Date/Time: Mon, 20 May 2024 14:54:04 +0000
Study_Overlay_-_OHLC 21 Days graph only?
View Count: 694
[2018-08-12 19:05:58] |
TedMar - Posts: 189 |
Hi, i get only 21 Days history in the studie. Example in chartbook. 1.) #1 chart with 60 M TimeFrame and history 90 Days 2.) #2 Chart with Daily Timefame and history 90 Days 3.) Add Study_Overlay_-_OHLC to #2 Chart 4.) In Study_Overlay_-_OHLC add as "Chart,Study, Subgraph reference " chart #1 (main Price Graph, Last) Now i can see only 21 Days supgraph . no matter i change #1 to 10 Sec and #2 to 5m , i get ~21 Days in supgraph only. Whats Wrong? |
[2018-08-13 17:50:00] |
We are not sure about this. However, what is the purpose of using the Study Overlay-OHLC study if it is just referencing the main price graph? You are not going to get anything useful out of it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-13 17:50:27
[2018-08-13 18:21:17] |
Ratio or Diffrence from "How to Create High Accuracy Spread or Ratio Charts" How to Create High Accuracy Spread or Ratio Charts it is not posible load more as ~21 Days (in every time frames same problem ) |
[2018-08-13 18:52:01] |
bradh - Posts: 859 |
Example in chartbook. 1.) #1 chart with 60 M TimeFrame and history 90 Days 2.) #2 Chart with Daily Timefame and history 90 Days 3.) Add Study_Overlay_-_OHLC to #2 Chart 4.) In Study_Overlay_-_OHLC add as "Chart,Study, Subgraph reference " chart #1 (main Price Graph, Last) Now i can see only 21 Days supgraph . no matter i change #1 to 10 Sec and #2 to 5m , i get ~21 Days in supgraph only. Whats Wrong? You are trying to add a 60 min chart as an overlay to a daily chart. The daily chart has only one bar per day, overlaying a 60 min chart will only give you one bar per daily bar. Please explain what you are trying to do. |
[2018-08-13 21:31:26] |
??? in example. how i can make daily "diffrence" study overlay in chart #3 as Main grapgh? like a "How to Create High Accuracy Spread or Ratio Charts" manual. |
[2018-08-14 17:52:47] |
We need a more detailed description of what you want to accomplish.
[2018-08-15 00:34:50] |
I checked again, i think the SC Data for US Stocks not completted . Example Stocks 30m TimeFrame IFF first bar 16.April 2018 BAC first bar 26.March.2018 PG first bar 17 April.2018 Date Time Of Last Edit: 2018-08-15 00:35:20
2018-08-15 02_22_47-Sierra Chart 1788 test_ratio.Cht SC Dat.png / V - Attached On 2018-08-15 00:26:22 UTC - Size: 283.74 KB - 290 views 2018-08-15 02_30_48-Sierra Chart 1788 test_ratio.Cht SC Dat.png / V - Attached On 2018-08-15 00:32:00 UTC - Size: 324.74 KB - 295 views |
