Date/Time: Mon, 13 May 2024 05:28:17 +0000
Pos Qty@Price:
View Count: 926
[2018-08-17 03:01:16] |
User312841 - Posts: 25 |
In the DOM, the Pos Qty@Price reads -> 30@24.71E when it should read 30@50.51, and the P/L is way high reading 773.92C Checked all the settings areas, cannot find my way out of this... |
Pos_Qty.JPG / V - Attached On 2018-08-17 02:51:26 UTC - Size: 22.7 KB - 286 views |
[2018-08-17 04:55:19] |
This is explained here: Trading Information Windows: Trade Service Provided Average Price That is an external service provided Position Average Price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-17 21:10:51] |
The display is incorrect. I bought the stock at 49.4249 and it is showing as 24.71E. The P/L is way off too. I am using TDAmeritrade for years now, does it not play nicely with Sierrachart??? If not what brokerages work better...
[2018-08-20 01:07:54] |
The only other choice would be Interactive Brokers: http://www.sierrachart.com/index.php?page=doc/InteractiveBrokers.php Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
