Date/Time: Mon, 20 May 2024 15:42:41 +0000
ASX symbols on Real-time and Historical Exchange Data Feed Symbols
View Count: 1225
[2018-08-15 06:36:41] |
User629461 - Posts: 162 |
Hi, I cant seem to find the ASX stock symbols on the Real-time and Historical Exchange Data Feed. Are you able to explain how to access these symbols? https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX Many thanks |
[2018-08-15 07:12:48] |
No. Real-time data is not provided for that exchange. Just historical data.
[2018-08-15 10:58:19] |
Ok - either way where can I find the historical data? ASX securities are not listed in the Available symbols list under 'Find Symbols'. When I search for a symbol code it indicates 'Not Found' (eg BHP). I am searching under 'SC Data - All Services'. Date Time Of Last Edit: 2018-08-15 10:59:06
[2018-08-15 11:25:34] |
OK - I figured out if I type the symbol name (ie BHP.AX) in the 'Selected Symbol' field and hit 'Open Historical Chart' it brings up the chart, however, the symbols do not appear om the 'Available Symbols list to select from. Why is that or is something wrong? Also, who are you using as you data provider for the ASX stocks? |
[2018-08-16 04:57:00] |
, however, the symbols do not appear om the 'Available Symbols list to select from. Refer to:File Menu: Find Symbol (File) The symbols are listed here: https://www.sierrachart.com/index.php?page=doc/SierraChart_RealTime_And_Historical_Symbols.php&SymbolsPage=Stocks&ID=1#ASX Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-16 04:58:00
