 CTS FIX socket (18) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:04 * CTS FIX socket (18) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:04 CTS FIX socket (18) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:04 CTS FIX socket (18) | Closed. | 2018-08-17 07:59:04 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:07 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:07 CTS FIX socket (19) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:07 CTS FIX socket (19) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:07 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:07 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:07 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:07 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:07 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:07 CTS FIX socket (19) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:07 CTS FIX socket (19) | Initiating close of socket by core. | 2018-08-17 07:59:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:07 CTS FIX socket (19) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:07 CTS FIX socket (19) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:07 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:07 CTS FIX socket (19) | Socket gracefully closed by remote side. | 2018-08-17 07:59:07 CTS FIX socket (19) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:07 * CTS FIX socket (19) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:07 CTS FIX socket (19) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:07 CTS FIX socket (19) | Closed. | 2018-08-17 07:59:07 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:10 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:10 CTS FIX socket (20) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:10 CTS FIX socket (20) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:10 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:10 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:10 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:10 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:10 * CTS FIX socket (20) | Socket gracefully closed by remote side. | 2018-08-17 07:59:10 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:10 CTS FIX socket (20) | Received socket Close event. | 2018-08-17 07:59:10 CTS FIX socket (20) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:10 CTS FIX socket (20) | Initiating close of socket by core. | 2018-08-17 07:59:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:10 CTS FIX socket (20) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:10 CTS FIX socket (20) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:10 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:10 CTS FIX socket (20) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:10 * CTS FIX socket (20) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:10 CTS FIX socket (20) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:10 CTS FIX socket (20) | Closed. | 2018-08-17 07:59:10 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:13 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:13 CTS FIX socket (21) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:13 CTS FIX socket (21) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:13 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:14 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:14 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:14 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:14 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:14 CTS FIX socket (21) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:14 CTS FIX socket (21) | Initiating close of socket by core. | 2018-08-17 07:59:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:14 CTS FIX socket (21) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:14 CTS FIX socket (21) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:14 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:14 CTS FIX socket (21) | Socket gracefully closed by remote side. | 2018-08-17 07:59:14 CTS FIX socket (21) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:14 * CTS FIX socket (21) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:14 CTS FIX socket (21) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:14 CTS FIX socket (21) | Closed. | 2018-08-17 07:59:14 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:17 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:17 CTS FIX socket (22) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:17 CTS FIX socket (22) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:59:17 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:17 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:17 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:17 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:17 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:17 CTS FIX socket (22) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:17 CTS FIX socket (22) | Initiating close of socket by core. | 2018-08-17 07:59:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:17 CTS FIX socket (22) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:17 CTS FIX socket (22) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:17 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:17 CTS FIX socket (22) | Socket gracefully closed by remote side. | 2018-08-17 07:59:17 CTS FIX socket (22) | Received socket Close event. | 2018-08-17 07:59:17 CTS FIX socket (22) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:17 * CTS FIX socket (22) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:17 CTS FIX socket (22) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:17 CTS FIX socket (22) | Closed. | 2018-08-17 07:59:17 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:20 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:20 CTS FIX socket (23) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:20 CTS FIX socket (23) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:59:20 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:20 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:20 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:20 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:20 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:20 CTS FIX socket (23) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:20 CTS FIX socket (23) | Initiating close of socket by core. | 2018-08-17 07:59:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:20 CTS FIX socket (23) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:20 CTS FIX socket (23) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:20 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:20 CTS FIX socket (23) | Socket gracefully closed by remote side. | 2018-08-17 07:59:20 CTS FIX socket (23) | Received socket Close event. | 2018-08-17 07:59:20 CTS FIX socket (23) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:20 * CTS FIX socket (23) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:20 CTS FIX socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:20 CTS FIX socket (23) | Closed. | 2018-08-17 07:59:20 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:23 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:23 CTS FIX socket (24) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:23 CTS FIX socket (24) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:23 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:24 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:24 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:24 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:24 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:24 CTS FIX socket (24) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:24 CTS FIX socket (24) | Initiating close of socket by core. | 2018-08-17 07:59:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:24 CTS FIX socket (24) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:24 CTS FIX socket (24) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:24 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:24 CTS FIX socket (24) | Socket gracefully closed by remote side. | 2018-08-17 07:59:24 CTS FIX socket (24) | Received socket Close event. | 2018-08-17 07:59:24 CTS FIX socket (24) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:24 * CTS FIX socket (24) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:24 CTS FIX socket (24) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:24 CTS FIX socket (24) | Closed. | 2018-08-17 07:59:24 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:27 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:27 CTS FIX socket (25) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:27 CTS FIX socket (25) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:27 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:27 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:27 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:27 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:27 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:27 CTS FIX socket (25) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:27 CTS FIX socket (25) | Initiating close of socket by core. | 2018-08-17 07:59:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:27 CTS FIX socket (25) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:27 CTS FIX socket (25) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:27 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:27 CTS FIX socket (25) | Socket gracefully closed by remote side. | 2018-08-17 07:59:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:27 CTS FIX socket (25) | Received socket Close event. | 2018-08-17 07:59:27 CTS FIX socket (25) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:27 * CTS FIX socket (25) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:27 CTS FIX socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:27 CTS FIX socket (25) | Closed. | 2018-08-17 07:59:27 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:30 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:30 CTS FIX socket (27) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:30 CTS FIX socket (27) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:30 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:30 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:30 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:30 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:30 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:30 CTS FIX socket (27) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:30 CTS FIX socket (27) | Initiating close of socket by core. | 2018-08-17 07:59:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:30 CTS FIX socket (27) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:30 CTS FIX socket (27) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:30 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:30 CTS FIX socket (27) | Socket gracefully closed by remote side. | 2018-08-17 07:59:30 CTS FIX socket (27) | Received socket Close event. | 2018-08-17 07:59:30 CTS FIX socket (27) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:30 * CTS FIX socket (27) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:30 CTS FIX socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:30 CTS FIX socket (27) | Closed. | 2018-08-17 07:59:30 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:33 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:33 CTS FIX socket (28) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:33 CTS FIX socket (28) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:33 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:34 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:34 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:34 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:34 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:34 CTS FIX socket (28) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:34 CTS FIX socket (28) | Initiating close of socket by core. | 2018-08-17 07:59:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:34 CTS FIX socket (28) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:34 CTS FIX socket (28) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:34 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:34 CTS FIX socket (28) | Socket gracefully closed by remote side. | 2018-08-17 07:59:34 CTS FIX socket (28) | Received socket Close event. | 2018-08-17 07:59:34 CTS FIX socket (28) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:34 * CTS FIX socket (28) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:34 CTS FIX socket (28) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:34 CTS FIX socket (28) | Closed. | 2018-08-17 07:59:34 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:37 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:37 CTS FIX socket (29) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:37 CTS FIX socket (29) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:37 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:37 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:37 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:37 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:37 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:37 CTS FIX socket (29) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:37 CTS FIX socket (29) | Initiating close of socket by core. | 2018-08-17 07:59:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:37 CTS FIX socket (29) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:37 CTS FIX socket (29) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:37 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:37 CTS FIX socket (29) | Socket gracefully closed by remote side. | 2018-08-17 07:59:37 CTS FIX socket (29) | Received socket Close event. | 2018-08-17 07:59:37 CTS FIX socket (29) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:37 * CTS FIX socket (29) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:37 CTS FIX socket (29) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:37 CTS FIX socket (29) | Closed. | 2018-08-17 07:59:37 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:40 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:40 CTS FIX socket (30) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:40 CTS FIX socket (30) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:40 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:40 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:40 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:40 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:40 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:40 CTS FIX socket (30) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:40 CTS FIX socket (30) | Initiating close of socket by core. | 2018-08-17 07:59:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:40 CTS FIX socket (30) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:40 CTS FIX socket (30) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:40 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:40 CTS FIX socket (30) | Socket gracefully closed by remote side. | 2018-08-17 07:59:40 CTS FIX socket (30) | Received socket Close event. | 2018-08-17 07:59:40 CTS FIX socket (30) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:40 * CTS FIX socket (30) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:40 CTS FIX socket (30) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:40 CTS FIX socket (30) | Closed. | 2018-08-17 07:59:40 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:43 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:43 CTS FIX socket (31) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:43 CTS FIX socket (31) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:43 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:44 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:44 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:44 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:44 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:44 CTS FIX socket (31) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:44 CTS FIX socket (31) | Initiating close of socket by core. | 2018-08-17 07:59:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:44 CTS FIX socket (31) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:44 CTS FIX socket (31) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:44 CTS FIX socket (31) | Socket gracefully closed by remote side. | 2018-08-17 07:59:44 CTS FIX socket (31) | Received socket Close event. | 2018-08-17 07:59:44 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:44 CTS FIX socket (31) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:44 * CTS FIX socket (31) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:44 CTS FIX socket (31) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:44 CTS FIX socket (31) | Closed. | 2018-08-17 07:59:44 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:47 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:47 CTS FIX socket (32) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:47 CTS FIX socket (32) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:47 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:47 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:47 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:47 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:47 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:47 CTS FIX socket (32) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:47 CTS FIX socket (32) | Initiating close of socket by core. | 2018-08-17 07:59:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:47 CTS FIX socket (32) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:47 CTS FIX socket (32) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:47 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:47 CTS FIX socket (32) | Socket gracefully closed by remote side. | 2018-08-17 07:59:47 CTS FIX socket (32) | Received socket Close event. | 2018-08-17 07:59:47 CTS FIX socket (32) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:47 * CTS FIX socket (32) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:47 CTS FIX socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:47 CTS FIX socket (32) | Closed. | 2018-08-17 07:59:47 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:50 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:50 CTS FIX socket (33) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:50 CTS FIX socket (33) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:50 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:50 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:50 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:50 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:50 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:50 CTS FIX socket (33) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:50 CTS FIX socket (33) | Initiating close of socket by core. | 2018-08-17 07:59:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:50 CTS FIX socket (33) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:50 CTS FIX socket (33) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:50 CTS FIX socket (33) | Socket gracefully closed by remote side. | 2018-08-17 07:59:50 CTS FIX socket (33) | Received socket Close event. | 2018-08-17 07:59:50 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:50 CTS FIX socket (33) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:51 * CTS FIX socket (33) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:51 CTS FIX socket (33) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:51 CTS FIX socket (33) | Closed. | 2018-08-17 07:59:51 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:51 Checking for new symbol settings for service code cqg | 2018-08-17 07:59:51 Current selected Data/Trading service: CQG FIX Trading | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Creating socket. Using TLS 1.2. | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:59:51 Requesting symbol settings for service code cqg. Overwrite = on. | 2018-08-17 07:59:51 Symbol settings received. | 2018-08-17 07:59:51 Processed 1335 symbol settings. | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Socket gracefully closed by remote side. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Received socket Close event. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Initiating close of socket by core. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Closed. | 2018-08-17 07:59:56 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:29 CQG FIX socket (36) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:29 CQG FIX socket (36) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:29 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:29 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:29 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:29 CQG FIX socket (36) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:29 CQG FIX socket (36) | Initiating close of socket by core. | 2018-08-17 08:00:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:29 CQG FIX socket (36) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:29 CQG FIX socket (36) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:29 CQG FIX socket (36) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:29 CQG FIX socket (36) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:29 CQG FIX socket (36) | Socket gracefully closed by remote side. | 2018-08-17 08:00:30 CQG FIX socket (36) | Closed. | 2018-08-17 08:00:30 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:32 CQG FIX socket (37) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:32 CQG FIX socket (37) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:32 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:33 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:33 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:33 CQG FIX socket (37) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:33 CQG FIX socket (37) | Initiating close of socket by core. | 2018-08-17 08:00:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:33 CQG FIX socket (37) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:33 CQG FIX socket (37) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:33 CQG FIX socket (37) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:33 CQG FIX socket (37) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:33 CQG FIX socket (37) | Socket gracefully closed by remote side. | 2018-08-17 08:00:33 CQG FIX socket (37) | Closed. | 2018-08-17 08:00:33 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:36 CQG FIX socket (38) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:36 CQG FIX socket (38) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:36 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:36 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:37 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:37 CQG FIX socket (38) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:37 CQG FIX socket (38) | Initiating close of socket by core. | 2018-08-17 08:00:37 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:37 CQG FIX socket (38) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:37 CQG FIX socket (38) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:37 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:37 CQG FIX socket (38) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:37 CQG FIX socket (38) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:37 CQG FIX socket (38) | Socket gracefully closed by remote side. | 2018-08-17 08:00:37 CQG FIX socket (38) | Closed. | 2018-08-17 08:00:37 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:40 CQG FIX socket (39) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:40 CQG FIX socket (39) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:40 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:40 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:40 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:40 CQG FIX socket (39) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:40 CQG FIX socket (39) | Initiating close of socket by core. | 2018-08-17 08:00:40 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:40 CQG FIX socket (39) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:40 CQG FIX socket (39) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:40 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:40 CQG FIX socket (39) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:40 CQG FIX socket (39) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:40 CQG FIX socket (39) | Socket gracefully closed by remote side. | 2018-08-17 08:00:40 CQG FIX socket (39) | Closed. | 2018-08-17 08:00:40 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:43 CQG FIX socket (40) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:43 CQG FIX socket (40) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:43 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:43 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:43 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:43 CQG FIX socket (40) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:43 CQG FIX socket (40) | Initiating close of socket by core. | 2018-08-17 08:00:43 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:43 CQG FIX socket (40) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:43 CQG FIX socket (40) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:43 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:43 CQG FIX socket (40) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:44 CQG FIX socket (40) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:44 CQG FIX socket (40) | Socket gracefully closed by remote side. | 2018-08-17 08:00:44 CQG FIX socket (40) | Closed. | 2018-08-17 08:00:44 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:46 CQG FIX socket (41) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:46 CQG FIX socket (41) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:46 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:47 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:47 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:47 CQG FIX socket (41) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:47 CQG FIX socket (41) | Initiating close of socket by core. | 2018-08-17 08:00:47 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:47 CQG FIX socket (41) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:47 CQG FIX socket (41) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:47 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:47 CQG FIX socket (41) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:47 CQG FIX socket (41) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:47 CQG FIX socket (41) | Socket gracefully closed by remote side. | 2018-08-17 08:00:47 CQG FIX socket (41) | Closed. | 2018-08-17 08:00:47 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:50 CQG FIX socket (42) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:50 CQG FIX socket (42) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:50 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:50 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:50 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:50 CQG FIX socket (42) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:50 CQG FIX socket (42) | Initiating close of socket by core. | 2018-08-17 08:00:50 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:50 CQG FIX socket (42) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:50 CQG FIX socket (42) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:50 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:50 CQG FIX socket (42) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:50 CQG FIX socket (42) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:50 CQG FIX socket (42) | Socket gracefully closed by remote side. | 2018-08-17 08:00:50 CQG FIX socket (42) | Closed. | 2018-08-17 08:00:50 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:53 CQG FIX socket (43) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:53 CQG FIX socket (43) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:53 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:54 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:54 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:54 CQG FIX socket (43) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:54 CQG FIX socket (43) | Initiating close of socket by core. | 2018-08-17 08:00:54 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:54 CQG FIX socket (43) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:54 CQG FIX socket (43) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:54 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:54 CQG FIX socket (43) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:54 CQG FIX socket (43) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:54 CQG FIX socket (43) | Socket gracefully closed by remote side. | 2018-08-17 08:00:54 CQG FIX socket (43) | Closed. | 2018-08-17 08:00:54 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:57 CQG FIX socket (44) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:57 CQG FIX socket (44) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:57 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:57 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:57 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:57 CQG FIX socket (44) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:57 CQG FIX socket (44) | Initiating close of socket by core. | 2018-08-17 08:00:57 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:57 CQG FIX socket (44) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:57 CQG FIX socket (44) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:57 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:57 CQG FIX socket (44) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:57 CQG FIX socket (44) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:57 CQG FIX socket (44) | Socket gracefully closed by remote side. | 2018-08-17 08:00:57 CQG FIX socket (44) | Closed. | 2018-08-17 08:00:57 |
[2018-08-17 08:07:06] |
Grateful55 - Posts: 32 |
Reading Internal Order ID file. | 2018-08-17 07:58:30 Reading Trade Orders file. | 2018-08-17 07:58:30 Reading Trade Positions and Account Balance file. | 2018-08-17 07:58:30 Listening on UDP port 22904. | 2018-08-17 07:58:30 Software version: 1785 64-bit | 2018-08-17 07:58:30 Safe Mode enabled | 2018-08-17 07:58:30 Usage end date: 2018-11-09 | 2018-08-17 07:58:30 Enabled for: Advanced Features. | 2018-08-17 07:58:30 Enabled for: Advanced Features 2. | 2018-08-17 07:58:30 Enabled for: Sierra Chart Historical Data Service. | 2018-08-17 07:58:30 Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2018-08-17 07:58:30 Enabled for: INDEXES_DATA_BARCHART | 2018-08-17 07:58:30 Enabled for: CME (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: CBOT (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: COMEX (Trading Account Required) | 2018-08-17 07:58:30 Enabled for: NYMEX (Trading Account Required) | 2018-08-17 07:58:30 Received 1 data feed usernames. | 2018-08-17 07:58:30 Allow Support for Sierra Chart Data Feeds is enabled. | 2018-08-17 07:58:30 Current selected Data/Trading service: CTS T4 FIX | 2018-08-17 07:58:30 Chart Update Interval: 500 | 2018-08-17 07:58:30 Time Zone: +00:00:00 (UTC+00) | 2018-08-17 07:58:30 2018-08-17 02:58:30 Local computer time | 2018-08-17 07:58:30 2018-08-17 07:58:30 Local computer time in UTC | 2018-08-17 07:58:30 2018-08-17 07:58:30 Local computer time in SC Time Zone | 2018-08-17 07:58:30 2018-08-17 07:58:20 Server time in UTC | 2018-08-17 07:58:30 Local computer UTC time and Server UTC time difference: 7 seconds. | 2018-08-17 07:58:30 Program path: C:\SierraChart\ | 2018-08-17 07:58:30 Data Files path: C:\SierraChart\Data\ | 2018-08-17 07:58:30 OS Version Number: 10.0 | 2018-08-17 07:58:30 Locale Setting: C | 2018-08-17 07:58:30 Checking for new symbol settings for service code cts | 2018-08-17 07:58:30 HTTPS connection to www.sierrachart.com:443 (8) | Creating socket. Using TLS 1.2. | 2018-08-17 07:58:30 HTTPS connection to www.sierrachart.com:443 (8) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:58:30 Received 5 login tokens. | 2018-08-17 07:58:30 Symbol settings are up-to-date for cts | 2018-08-17 07:58:31 HTTPS connection to www.sierrachart.com:443 (9) | Creating socket. Using TLS 1.2. | 2018-08-17 07:58:32 HTTPS connection to www.sierrachart.com:443 (9) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Socket gracefully closed by remote side. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Received socket Close event. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Initiating close of socket by core. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:32 HTTPS connection to login.sierrachart.com:443 (5) | Closed. | 2018-08-17 07:58:32 HTTPS connection to www.sierrachart.com:443 (6) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Received socket Close event. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Initiating close of socket by core. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (6) | Closed. | 2018-08-17 07:58:36 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:36 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:36 CTS FIX socket (10) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:36 CTS FIX socket (10) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Received socket Close event. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Initiating close of socket by core. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (8) | Closed. | 2018-08-17 07:58:36 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:36 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:36 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:36 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:36 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:36 CTS FIX socket (10) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:36 CTS FIX socket (10) | Initiating close of socket by core. | 2018-08-17 07:58:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:36 CTS FIX socket (10) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:36 CTS FIX socket (10) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:36 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:36 CTS FIX socket (10) | Socket gracefully closed by remote side. | 2018-08-17 07:58:36 CTS FIX socket (10) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:36 * CTS FIX socket (10) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:36 CTS FIX socket (10) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:36 CTS FIX socket (10) | Closed. | 2018-08-17 07:58:36 HTTPS connection to www.sierrachart.com:443 (9) | Socket gracefully closed by remote side. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Received socket Close event. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Initiating close of socket by core. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:38 HTTPS connection to www.sierrachart.com:443 (9) | Closed. | 2018-08-17 07:58:38 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:39 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:39 CTS FIX socket (11) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:39 CTS FIX socket (11) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:39 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:39 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:39 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:39 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:39 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:39 CTS FIX socket (11) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:39 CTS FIX socket (11) | Initiating close of socket by core. | 2018-08-17 07:58:39 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:39 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:39 CTS FIX socket (11) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:39 CTS FIX socket (11) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:39 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:39 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:39 CTS FIX socket (11) | Socket gracefully closed by remote side. | 2018-08-17 07:58:39 CTS FIX socket (11) | Received socket Close event. | 2018-08-17 07:58:39 CTS FIX socket (11) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:39 * CTS FIX socket (11) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:39 CTS FIX socket (11) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:39 CTS FIX socket (11) | Closed. | 2018-08-17 07:58:39 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:42 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:42 CTS FIX socket (12) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:42 CTS FIX socket (12) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:42 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:43 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:43 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:43 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:43 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:43 CTS FIX socket (12) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:43 CTS FIX socket (12) | Initiating close of socket by core. | 2018-08-17 07:58:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:43 CTS FIX socket (12) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:43 CTS FIX socket (12) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:43 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:43 CTS FIX socket (12) | Socket gracefully closed by remote side. | 2018-08-17 07:58:43 CTS FIX socket (12) | Received socket Close event. | 2018-08-17 07:58:43 CTS FIX socket (12) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:43 * CTS FIX socket (12) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:43 CTS FIX socket (12) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:43 CTS FIX socket (12) | Closed. | 2018-08-17 07:58:43 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:46 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:46 CTS FIX socket (13) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:46 CTS FIX socket (13) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:58:46 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:46 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:46 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:46 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:46 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:46 CTS FIX socket (13) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:46 CTS FIX socket (13) | Initiating close of socket by core. | 2018-08-17 07:58:46 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:46 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:46 CTS FIX socket (13) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:46 CTS FIX socket (13) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:46 CTS FIX socket (13) | Socket gracefully closed by remote side. | 2018-08-17 07:58:46 CTS FIX socket (13) | Received socket Close event. | 2018-08-17 07:58:46 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:46 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:46 CTS FIX socket (13) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:46 CTS FIX socket (13) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:46 CTS FIX socket (13) | Closed. | 2018-08-17 07:58:46 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:49 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:49 CTS FIX socket (14) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:49 CTS FIX socket (14) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:49 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:49 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:49 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:49 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:49 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:49 CTS FIX socket (14) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:49 CTS FIX socket (14) | Initiating close of socket by core. | 2018-08-17 07:58:49 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:49 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:49 CTS FIX socket (14) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:49 CTS FIX socket (14) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:49 CTS FIX socket (14) | Socket gracefully closed by remote side. | 2018-08-17 07:58:49 CTS FIX socket (14) | Received socket Close event. | 2018-08-17 07:58:49 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:49 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:49 CTS FIX socket (14) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:49 * CTS FIX socket (14) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:49 CTS FIX socket (14) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:49 CTS FIX socket (14) | Closed. | 2018-08-17 07:58:49 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:52 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:52 CTS FIX socket (15) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:52 CTS FIX socket (15) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:52 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:53 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:53 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:53 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:53 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:53 CTS FIX socket (15) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:53 CTS FIX socket (15) | Initiating close of socket by core. | 2018-08-17 07:58:53 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:53 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:53 CTS FIX socket (15) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:53 CTS FIX socket (15) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:53 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:53 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:53 CTS FIX socket (15) | Socket gracefully closed by remote side. | 2018-08-17 07:58:53 CTS FIX socket (15) | Received socket Close event. | 2018-08-17 07:58:53 CTS FIX socket (15) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:53 * CTS FIX socket (15) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:53 CTS FIX socket (15) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:53 CTS FIX socket (15) | Closed. | 2018-08-17 07:58:53 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:56 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:56 CTS FIX socket (16) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:56 CTS FIX socket (16) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:58:56 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:56 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:56 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:56 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:56 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:56 CTS FIX socket (16) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:58:56 CTS FIX socket (16) | Initiating close of socket by core. | 2018-08-17 07:58:56 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:56 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:56 CTS FIX socket (16) | Sending bytes from final send buffer: 107 | 2018-08-17 07:58:56 CTS FIX socket (16) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:56 CTS FIX socket (16) | Socket gracefully closed by remote side. | 2018-08-17 07:58:56 CTS FIX socket (16) | Received socket Close event. | 2018-08-17 07:58:56 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:56 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:56 CTS FIX socket (16) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:56 * CTS FIX socket (16) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:56 CTS FIX socket (16) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:56 CTS FIX socket (16) | Closed. | 2018-08-17 07:58:56 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:58:59 CTS T4 FIX | Firm: AMP | 2018-08-17 07:58:59 CTS FIX socket (17) | Creating socket. Using TLS 1.0. | 2018-08-17 07:58:59 CTS FIX socket (17) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:58:59 CTS FIX: Sending the Logon message. | 2018-08-17 07:58:59 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:58:59 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:58:59 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:58:59 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:58:59 CTS FIX socket (17) | Initiating close of socket by core. | 2018-08-17 07:58:59 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:58:59 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:59 CTS FIX socket (17) | Write in progress. Shutdown being delayed. | 2018-08-17 07:58:59 CTS T4 FIX | Disconnected. | 2018-08-17 07:58:59 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:58:59 CTS FIX socket (17) | Socket gracefully closed by remote side. | 2018-08-17 07:58:59 CTS FIX socket (17) | Received socket Close event. | 2018-08-17 07:58:59 CTS FIX socket (17) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:58:59 * CTS FIX socket (17) | Write has completed. Shutdown being performed. | 2018-08-17 07:58:59 CTS FIX socket (17) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:58:59 CTS FIX socket (17) | Closed. | 2018-08-17 07:58:59 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:02 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:02 CTS FIX socket (18) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:03 CTS FIX socket (18) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:03 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:03 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:04 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:04 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:04 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:04 CTS FIX socket (18) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:04 CTS FIX socket (18) | Initiating close of socket by core. | 2018-08-17 07:59:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:04 CTS FIX socket (18) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:04 CTS FIX socket (18) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:04 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:04 CTS FIX socket (18) | Socket gracefully closed by remote side. | 2018-08-17 07:59:04 CTS FIX socket (18) | Received socket Close event. | 2018-08-17 07:59:04 CTS FIX socket (18) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:04 * CTS FIX socket (18) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:04 CTS FIX socket (18) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:04 CTS FIX socket (18) | Closed. | 2018-08-17 07:59:04 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:07 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:07 CTS FIX socket (19) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:07 CTS FIX socket (19) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:07 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:07 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:07 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:07 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:07 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:07 CTS FIX socket (19) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:07 CTS FIX socket (19) | Initiating close of socket by core. | 2018-08-17 07:59:07 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:07 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:07 CTS FIX socket (19) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:07 CTS FIX socket (19) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:07 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:07 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:07 CTS FIX socket (19) | Socket gracefully closed by remote side. | 2018-08-17 07:59:07 CTS FIX socket (19) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:07 * CTS FIX socket (19) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:07 CTS FIX socket (19) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:07 CTS FIX socket (19) | Closed. | 2018-08-17 07:59:07 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:10 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:10 CTS FIX socket (20) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:10 CTS FIX socket (20) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:10 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:10 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:10 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:10 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:10 * CTS FIX socket (20) | Socket gracefully closed by remote side. | 2018-08-17 07:59:10 CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:10 CTS FIX socket (20) | Received socket Close event. | 2018-08-17 07:59:10 CTS FIX socket (20) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:10 CTS FIX socket (20) | Initiating close of socket by core. | 2018-08-17 07:59:10 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:10 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:10 CTS FIX socket (20) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:10 CTS FIX socket (20) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:10 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:10 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:10 CTS FIX socket (20) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:10 * CTS FIX socket (20) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:10 CTS FIX socket (20) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:10 CTS FIX socket (20) | Closed. | 2018-08-17 07:59:10 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:13 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:13 CTS FIX socket (21) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:13 CTS FIX socket (21) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:13 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:14 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:14 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:14 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:14 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:14 CTS FIX socket (21) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:14 CTS FIX socket (21) | Initiating close of socket by core. | 2018-08-17 07:59:14 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:14 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:14 CTS FIX socket (21) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:14 CTS FIX socket (21) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:14 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:14 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:14 CTS FIX socket (21) | Socket gracefully closed by remote side. | 2018-08-17 07:59:14 CTS FIX socket (21) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:14 * CTS FIX socket (21) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:14 CTS FIX socket (21) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:14 CTS FIX socket (21) | Closed. | 2018-08-17 07:59:14 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:17 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:17 CTS FIX socket (22) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:17 CTS FIX socket (22) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:59:17 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:17 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:17 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:17 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:17 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:17 CTS FIX socket (22) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:17 CTS FIX socket (22) | Initiating close of socket by core. | 2018-08-17 07:59:17 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:17 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:17 CTS FIX socket (22) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:17 CTS FIX socket (22) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:17 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:17 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:17 CTS FIX socket (22) | Socket gracefully closed by remote side. | 2018-08-17 07:59:17 CTS FIX socket (22) | Received socket Close event. | 2018-08-17 07:59:17 CTS FIX socket (22) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:17 * CTS FIX socket (22) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:17 CTS FIX socket (22) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:17 CTS FIX socket (22) | Closed. | 2018-08-17 07:59:17 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:20 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:20 CTS FIX socket (23) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:20 CTS FIX socket (23) | Connecting to IP: 74.201.6.106. | 2018-08-17 07:59:20 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:20 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:20 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:20 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:20 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:20 CTS FIX socket (23) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:20 CTS FIX socket (23) | Initiating close of socket by core. | 2018-08-17 07:59:20 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:20 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:20 CTS FIX socket (23) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:20 CTS FIX socket (23) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:20 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:20 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:20 CTS FIX socket (23) | Socket gracefully closed by remote side. | 2018-08-17 07:59:20 CTS FIX socket (23) | Received socket Close event. | 2018-08-17 07:59:20 CTS FIX socket (23) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:20 * CTS FIX socket (23) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:20 CTS FIX socket (23) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:20 CTS FIX socket (23) | Closed. | 2018-08-17 07:59:20 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:23 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:23 CTS FIX socket (24) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:23 CTS FIX socket (24) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:23 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:24 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:24 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:24 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:24 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:24 CTS FIX socket (24) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:24 CTS FIX socket (24) | Initiating close of socket by core. | 2018-08-17 07:59:24 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:24 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:24 CTS FIX socket (24) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:24 CTS FIX socket (24) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:24 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:24 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:24 CTS FIX socket (24) | Socket gracefully closed by remote side. | 2018-08-17 07:59:24 CTS FIX socket (24) | Received socket Close event. | 2018-08-17 07:59:24 CTS FIX socket (24) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:24 * CTS FIX socket (24) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:24 CTS FIX socket (24) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:24 CTS FIX socket (24) | Closed. | 2018-08-17 07:59:24 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:27 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:27 CTS FIX socket (25) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:27 CTS FIX socket (25) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:27 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:27 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:27 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:27 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:27 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:27 CTS FIX socket (25) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:27 CTS FIX socket (25) | Initiating close of socket by core. | 2018-08-17 07:59:27 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:27 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:27 CTS FIX socket (25) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:27 CTS FIX socket (25) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:27 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:27 CTS FIX socket (25) | Socket gracefully closed by remote side. | 2018-08-17 07:59:27 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:27 CTS FIX socket (25) | Received socket Close event. | 2018-08-17 07:59:27 CTS FIX socket (25) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:27 * CTS FIX socket (25) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:27 CTS FIX socket (25) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:27 CTS FIX socket (25) | Closed. | 2018-08-17 07:59:27 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:30 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:30 CTS FIX socket (27) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:30 CTS FIX socket (27) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:30 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:30 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:30 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:30 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:30 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:30 CTS FIX socket (27) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:30 CTS FIX socket (27) | Initiating close of socket by core. | 2018-08-17 07:59:30 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:30 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:30 CTS FIX socket (27) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:30 CTS FIX socket (27) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:30 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:30 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:30 CTS FIX socket (27) | Socket gracefully closed by remote side. | 2018-08-17 07:59:30 CTS FIX socket (27) | Received socket Close event. | 2018-08-17 07:59:30 CTS FIX socket (27) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:30 * CTS FIX socket (27) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:30 CTS FIX socket (27) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:30 CTS FIX socket (27) | Closed. | 2018-08-17 07:59:30 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:33 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:33 CTS FIX socket (28) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:33 CTS FIX socket (28) | Connecting to IP: 74.201.6.74. | 2018-08-17 07:59:33 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:34 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:34 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:34 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:34 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:34 CTS FIX socket (28) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:34 CTS FIX socket (28) | Initiating close of socket by core. | 2018-08-17 07:59:34 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:34 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:34 CTS FIX socket (28) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:34 CTS FIX socket (28) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:34 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:34 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:34 CTS FIX socket (28) | Socket gracefully closed by remote side. | 2018-08-17 07:59:34 CTS FIX socket (28) | Received socket Close event. | 2018-08-17 07:59:34 CTS FIX socket (28) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:34 * CTS FIX socket (28) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:34 CTS FIX socket (28) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:34 CTS FIX socket (28) | Closed. | 2018-08-17 07:59:34 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:37 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:37 CTS FIX socket (29) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:37 CTS FIX socket (29) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:37 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:37 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:37 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:37 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:37 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:37 CTS FIX socket (29) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:37 CTS FIX socket (29) | Initiating close of socket by core. | 2018-08-17 07:59:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:37 CTS FIX socket (29) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:37 CTS FIX socket (29) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:37 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:37 CTS FIX socket (29) | Socket gracefully closed by remote side. | 2018-08-17 07:59:37 CTS FIX socket (29) | Received socket Close event. | 2018-08-17 07:59:37 CTS FIX socket (29) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:37 * CTS FIX socket (29) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:37 CTS FIX socket (29) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:37 CTS FIX socket (29) | Closed. | 2018-08-17 07:59:37 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:40 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:40 CTS FIX socket (30) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:40 CTS FIX socket (30) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:40 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:40 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:40 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:40 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:40 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:40 CTS FIX socket (30) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:40 CTS FIX socket (30) | Initiating close of socket by core. | 2018-08-17 07:59:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:40 CTS FIX socket (30) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:40 CTS FIX socket (30) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:40 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:40 CTS FIX socket (30) | Socket gracefully closed by remote side. | 2018-08-17 07:59:40 CTS FIX socket (30) | Received socket Close event. | 2018-08-17 07:59:40 CTS FIX socket (30) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:40 * CTS FIX socket (30) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:40 CTS FIX socket (30) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:40 CTS FIX socket (30) | Closed. | 2018-08-17 07:59:40 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:43 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:43 CTS FIX socket (31) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:43 CTS FIX socket (31) | Connecting to IP: 69.44.110.74. | 2018-08-17 07:59:43 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:44 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:44 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:44 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:44 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:44 CTS FIX socket (31) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:44 CTS FIX socket (31) | Initiating close of socket by core. | 2018-08-17 07:59:44 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:44 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:44 CTS FIX socket (31) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:44 CTS FIX socket (31) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:44 CTS FIX socket (31) | Socket gracefully closed by remote side. | 2018-08-17 07:59:44 CTS FIX socket (31) | Received socket Close event. | 2018-08-17 07:59:44 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:44 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:44 CTS FIX socket (31) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:44 * CTS FIX socket (31) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:44 CTS FIX socket (31) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:44 CTS FIX socket (31) | Closed. | 2018-08-17 07:59:44 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:47 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:47 CTS FIX socket (32) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:47 CTS FIX socket (32) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:47 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:47 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:47 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:47 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:47 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:47 CTS FIX socket (32) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:47 CTS FIX socket (32) | Initiating close of socket by core. | 2018-08-17 07:59:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:47 CTS FIX socket (32) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:47 CTS FIX socket (32) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:47 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:47 CTS FIX socket (32) | Socket gracefully closed by remote side. | 2018-08-17 07:59:47 CTS FIX socket (32) | Received socket Close event. | 2018-08-17 07:59:47 CTS FIX socket (32) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:47 * CTS FIX socket (32) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:47 CTS FIX socket (32) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:47 CTS FIX socket (32) | Closed. | 2018-08-17 07:59:47 CTS T4 FIX | Connecting to CTS Live server fix.t4login.com:10443 | 2018-08-17 07:59:50 CTS T4 FIX | Firm: AMP | 2018-08-17 07:59:50 CTS FIX socket (33) | Creating socket. Using TLS 1.0. | 2018-08-17 07:59:50 CTS FIX socket (33) | Connecting to IP: 69.44.110.106. | 2018-08-17 07:59:50 CTS FIX: Sending the Logon message. | 2018-08-17 07:59:50 CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:50 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:50 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:50 * CTS FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 07:59:50 CTS FIX socket (33) | Adding bytes from final send buffer from buffered socket: 107 | 2018-08-17 07:59:50 CTS FIX socket (33) | Initiating close of socket by core. | 2018-08-17 07:59:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 07:59:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:50 CTS FIX socket (33) | Sending bytes from final send buffer: 107 | 2018-08-17 07:59:50 CTS FIX socket (33) | Write in progress. Shutdown being delayed. | 2018-08-17 07:59:50 CTS FIX socket (33) | Socket gracefully closed by remote side. | 2018-08-17 07:59:50 CTS FIX socket (33) | Received socket Close event. | 2018-08-17 07:59:50 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 07:59:50 CTS FIX socket (33) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 07:59:51 * CTS FIX socket (33) | Write has completed. Shutdown being performed. | 2018-08-17 07:59:51 CTS FIX socket (33) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:51 CTS FIX socket (33) | Closed. | 2018-08-17 07:59:51 CTS T4 FIX | Disconnected. | 2018-08-17 07:59:51 Checking for new symbol settings for service code cqg | 2018-08-17 07:59:51 Current selected Data/Trading service: CQG FIX Trading | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Creating socket. Using TLS 1.2. | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Connecting to IP: 204.15.192.108. | 2018-08-17 07:59:51 Requesting symbol settings for service code cqg. Overwrite = on. | 2018-08-17 07:59:51 Symbol settings received. | 2018-08-17 07:59:51 Processed 1335 symbol settings. | 2018-08-17 07:59:51 HTTPS connection to www.sierrachart.com:443 (34) | Socket gracefully closed by remote side. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Received socket Close event. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Initiating close of socket by core. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 07:59:56 HTTPS connection to www.sierrachart.com:443 (34) | Closed. | 2018-08-17 07:59:56 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:29 CQG FIX socket (36) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:29 CQG FIX socket (36) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:29 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:29 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:29 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:29 CQG FIX socket (36) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:29 CQG FIX socket (36) | Initiating close of socket by core. | 2018-08-17 08:00:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:29 CQG FIX socket (36) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:29 CQG FIX socket (36) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:29 CQG FIX socket (36) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:29 CQG FIX socket (36) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:29 CQG FIX socket (36) | Socket gracefully closed by remote side. | 2018-08-17 08:00:30 CQG FIX socket (36) | Closed. | 2018-08-17 08:00:30 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:32 CQG FIX socket (37) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:32 CQG FIX socket (37) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:32 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:33 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:33 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:33 CQG FIX socket (37) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:33 CQG FIX socket (37) | Initiating close of socket by core. | 2018-08-17 08:00:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:33 CQG FIX socket (37) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:33 CQG FIX socket (37) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:33 CQG FIX socket (37) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:33 CQG FIX socket (37) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:33 CQG FIX socket (37) | Socket gracefully closed by remote side. | 2018-08-17 08:00:33 CQG FIX socket (37) | Closed. | 2018-08-17 08:00:33 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:36 CQG FIX socket (38) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:36 CQG FIX socket (38) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:36 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:36 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:37 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:37 CQG FIX socket (38) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:37 CQG FIX socket (38) | Initiating close of socket by core. | 2018-08-17 08:00:37 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:37 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:37 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:37 CQG FIX socket (38) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:37 CQG FIX socket (38) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:37 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:37 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:37 CQG FIX socket (38) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:37 CQG FIX socket (38) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:37 CQG FIX socket (38) | Socket gracefully closed by remote side. | 2018-08-17 08:00:37 CQG FIX socket (38) | Closed. | 2018-08-17 08:00:37 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:40 CQG FIX socket (39) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:40 CQG FIX socket (39) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:40 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:40 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:40 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:40 CQG FIX socket (39) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:40 CQG FIX socket (39) | Initiating close of socket by core. | 2018-08-17 08:00:40 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:40 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:40 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:40 CQG FIX socket (39) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:40 CQG FIX socket (39) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:40 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:40 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:40 CQG FIX socket (39) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:40 CQG FIX socket (39) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:40 CQG FIX socket (39) | Socket gracefully closed by remote side. | 2018-08-17 08:00:40 CQG FIX socket (39) | Closed. | 2018-08-17 08:00:40 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:43 CQG FIX socket (40) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:43 CQG FIX socket (40) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:43 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:43 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:43 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:43 CQG FIX socket (40) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:43 CQG FIX socket (40) | Initiating close of socket by core. | 2018-08-17 08:00:43 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:43 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:43 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:43 CQG FIX socket (40) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:43 CQG FIX socket (40) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:43 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:43 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:43 CQG FIX socket (40) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:44 CQG FIX socket (40) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:44 CQG FIX socket (40) | Socket gracefully closed by remote side. | 2018-08-17 08:00:44 CQG FIX socket (40) | Closed. | 2018-08-17 08:00:44 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:46 CQG FIX socket (41) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:46 CQG FIX socket (41) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:46 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:47 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:47 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:47 CQG FIX socket (41) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:47 CQG FIX socket (41) | Initiating close of socket by core. | 2018-08-17 08:00:47 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:47 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:47 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:47 CQG FIX socket (41) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:47 CQG FIX socket (41) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:47 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:47 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:47 CQG FIX socket (41) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:47 CQG FIX socket (41) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:47 CQG FIX socket (41) | Socket gracefully closed by remote side. | 2018-08-17 08:00:47 CQG FIX socket (41) | Closed. | 2018-08-17 08:00:47 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:50 CQG FIX socket (42) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:50 CQG FIX socket (42) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:50 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:50 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:50 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:50 CQG FIX socket (42) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:50 CQG FIX socket (42) | Initiating close of socket by core. | 2018-08-17 08:00:50 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:50 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:50 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:50 CQG FIX socket (42) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:50 CQG FIX socket (42) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:50 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:50 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:50 CQG FIX socket (42) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:50 CQG FIX socket (42) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:50 CQG FIX socket (42) | Socket gracefully closed by remote side. | 2018-08-17 08:00:50 CQG FIX socket (42) | Closed. | 2018-08-17 08:00:50 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:53 CQG FIX socket (43) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:53 CQG FIX socket (43) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:53 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:54 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:54 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:54 CQG FIX socket (43) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:54 CQG FIX socket (43) | Initiating close of socket by core. | 2018-08-17 08:00:54 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:54 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:54 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:54 CQG FIX socket (43) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:54 CQG FIX socket (43) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:54 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:54 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:54 CQG FIX socket (43) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:54 CQG FIX socket (43) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:54 CQG FIX socket (43) | Socket gracefully closed by remote side. | 2018-08-17 08:00:54 CQG FIX socket (43) | Closed. | 2018-08-17 08:00:54 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:00:57 CQG FIX socket (44) | Creating socket. Using TLS 1.2. | 2018-08-17 08:00:57 CQG FIX socket (44) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:00:57 CQG FIX: Sending the Logon message. | 2018-08-17 08:00:57 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:00:57 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:00:57 CQG FIX socket (44) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:00:57 CQG FIX socket (44) | Initiating close of socket by core. | 2018-08-17 08:00:57 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:57 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:00:57 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:57 CQG FIX socket (44) | Sending bytes from final send buffer: 110 | 2018-08-17 08:00:57 CQG FIX socket (44) | Write in progress. Shutdown being delayed. | 2018-08-17 08:00:57 CQG FIX Trading | Disconnected. | 2018-08-17 08:00:57 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:00:57 CQG FIX socket (44) | Write has completed. Shutdown being performed. | 2018-08-17 08:00:57 CQG FIX socket (44) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:00:57 CQG FIX socket (44) | Socket gracefully closed by remote side. | 2018-08-17 08:00:57 CQG FIX socket (44) | Closed. | 2018-08-17 08:00:57 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:00 CQG FIX socket (45) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:00 CQG FIX socket (45) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:00 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:00 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:01 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:01 CQG FIX socket (45) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:01 CQG FIX socket (45) | Initiating close of socket by core. | 2018-08-17 08:01:01 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:01 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:01 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:01 CQG FIX socket (45) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:01 CQG FIX socket (45) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:01 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:01 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:01 CQG FIX socket (45) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:01 CQG FIX socket (45) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:01 CQG FIX socket (45) | Socket gracefully closed by remote side. | 2018-08-17 08:01:01 CQG FIX socket (45) | Closed. | 2018-08-17 08:01:01 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:04 CQG FIX socket (46) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:04 CQG FIX socket (46) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:04 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:04 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:04 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:04 CQG FIX socket (46) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:04 CQG FIX socket (46) | Initiating close of socket by core. | 2018-08-17 08:01:04 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:04 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:04 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:04 CQG FIX socket (46) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:04 CQG FIX socket (46) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:04 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:04 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:04 CQG FIX socket (46) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:04 CQG FIX socket (46) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:04 CQG FIX socket (46) | Socket gracefully closed by remote side. | 2018-08-17 08:01:04 CQG FIX socket (46) | Closed. | 2018-08-17 08:01:04 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:07 CQG FIX socket (47) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:07 CQG FIX socket (47) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:07 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:07 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:08 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:08 CQG FIX socket (47) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:08 CQG FIX socket (47) | Initiating close of socket by core. | 2018-08-17 08:01:08 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:08 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:08 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:08 CQG FIX socket (47) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:08 CQG FIX socket (47) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:08 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:08 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:08 CQG FIX socket (47) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:08 CQG FIX socket (47) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:08 CQG FIX socket (47) | Socket gracefully closed by remote side. | 2018-08-17 08:01:08 CQG FIX socket (47) | Closed. | 2018-08-17 08:01:08 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:11 CQG FIX socket (48) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:11 CQG FIX socket (48) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:11 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:11 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:12 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:12 CQG FIX socket (48) | Initiating close of socket by core. | 2018-08-17 08:01:12 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:12 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:12 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:12 CQG FIX socket (48) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:12 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:12 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:12 CQG FIX socket (48) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:12 CQG FIX socket (48) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:12 CQG FIX socket (48) | Socket gracefully closed by remote side. | 2018-08-17 08:01:12 CQG FIX socket (48) | Closed. | 2018-08-17 08:01:12 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:15 CQG FIX socket (49) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:15 CQG FIX socket (49) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:15 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:15 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:15 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:15 CQG FIX socket (49) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:15 CQG FIX socket (49) | Initiating close of socket by core. | 2018-08-17 08:01:15 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:15 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:15 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:15 CQG FIX socket (49) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:15 CQG FIX socket (49) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:15 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:15 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:15 CQG FIX socket (49) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:15 CQG FIX socket (49) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:15 CQG FIX socket (49) | Socket gracefully closed by remote side. | 2018-08-17 08:01:15 CQG FIX socket (49) | Closed. | 2018-08-17 08:01:15 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:18 CQG FIX socket (50) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:18 CQG FIX socket (50) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:18 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:18 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:19 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:19 CQG FIX socket (50) | Initiating close of socket by core. | 2018-08-17 08:01:19 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:19 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:19 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:19 CQG FIX socket (50) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:19 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:19 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:19 CQG FIX socket (50) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:19 CQG FIX socket (50) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:19 CQG FIX socket (50) | Socket gracefully closed by remote side. | 2018-08-17 08:01:19 CQG FIX socket (50) | Closed. | 2018-08-17 08:01:19 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:22 CQG FIX socket (51) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:22 CQG FIX socket (51) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:22 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:22 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:22 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:22 CQG FIX socket (51) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:22 CQG FIX socket (51) | Initiating close of socket by core. | 2018-08-17 08:01:22 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:22 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:22 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:22 CQG FIX socket (51) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:22 CQG FIX socket (51) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:22 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:22 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:22 CQG FIX socket (51) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:22 CQG FIX socket (51) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:22 CQG FIX socket (51) | Socket gracefully closed by remote side. | 2018-08-17 08:01:22 CQG FIX socket (51) | Closed. | 2018-08-17 08:01:22 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:25 CQG FIX socket (52) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:25 CQG FIX socket (52) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:25 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:26 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:26 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:26 CQG FIX socket (52) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:26 CQG FIX socket (52) | Initiating close of socket by core. | 2018-08-17 08:01:26 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:26 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:26 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:26 CQG FIX socket (52) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:26 CQG FIX socket (52) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:26 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:26 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:26 CQG FIX socket (52) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:26 CQG FIX socket (52) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:26 CQG FIX socket (52) | Socket gracefully closed by remote side. | 2018-08-17 08:01:26 CQG FIX socket (52) | Closed. | 2018-08-17 08:01:26 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:29 CQG FIX socket (54) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:29 CQG FIX socket (54) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:29 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:29 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:29 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:29 CQG FIX socket (54) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:29 CQG FIX socket (54) | Initiating close of socket by core. | 2018-08-17 08:01:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:29 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:29 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:29 CQG FIX socket (54) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:29 CQG FIX socket (54) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:29 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:29 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:29 CQG FIX socket (54) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:29 CQG FIX socket (54) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:29 CQG FIX socket (54) | Socket gracefully closed by remote side. | 2018-08-17 08:01:29 CQG FIX socket (54) | Closed. | 2018-08-17 08:01:29 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:32 CQG FIX socket (55) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:32 CQG FIX socket (55) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:32 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:32 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:33 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:33 CQG FIX socket (55) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:33 CQG FIX socket (55) | Initiating close of socket by core. | 2018-08-17 08:01:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:33 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:33 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:33 CQG FIX socket (55) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:33 CQG FIX socket (55) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:33 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:33 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:33 CQG FIX socket (55) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:33 CQG FIX socket (55) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:33 CQG FIX socket (55) | Socket gracefully closed by remote side. | 2018-08-17 08:01:33 CQG FIX socket (55) | Closed. | 2018-08-17 08:01:33 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:36 CQG FIX socket (56) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:36 CQG FIX socket (56) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:36 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:36 CQG FIX: Received a Logout message. Text = Your logon is disabled. Contact your FCM. | 2018-08-17 08:01:36 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:36 CQG FIX socket (56) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:36 CQG FIX socket (56) | Initiating close of socket by core. | 2018-08-17 08:01:36 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:36 Error connecting to Data or Trading service. For help with this issue, press the 'Send For Analysis' button on this window. | 2018-08-17 08:01:36 Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:36 CQG FIX socket (56) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:36 CQG FIX socket (56) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:36 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:36 Will reconnect to the server in 3.0 seconds. Select 'File >> Disconnect' to prevent further connection attempts. | 2018-08-17 08:01:36 CQG FIX socket (56) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:36 CQG FIX socket (56) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:36 CQG FIX socket (56) | Socket gracefully closed by remote side. | 2018-08-17 08:01:36 CQG FIX socket (56) | Closed. | 2018-08-17 08:01:36 CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2018-08-17 08:01:39 CQG FIX socket (57) | Creating socket. Using TLS 1.2. | 2018-08-17 08:01:39 CQG FIX socket (57) | Connecting to IP: 208.48.16.214. | 2018-08-17 08:01:39 CQG FIX: Sending the Logon message. | 2018-08-17 08:01:39 CQG FIX: Received a Logout message. Text = Logon rate has exceeded the allowable limit: 20 logins per 5 minutes. Contact Customer Support for assistance. | 2018-08-17 08:01:39 CQG FIX: Sending a Logout message. Text = Received Logout message. | 2018-08-17 08:01:39 CQG FIX socket (57) | Adding bytes from final send buffer from buffered socket: 110 | 2018-08-17 08:01:39 CQG FIX socket (57) | Initiating close of socket by core. | 2018-08-17 08:01:39 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:39 CQG FIX socket (57) | Sending bytes from final send buffer: 110 | 2018-08-17 08:01:39 CQG FIX socket (57) | Write in progress. Shutdown being delayed. | 2018-08-17 08:01:39 CQG FIX Trading | Disconnected. | 2018-08-17 08:01:39 CQG FIX socket (57) | Write has completed. Shutdown being performed. | 2018-08-17 08:01:39 CQG FIX socket (57) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:01:39 CQG FIX socket (57) | Socket gracefully closed by remote side. | 2018-08-17 08:01:40 CQG FIX socket (57) | Closed. | 2018-08-17 08:01:40 Checking for new symbol settings for service code tda | 2018-08-17 08:05:44 Current selected Data/Trading service: TD Ameritrade | 2018-08-17 08:05:44 HTTPS connection to www.sierrachart.com:443 (62) | Creating socket. Using TLS 1.2. | 2018-08-17 08:05:44 HTTPS connection to www.sierrachart.com:443 (62) | Connecting to IP: 204.15.192.108. | 2018-08-17 08:05:44 Requesting symbol settings for service code tda. Overwrite = on. | 2018-08-17 08:05:44 Symbol settings received. | 2018-08-17 08:05:44 Processed 832 symbol settings. | 2018-08-17 08:05:45 HTTPS connection to www.sierrachart.com:443 (62) | Socket gracefully closed by remote side. | 2018-08-17 08:05:49 HTTPS connection to www.sierrachart.com:443 (62) | Received socket Close event. | 2018-08-17 08:05:49 HTTPS connection to www.sierrachart.com:443 (62) | Initiating close of socket by core. | 2018-08-17 08:05:49 HTTPS connection to www.sierrachart.com:443 (62) | Graceful close received or receive error. Shutdown complete. Closing socket now. | 2018-08-17 08:05:49 HTTPS connection to www.sierrachart.com:443 (62) | Closed. | 2018-08-17 08:05:49 TD Ameritrade | Connecting. | 2018-08-17 08:05:51 TD Ameritrade | Logging in. (Step 1 of 3) | 2018-08-17 08:05:51 HTTPS connection to apis.tdameritrade.com:443 (63) | Creating socket. Using TLS 1.0. | 2018-08-17 08:05:51 HTTPS connection to apis.tdameritrade.com:443 (63) | Connecting to IP: 216.105.251.201. | 2018-08-17 08:05:51 TD Ameritrade | Authorized for streamer data. Account: 49*** | 2018-08-17 08:05:52 TD Ameritrade | Authorized for streamer data. Account: 49*** | 2018-08-17 08:05:52 TD Ameritrade | Authorized for streamer data. Account: 49*** | 2018-08-17 08:05:52 TD Ameritrade | Authorized for streamer data. Account: 49*** | 2018-08-17 08:05:52 TD Ameritrade | Authorized for streamer data. Account: 20*** | 2018-08-17 08:05:52 TD Ameritrade | Getting streamer information. (Step 2 of 3) | 2018-08-17 08:05:52 TD Ameritrade | Requesting message key for account activity streamer (Step 3 of 3) | 2018-08-17 08:05:52 TD Ameritrade | Requesting account balance data. Connection will be complete once received. | 2018-08-17 08:05:53 TD Ameritrade | Connected to data and trading server. | 2018-08-17 08:05:53 TD Ameritrade | Streamer request #1 initiated. | 2018-08-17 08:05:54 HTTPS connection to ameritrade02.streamer.com:443 (64) | Creating socket. Using TLS 1.0. | 2018-08-17 08:05:54 HTTPS connection to ameritrade02.streamer.com:443 (64) | Connecting to IP: 216.105.251.37. | 2018-08-17 08:05:54 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-2 | 2018-08-17 08:05:55 Subscribing to market data for symbol ACBFF for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: ACBFF. ID: 1 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: ACBFF. ID: 1 | 2018-08-17 08:05:59 Subscribing to market data for symbol AGG for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: AGG. ID: 2 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: AGG. ID: 2 | 2018-08-17 08:05:59 Subscribing to market data for symbol BNDX for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: BNDX. ID: 3 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: BNDX. ID: 3 | 2018-08-17 08:05:59 Subscribing to market data for symbol BSV for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: BSV. ID: 4 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: BSV. ID: 4 | 2018-08-17 08:05:59 Subscribing to market data for symbol EMLC for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: EMLC. ID: 5 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: EMLC. ID: 5 | 2018-08-17 08:05:59 Subscribing to market data for symbol ITOT for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: ITOT. ID: 6 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: ITOT. ID: 6 | 2018-08-17 08:05:59 Subscribing to market data for symbol VEA for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: VEA. ID: 7 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: VEA. ID: 7 | 2018-08-17 08:05:59 Subscribing to market data for symbol VWO for trade position profit/loss. | 2018-08-17 08:05:59 TD Ameritrade | Starting real-time market data updates for: VWO. ID: 8 | 2018-08-17 08:05:59 TD Ameritrade | Requesting security definition data for: VWO. ID: 8 | 2018-08-17 08:05:59 TD Ameritrade | Old streamer request finished. Request ID: 1. | 2018-08-17 08:06:00 HTTPS connection to ameritrade02.streamer.com:443 (64) | Initiating close of socket by core. | 2018-08-17 08:06:00 HTTPS connection to ameritrade02.streamer.com:443 (64) | Shutdown started. Waiting for graceful close. | 2018-08-17 08:06:00 TD Ameritrade | Streamer request #2 initiated. | 2018-08-17 08:06:01 HTTPS connection to ameritrade02.streamer.com:443 (65) | Creating socket. Using TLS 1.0. | 2018-08-17 08:06:01 HTTPS connection to ameritrade02.streamer.com:443 (65) | Connecting to IP: 216.105.251.37. | 2018-08-17 08:06:01 TD Ameritrade | Streamer response: STREAMER_SERVER_ID. Additional text: 10-2 | 2018-08-17 08:06:01 HTTPS connection to ameritrade02.streamer.com:443 (64) | Close event error. Windows error code 10053: An established connection was aborted by the software in your host machine. | 2018-08-17 08:06:02 * HTTPS connection to ameritrade02.streamer.com:443 (64) | Socket gracefully closed by remote side. | 2018-08-17 08:06:02 HTTPS connection to ameritrade02.streamer.com:443 (64) | Closed. | 2018-08-17 08:06:02 |
[2018-08-17 08:11:17] |
We are seeing connections to several different services. So did you want to connect to CQG, CTS or TD Ameritrade? Which one.
[2018-08-17 08:16:35] |
Grateful55 - Posts: 32 |
I got TD Ameritrade to work but the other two don't for some reason and all my charts are missing sorry for the head ache I'm new thanks for any help you can provide
[2018-08-17 11:25:50] |
In the case of CTS these are the relevant messages: CTS FIX: Received a Logout message. Text = Login failed: most likely incorrect user and password combination | 2018-08-17 07:59:50 CTS T4 FIX | Check the Username, Password, Firm, Live/Simulation Server settings in 'File >> Data/Trade Service Settings'. | 2018-08-17 07:59:50 * CTS T4 FIX | One or more of them is not set correctly or your settings are not properly set on the CTS T4 system in which case contact your clearing firm. | 2018-08-17 07:59:50 * https://www.sierrachart.com/index.php?page=doc/CTS_T4.php#SetupInstructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
