Date/Time: Sat, 04 May 2024 10:49:23 +0000
Crude Oil 30-Minute Chart Skips from 2017 to 2014 Missing Years
View Count: 525
[2018-08-08 17:28:43] |
User827078 - Posts: 1 |
I can't load the full crude oil chart. Can you check your systems to make sure the full crude oil chart loads. Thank you.
[2018-08-08 17:37:52] |
Follow the instructions here to re-download the data for the Continuous Futures Contract chart: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Also if you update to the current version, an issue like this automatically resolves itself upon selecting Chart >> Reload and Recalculate at least in most cases. Here are the instructions to update: Software Download: Fast Update Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
