Date/Time: Sun, 19 May 2024 01:12:02 +0000
Daily OHLC showing on Daily
View Count: 733
[2018-08-13 12:07:43] |
StevenCaleb - Posts: 14 |
The Daily OHLC shows on all time frames except for daily. How can I fix this?
[2018-08-13 18:08:00] |
When the chart bars are set to Daily, post an image of the chart following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-13 20:14:15] |
http://www.sierrachart.com/image.php?Image=1534191121199.png
[2018-08-14 21:54:57] |
Check the Number of Days to Calculate input with the Daily OHLC study. You will need to increase that.
[2018-08-15 14:16:35] |
I increased that but it didn't help. I tried several different #s of days back. Regardless I still had the 0 readings as in the image I posted.
[2018-08-15 17:13:24] |
You are adjusting the wrong setting. The Input is named "Number of Days to Calculate".
[2018-08-16 20:43:42] |
No, I tried both. I still get 0s.
[2018-08-16 21:11:54] |
There still must be a problem with the Input settings. Follow the instructions here to reset the study to default and then remove it and add it again: Chart Studies: Resetting Default Study Settings For an Individual Study Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-18 11:14:28] |
That got it working. But now it shows different OHLC numbers on the daily than my 5 minute chart. I noticed in chart settings when on daily, the seesions times are blanked out. Can this be fixed?
[2018-08-20 11:49:37] |
This page here answers your questions: Historical Chart Prices Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
