Date/Time: Sun, 28 Apr 2024 19:58:19 +0000
Quotation of the future DAX
View Count: 906
[2018-08-06 12:53:50] |
jean marie bourgeat - Posts: 4 |
Hello, with sierra chart, for the FDAX (DAX) market Eurex, I do not have the same point value as you on the previous deadline but it's good on the future date of the month. I just registered for sierra chart and I think I have the default feed (SC data) I wish to have the history in UT 5 min over 1 year. I make the comparison with pro realtime in France I just wish to do a graphical study not trading. Thank you. |
[2018-08-06 15:46:14] |
Provide an image of the chart or Trade DOM, by following these instructions: https://www.sierrachart.com/index.php?page=doc/PostingInformation.php#Image Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2018-08-08 07:40:32] |
hello, http://www.sierrachart.com/image.php?Image=1533713961575.png |
comparison.jpg / V - Attached On 2018-08-08 07:40:08 UTC - Size: 300.07 KB - 301 views |
[2018-08-08 07:56:07] |
What is the question?
[2018-08-08 09:03:07] |
On the attached file, difference in quotation between my two platforms on the previous future contract Thank you |
[2018-08-08 18:37:51] |
You may be looking at a back adjusted contract in the other program. Or you are comparing the June and September contracts. Which are different. In Sierra Chart you will want to use the Continuous Futures Contract feature which is documented here: Continuous Futures Contract Charts Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2018-08-08 18:38:37
[2018-08-09 03:38:28] |
Flipper - Posts: 65 |
the previous future contract Thank you That looks like a CFD chart? If it is then that is the reason for the different prices. It's "made up" by your CFD market maker. |
[2018-08-09 04:33:38] |
It might be a CFD but we do see that the word "Future" in the chart and also 09 2018.
[2018-08-09 07:07:22] |
Hello, j don't understand, not cfd ?
